YLR-04VF
YLR-04VF
    JST
    P=4.5mm
    2X2P 4.5MM
YLR-04VF 数据手册
YL CONNECTOR 4.5 mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications • Current rating: 10 A AC/DC (7 A when retainers are mounted) • Voltage rating: 300 V AC/DC • Temperature range: -25℃ to +90℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25 mm2 • Applicable panel thickness: 0.7 to 2.0 mm YL CONNECTOR Panel lock Inner lock Retainer Housing lance YLコネクタ表1 Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit: A No. of circuits The retainer features added protection against non-insertion or disconnection. ● ● ● ● Housing lance Secondary retainers Inner-housing lock Panel lock construction #16 #18 #20 #22 #24 #26 1 10 7 5 4 3 2 2 10 7 5 4 3 2 3 9 6 4 4 3 2 4 9 6 4 4 3 2 6 8 5 3 3 2 2 8 7 4 3 3 2 2 9 6 4 3 3 2 2 12 6 3 2 2 2 2 15 5 3 2 2 2 1 16 5 3 2 2 2 1 21 5 3 2 2 2 1 Note: Secondary retainers cannot be used with AWG #16 wires. * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Standards Recognized E60389 Certified LR20812 R9351052 ® Wire size (AWG) ® ® YLコネクタ表3 ® Panel Layout and Assembly layout A YLコネクタ表4 B (35.1) (38.7) (including retainer) 20.5 3.2 10.8 16.6 21.8 A C 9.5 15.3 D Single row 2・3 2-row 4・6・8・12・16 3-row 9・12・15・21 Dimensions (mm) A B E Type No. of circuits 9.8 Panel thickness No. of Receptacle (mm) circuits housing Model No. Dimensions (mm) 2 YLR-02V 3 YLR-03V 4 YLR-04V 6 YLR-06V 8 YLR-08V 9 YLR-09V YLR-12V 12 YLR-12VA 15 YLR-15V 16 YLR-16V 21 YLR-21V 0.7 to 2.0 0.7 to 0.8 0.9 to 1.3 1.4 to 2.0 A B C 10.7 16.8 7.1 D±0.1 E±0.1 D±0.1 E±0.1 D±0.1 E±0.1 4.4 1.35 5.0 1.05 5.6 0.75 15.3 21.3 7.1 4.4 1.35 5.0 1.05 5.6 0.75 10.7 16.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 15.3 21.3 12.9 7.1 2.9 7.7 2.6 8.3 2.3 19.8 25.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 15.3 21.3 18.2 7.1 5.55 7.7 5.25 8.3 4.95 19.8 25.8 18.2 7.1 5.55 7.7 5.25 8.3 4.95 28.9 34.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 24.4 30.3 18.2 7.1 5.55 7.7 5.25 8.3 4.95 37.9 43.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 33.5 39.3 18.2 7.1 5.55 7.7 5.25 8.3 4.95 Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. B 1 YL CONNECTOR YLコネクタ表2 Contact Applicable wire Model No. Pin contact 2 Pin contact AWG # Insulation O.D. (mm) 26~20 1.3~2.5 0.5 ~1.25 20~16 2.0~3.4 *0.3+0.3~ 0.5+0.5 *22+22~ 20+20 mm2 Socket contact SYM-01T-P0.5A SYF-01T-P0.5A 0.13~0.5 4.4 SYM-41T-P0.5A SYF-41T-P0.5A 2 0.5 1.1 19.5 Q’ty/ reel 4,000 *1.5+1.5~ 2.0+2.0 SYM-01T-P0.5A (    ) 5,000 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: 1 . Contact JST for special products. 2. Retainers cannot be used with electric wire whose insulation O.D. exceeds 2.7 mm and AWG #16. 3. *Marked products are not approved by TÜV . 