PA28SO1-08-3
PA28SO1-08-3
    LOGICALSYSTEMS
    ADAPTER 28-SOIC TO 28-DIP
PA28SO1-08-3 数据手册
PAxxSO1-08(H)-s Data Sheet 14-28 pin SO socket/14-28 pin DIP 0.3"or 0.6" plug Supported Device/Footprints Adapter Construction This adapter accepts various pin count SO packages with a body width of 0.3” and lead pitch of 0.050”. The adapter DIP plug has the same pin count as the SO package. The DIP plug span is 0.3” or 0.6”. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced easily Device Dimensions This socket can accept devices of the following dimensions: When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. The following chart shows the various socket and board part numbers that make up these adapters. Body mm (inches) min. typ. max. 7.4 7.8 7.9 (0.291) (0.307) (0.311) Tip mm (inches) min. 10.0 (0.394) typ. 11.6 (0.457) max. n/a Knee mm (inches) min. typ. max. n/a 9.3 9.4 (0.366) (0.370) Body Length Lead Pitch n/a 1.27 Adapter Dimensions Adapter PA14SO1-08H-3 PA14SO1-08H-6 PA16SO1-08H-3 PA16SO1-08H-6 PA18SO1-08H-3 PA18SO1-08H-6 PA20SO1-08H-3 PA20SO1-08H-6 PA24SO1-08H-3 PA24SO1-08H-6 PA28SO1-08-3 PA28SO1-08-6 Socket 14(28H)SD-08 14(28H)SD-08 16(28H)SD-08 16(28H)SD-08 18(28H)SD-08 18(28H)SD-08 20(28H)SD-08 20(28H)SD-08 24(28H)SD-08 24(28H)SD-08 28SD-08 28SD-08 Board 28SO08-14-3 28SO08-14-6 28SO08-16-3 28SO08-16-6 28SO08-18-3 28SO08-18-6 28SO08-20-3 28SO08-20-6 28SO08-24-3 28SO08-24-6 28SO08-3 28SO08-6 DIP Plug 0.3” 0.6” 0.3” 0.6” 0.3” 0.6” 0.3” 0.6” 0.3” 0.6” 0.3” 0.6” The board is Rev F. Test Socket LSC # xx(28)SD-08 28SD-08 Style Mfgr/Pn Lidded ZIF Enplas FP-xx(28H)-1.27-08 Lidded ZIF Enplas FP-28-1.27-08 The xx(28)SD-08 sockets are depopulated from 28 pins to fit the various devices. The sockets are removable so that they may be replaced easily. They are depopulated at the Pin 1 end. If you remove the socket be sure to replace it with the hinge at the Pin 1 end. These sockets have divider fingers between the contacts. A device with fewer pins can be properly inserted in a socket with more pins. The 28 pin adapter can be used for lower pincount devices. This feature offers a cost and adapter inventory saving for those that have the time for more careful device handling. Wiring Wiring is 1 to 1. Pin 1 of the SO device is wired to pin 1 of the DIP plug. Pin 2 to pin 2 and so on around the adapter. Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PAxxSO1-08(H)-s Data Sheet Doc: SO108-B.DOC Rev 6/02/00 Page 1 of 1
PA28SO1-08-3 价格&库存
很抱歉,暂时无法提供与“PA28SO1-08-3”相匹配的价格&库存,您可以联系我们找货
