PA40-44-P64-DP
PA40-44-P64-DP
    LOGICALSYSTEMS
    ADAPTER 40-DIP ZIF & 44-PLCC
PA40-44-P64-DP 数据手册
PA40-44-P64-DP(-PP) Data Sheet 40 pin DIP socket/44 pin PLCC plug Supported Device/Footprints Adapter Construction The PA40-44-P64-DP adapter accepts 40 pin DIP devices and plugs into 44 pin PLCC production sockets. This allows DIP devices, or emulators with DIP plugs, to be used during development of PLCC based products. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. The PA40P64-DP-PP has a production socket only. Device Footprint Mfgr Device Package Device Plug Microchip PIC16C64 DIP PIC16C64 44 pin PLCC PIC16C64A PIC16C64A PIC16C65 PIC16C65 PIC16C65A PIC16C65A PIC16C74 PIC16C74 PIC16C74A PIC16C74A Adapter Dimensions When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket DIP ZIF test socket: Aries Part #: 44-6554-11 LSC Part #: 40ADZ P64-DP Accepts the test socket and remaps the signals to the PLCC plug. Test Points are available using the DIP socket pins (.020 dia. x .130 high). Adapter Wiring The following chart shows the connections from the DIP device to the adapter’s PLCC plug. PA40-44-P64-DP DEVICE SIGNAL NC 1 MCLR/Vpp 2 RA0 3 RA1 4 RA2 5 RA3 6 RA4/TOCKI 7 RA5/SS 8 RE0/RD 9 RE1/WR 10 RE2/CS 11 VDO 12 VSS 13 OSC1/CLKIN 14 OSC2/CLKOUT 15 RC0/T1CKI 16 RC1/T1CKO N/C 17 RC2/CCP1 18 RC3/SCK/SCL 19 RD0/PSP0 20 RD1/PSP1 PLUG PLUG 1 44 2 43 3 42 4 41 5 40 6 39 7 38 8 37 9 36 10 35 11 34 12 33 13 32 14 31 15 30 16 29 18 28 17 27 19 26 20 25 21 24 22 23 SIGNAL RB 7 RB 6 RB 5 RB 4 RB 3 RB 2 RB 1 RB0/INT VDO VSS RD7/PSP7 RD6/PSP6 RD5/PSP5 RD4/PSP4 RC7 N/C RC6 RC5/SDO RC4/SDI/SDA RD3/PSP3 RD2/PSP2 DEVICE 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 PA40-44-P64-DP-PP Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA40-44-P64-DP(-PP) Data Sheet Doc: 40P64DP.DOC Rev 5/5/99 Page 1 of 1
PA40-44-P64-DP 价格&库存
很抱歉,暂时无法提供与“PA40-44-P64-DP”相匹配的价格&库存,您可以联系我们找货