2.8 Socket contact 2 4.4 SYM-01T-P0.5A 1.1 SYF-01T-P0.5A SYM-41T-P0.5A 1.8 Applicator Crimping machine Crimp applicator Contact 14.2 Crimp applicator with dies Dies MK/SYF/M-01-05 APLMK SYF/M01-05 AP-K2N MKS-L MK/SYF/M-41-05 APLMK SYF/M41-05 SYF-41T-P0.5A Note: Contact JST for fully automatic crimping applicator. Contact position location numbers Contact position numbers are stamped Retainer Receptacle housing Retainer Plug housing 3 3 2 1 1 2 2 1 4 8 3 7 L JST 12 11 10 L JST 8 9 3 7 6 2 5 21 20 19 17 16 15 18 10 9 8 11 12 13 14 1 7 8 16 7 15 6 14 5 13 4 12 3 11 2 10 9 6 6 12 5 11 4 10 7 1 1 15 14 13 L JST 12 4 1 5 2 6 3 6 2 5 L JST 1 4 4 2 L JST 3 10 9 8 11 1 7 9 6 5 2 4 10 3 3 2 11 1 4 16 15 14 13 12 11 10 9 1 12 8 7 6 5 4 3 2 1 5 8 5 L JST 13 7 6 5 4 3 2 1 15 14 13 12 11 4 2 15 6 14 13 12 11 10 9 8 10 9 8 7 6 3 9 14 1 21 20 19 18 17 16 15 5 4 3 2 1 2 3 16 7 6 5 4 3 2 1 12 11 10 9 8 7 1 4 17 10 15 2 11 10 9 8 7 6 L JST 5 18 11 8 7 15 14 13 12 11 L JST 16 3 12 1 4 3 2 1 6 5 4 3 2 1 L JST 6 19 12 4 8 5 9 2 8 7 6 5 8 7 6 5 4 3 2 1 3 6 9 2 5 8 1 4 7 3 9 13 5 13 2 L JST 6 9 3 10 14 7 15 4 11 10 8 L JST 12 12 11 10 9 16 15 14 13 12 11 10 9 3 6 2 5 1 4 2 8 7 20 1 21 14 2 3 1 9 7 8 2 L JST 8 7 3 2 4 1 3 1 9 6 4 9 6 3 8 5 2 7 4 1 4 3 2 1 5 10 8 7 6 5 6 3 5 2 4 1 6 5 4 3 2 1 4 5 L JST 11 1 1 1 6 2 5 4 12 3 L JST 4 2 7 6 5 3 8 7 2 6 4 9 8 3 5 L JST L JST 6 12 11 10 9 8 7 L JST 1 1 2 1 L JST L JST 3 1 1 L JST 1 4 2 3 1 2 4 2 L JST 1 3 2 1 3 2 2 1 L JST L JST 1 Plug housing L JST Receptacle housing 4 3 2 1 8 7 6 5 4 3 2 1 8 7 6 5 12 11 10 9 7 6 5 4 3 2 1 14 13 12 11 10 9 8 21 20 19 18 17 16 15 P266 YL CONNECTOR c Housing Material: Housing...PA 66, UL94V-0, white Retainer...Glass-filled PA 66, UL94V-0, ivory 26.6 8.5 3.35 500 6.0 YLP-02V Q’ty/ bag 1,000 2.9 YLS-02V Q’ty/ bag L JST 26.6 YLR-02VF 8.3 3.1 10.3 1 6.7 500 500 8.5 3.5 20.9 2 1,000 2.9 6.0 L JST 10.3 20.9 2 3.0 10.3 3.0 Q’ty/ bag 7A (10 A) 500 Q’ty/ bag 3.8 L JST 3.0 YLR-02V 300 V YLS-01V 1 6.7 2 Q’ty/ bag 2 7A (10 A) YLP-01V Retainer L JST 300 V Q’ty/ bag L JST 1 5.8 YLR-01VF Plug housing (for socket contact) 5.8 Receptacle housing (for pin contact) 1 No. of Voltage Current circuits rating rating 1 6.7 3.1 26.6 YLR-03V 3.0 Q’ty/ bag YLP-03V Q’ty/ bag 26.6 12.8 2 L JST 3.1 14.8 6.7 6A YLR-03VF 500 20.9 3 8.5 3.5 6.0 500 1,000 2.9 2 L JST 14.8 1 (9 A) 3 3.0 1 300 V Q’ty/ bag 2 L JST 14.8 3 3 YLS-03V (commonly used for 3-circuit housing and 6-circuit housing) 1 6.7 3.1 26.6 RoHS2 compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2. Contact JST for Glow Wire compliant connectors. 