PA44-PZP
PA44-PZP
    LOGICALSYSTEMS
    PLCC
    ADAPTER 44-PLCC ZIF TO 44-PLCC
PA44-PZP 数据手册
PA44-P(Z)P Data Sheet 44 pin PLCC socket/44 pin PLCC plug Supported Device/Footprints Adapter Construction These adapters accepts 44 pin PLCC devices and plugs into 44 pin PLCC production sockets. Test points are provided near the edges of the circuit board. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. Mfgr Many Socket Device 44 pin Package PLCC Device 44 pin Plug Package PLCC When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. The adapters described by this datasheet and their subassemblies are: Adapter Test Socket Board PA44-PP 44-306 44-PP PA44-PZP 44-400 44-PZP Adapter Dimensions Test Sockets LSC # 44-306 44-400 Style Auto-Eject Lidded ZIF Mfgr/Pn Yamaichi IC120-0444-306 Yamaichi IC51-0444-400 Test Points These adapters offer Test Points. The Test Points are rows of plate-thru-holes (PTH) along the 4 edges of the adapter. Grabbers may be used to hook onto the holes. PA44-PP Alternately, 0.050” pitch 11 pin strips can be soldered into the holes and connections made to the strip’s pins. A right angle strip should be considered for easier access to the pins. Adapter Wiring This adapter is wired 1 to 1. Pin 1 of the socket is connected to pin 1 of the plug. Pin 2 to pin 2 and so on around the adapter. PA44-PZP Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA44-P(Z)P Data Sheet Doc: 44PP.DOC Rev 08/06/99 Page 1 of 1
PA44-PZP 价格&库存
很抱歉,暂时无法提供与“PA44-PZP”相匹配的价格&库存,您可以联系我们找货
