AZC099-04S-MS
AZC099-04S-MS
    MSKSEMI(美森科)
    SOT-23-6
    单向ESD 5V截止 峰值浪涌电流:5A
AZC099-04S-MS 数据手册
www.msksemi.com AZC099-04S-MS Semiconductor SOT-23-6 PIN Configuration Compiance MAIN APPLICATIONS USB 2.0&3.0 power and data line protection Digital video interface (DVI) Notebook computers Video graphics cards Monitors and flat panel displays 10/100/1000 ethernet SIM ports ATM interfaces PROTECTION SOLUTION TO MEET IEC61000-4-2 (ESD) ±20kV (air), ±20kV (contact) IEC61000-4-4 (EFT) 40A (5/50ns) IEC61000-4-5 (Lightning) 5A (8/20µs) ABSOLUTE MAXIMUM RATINGS (TA=25℃, RH=45%-75%, unless otherwise noted) Parameter Peak pulse power dissipation on 8/20µs waveform ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Symbol Value Unit PPP 100 W VESD +/- 20 +/-20 kV Lead soldering temperature TL 260 (10 sec.) ℃ Operating junction temperature range TJ -55 to +125 ℃ TSTG -55 to +150 ℃ Storage temperature range www.msksemi.com AZC099-04S-MS Semiconductor Compiance ELECTRICAL CHARACTERISTICS (TA=25℃) Parameter Symbol Conditions Min Typ VRWM Reverse working voltage VBR Reverse breakdown voltage IT=1mA Unit 5.0 V 6.0 Reverse leakage current IR VRWM=5V Forward voltage VF IT=10mA Clamping voltage (I/O pin to Ground) VC Junction capacitance Max V 1 µA 0.8 1.0 V IPP=1A, tP=8/20µs 9.5 11 VC IPP=5A, tP=8/20µs 12.5 15 CJ VRWM=0V, f=1MHz Any I/O pin to Ground VRWM=0V, f=1MHz Between I/O pins 0.65 0.8 0.3 0.5 V pF RATINGS AND V-I CHARACTERISTICS CURVES (TA=25℃, unless otherwise noted) FIG.1:V- I curve characteristics (Uni-directional) IF FIG.2: Pulse waveform (8/20µs) Percent of IPPM I front time: T1 = 1.25×T = 8×(1±20%)µs time to half value: T2 = 20×(1±20%)µs Peak value 100 90 Half value V VC VBR VRWM IRVF IT 50 IPP 10 0 0 FIG.3: Pulse derating curve T2 t(µs) T T1 10 20 30 40 FIG.4: ESD clamping (20kV contact) PPP derating in percentage(%) 100 Percent of I PPM 100 90 80 30ns 60 40 60ns 20 0 0 25 50 TA(℃) 75 100 125 150 175 10 0 0 t(ns) tr 0.7 to 1ns 30 60 www.msksemi.com AZC099-04S-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E1 E e e1 L θ Dimensions In Millimeters Min. Max. 1.050 1.250 0.000 0.100 1.050 1.150 0.300 0.500 0.100 0.200 2.820 3.020 1.500 1.700 2.650 2.950 0.950(BSC) 1.800 2.000 0.300 0.600 0° 8° Dimensions In Inches Min. Max. 0.041 0.049 0.000 0.004 0.041 0.045 0.012 0.020 0.004 0.008 0.111 0.119 0.059 0.067 0.104 0.116 0.037(BSC) 0.071 0.079 0.012 0.024 0° 8° REEL SPECIFICATION P/N AZC099-04S-MS PKG SOT-23-6 QTY 3000 www.msksemi.com AZC099-04S-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
AZC099-04S-MS 价格&库存
很抱歉,暂时无法提供与“AZC099-04S-MS”相匹配的价格&库存,您可以联系我们找货