3 YL CONNECTOR P267 Housing Material: Housing...PA 66, UL94V-0, white No. of Voltage Current circuits rating rating Receptacle housing (for pin contact) 1 500 8.5 20.9 3.5 500 11.8 1,000 2.9 2 L JST 10.3 8.3 10.3 4 L JST 2 26.6 3 3.1 YLR-04VF 4 00 Q’ty/ bag 1 12.5 6A (9 A) YLS-02V 2 300 V Q’ty/ bag 3 4 YLP-04V Retainer L JST y/ g Plug housing (for socket contact) Q’ty/ bag 4 3.0 10.3 3.0 YLR-04V Retaine...Glass-filled PA 66, UL94V-0, ivory 3 1 y/ g 12.5 3.1 26.6 YLR-06V YLP-06V Q’ty/ bag 6 3 5 YLS-03V (commonly used for 3-circuit housing and 6-circuit housing) Q’ty/ bag 2 4 00 L JST 14.8 3.0 Q’ty/ bag 3 5 2 L JST 14.8 500 8.5 20.9 3.5 12.8 500 6 / g 14.8 YLR-06VF L JST 2 5 (8 A) 4 300 V 26.6 1 6 3.1 3 6 3.0 1 12.5 5A 1,000 2.9 11.8 4 1 L JST 12.5 00 3.1 26.6 YLR-08V YLP-08V Q’ty/ bag YLS-08V Q’ty/ bag 8 4 7 3 6 2 L JST 19.3 3.0 Q’ty/ bag 5 26.6 19.3 YLR-08VF 500 1 5 250 8.5 4 7 3 6 2 3.5 11.8 1,000 2.9 L JST 8 20.9 19.0 L JST 2 6 3.1 3 7 12.5 4A (7 A) 19.3 300 V 4 8 3.0 1 8 5 1 12.5 3.1 26.6 YLR-09V YLP-09V Q’ty/ bag 3.5 Q’ty/ bag 1 3.0 9 8 14.8 6 7 L JST 3 500 - 8.5 17.7 3.1 26.6 20.9 RoHS2 compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 4 5 4 4 7 250 1 2 14.8 3 5 8 4A (6 A) L JST 300 V 6 9 9 2 3.0 Q’ty/ bag 17.0 2. Contact JST for Glow Wire compliant connectors. YL CONNECTOR P268 Housing Material: Housing...PA 66, UL94V-0, white Receptacle housing (for pin contact) YLR-12VA YLP-12VA 1 26.3 L JST 1 7 20.9 26.6 12.5 3.0 1,000 7 2 8 200 8.5 11.8 2.9 3A YLR-12V Q’ty/ bag Q’ty/ bag 4 8 12 3 3 7 11 6 2 2 6 Q’ty/ bag Q’ty/ bag 10 1 - 17.0 YLP-15V 3.1 23.8 15 14 13 L JST 10 9 8 200 - 1 1 12 6 11 11 2 7 7 3 12 6 4 8 13 5 5 9 2 10 L JST 14 200 4 3.5 3 3.0 1 20.9 Q’ty/ bag 3.0 9 5 5 200 8.5 26.6 15 23.8 19.3 4 7 9 3A (5 A) - L JST 8 10 L JST 200 17.7 Q’ty/ bag 3.5 11 19.3 YLP-12V 3.1 3.0 (6 A) 12 300 V 28.3 3 6 12 4 9 200 YLR-15V 15 Q’ty/ bag 5 11 5 10 300 V YLS-12V 3.5 4 10 6 11 12 Retainer Q’ty/ bag 3 9 3.0 12 L JST 28.3 Plug housing (for socket contact) Q’ty/ bag 3.1 Retainer...Glass-filled PA 66, UL94V-0, ivory 2 8 No. of Voltage Current circuits rating rating 8.5 17.0 YLP-16V Q’ty/ bag YLS-16V Q’ty/ bag 11 3 10 2 L JST 37.3 37.0 100 200 1,000 1 1 9 9 4 7 15 12 6 14 5 5 13 6 8 16 3.5 4 12 3.0 7 37.3 8 13 L JST 14 3A (5 A) 15 300 V Q’ty/ bag 3.1 16 16 20.9 3 11 YLR-16V 26.6 2 10 3.0 17.7 3.0 8.5 12.5 26.6 20.9 11.8 2.9 RoHS2 compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2. Contact JST for Glow Wire compliant connectors. 5 YL CONNECTOR P269 Housing Material: Housing...PA 66, UL94V-0, white Receptacle housing (for pin contact) YLR-21V Q’ty/ YLP-21V bag 1 3.0 26.6 20.9 RoHS2 compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2. Contact JST for Glow Wire compliant connectors. 6 21 20 19 18 L JST 17 16 15 17.0 32.8 7 14 6 13 5 12 8 4 2 15 11 9 3 3 16 10 4 17 10 9 5 18 11 2 6 12 100 8.5 17.7 Q’ty/ bag 3.5 1 3.0 7 13 32.8 14 L JST 19 3A (5 A) 20 300 V Retainer Q’ty/ bag 3.1 21 21 Plug housing (for socket contact) 8 No. of Voltage Current circuits rating rating 200 -
YLR-04VF 价格&库存
很抱歉,暂时无法提供与“YLR-04VF”相匹配的价格&库存,您可以联系我们找货
