TPESD0502S6
Low Capacitance 2-Line ESD Protection
www.sot23.com.tw
Features
Mechanical Characteristics
Package: SOT23-6
ϥ IEC61000-4-2 ESD 15KV Air,8KV contact compliance
ϥ
ϥ ʳʳSmall SOT23-6L surface mount package
ϥ ʳʳ Lead Finish: Matte Tin
ϥ Protects three data lines
ϥ
UL Flammability Classification Rating 94V-0
ϥ Working voltage : 5V
ϥ
Pb-Free, Halogen Free, RoHS/WEEE Compliant
ϥ Low leakage current and low clamping voltage
ϥ Solid-state silicon avalanche technology
ϥ Lead Free/RoHS compliant
ϥ Solder reflow temperature:Pure Tin-Sn,260-270ć
ϥ Flammability rating UL 94V-0
Applications
IC
ϥ USB 2.0 interface
ϥ 10/100 Ethernet
ϥ Personal digital assistants (PDA's)
ϥ Portable instrumentation
ϥ Digital cameras
Ordering Information
Reel Size
3000
7”
TE
CH
TPESD0502S6
Qty per Reel
PU
Part Number
BL
ϥ Notebooks, Desktops and Servers
Dimensions and Pin Configuration
A
I/O1
VBUS
I/O2
I/O1
GND
I/O2
1
WWW.TECHPUBLIC.COM.TW
TPESD0502S6
www.sot23.com.tw
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter Rating
Symbol
Unit
Value
ESD voltage (HBM contact)
±8
VESD
kV
ESD voltage (AIR contact)
±15
TL
260 (10 sec.)
ć
TSTG ,TJ
-55~+150
ć
Lead soldering temperature
IC
Storage & operating temperature range
Symbol
Reverse stand-off voltage
TE
Clamping voltage (tp=8/20ȝs)
Off state junction capacitance
Typ
Max
5
Unit
V
VBR
IBR=1mA
IR
VR=5.25V
each I/O pin
1
ȝA
VC
IPP=1A
12
V
VC
IPP=5A
17
V
CJ
0Vdc,f=1MHz
Between I/O
pins and GND
CH
Min
VRWM
Reverse breakdown voltage
Reverse leakage current
Test Condition
PU
Rating
Parameter
BL
Electrical Characteristics (TA=25°C unless otherwise specified)
2
6
V
3.5
pF
TPESD0502S6
www.sot23.com.tw
PROTECTION PRODUCTS
Typical charateristics
Fig2. ESD Pulse Waveform (according to IEC 61000-4-2)
Fig1. 8/20µ s Pulse Waveform
100
100%
TEST
WAVEFORM
PARAMETERS
tr=8 s
td=20 s
Peak Value IPP
80
60
40
td=t IPP/2
10
15
30
Time (ns)
30ns
60ns
CH
Power Derating Curve
110
100
90
80
70
60
50
40
30
TE
% of Rated Power
tr = 0.7~1ns
PU
t - Time ( s)
Fig3.
10%
BL
90%
IC
tr
Percent of Peak Pulse Current %
IPP - Peak Pulse Current - % of IPP
120
50
75
100
125
150
Ambient Temperature –TA (ºC)
3
TPESD0502S6
www.sot23.com.tw
Outline Drawing - SOT23-6
A
e1
D
DIM
N
H
EI
1
E
0.25
L
e
DETAIL
A
BL
D
aaa C
A2
A
SEE DETAIL
A1
1.45
0.90
0.15
0.00
.90 1.15 1.30
0.25
0.50
0.22
0.08
2.80 2.90 3.00
1.50 1.60 1.75
2.80 BSC
0.95 BSC
1.90 BSC
0.30 0.45 0.60
(0.60)
6
0°
10°
0.10
0.20
0.20
SIDE VIEW
C A-B D
CH
bxN
bbb
A
.057
.035
.000
.006
.035 .045 .051
.010
.020
.003
.009
.110 .114 .118
.060 .063 .069
.110 BSC
.037 BSC
.075 BSC
.012 .018 .024
(.024)
6
0°
10°
.004
.008
.008
PU
C
01
(L1)
B
SEATING
PLANE
A
A1
A2
b
c
D
E1
E
e
e1
L
L1
N
01
aaa
bbb
ccc
c
GAGE
PLANE
2
ccc C
2X N/2 TIPS
H
IC
2X E/2
DIMENSIONS
MILLIMETERS
INCHES
MIN NOM MAX MIN NOM MAX
TE
Land Pattern - SOT23-6
X
DIM
(C)
G
C
G
P
X
Y
Z
Z
Y
DIMENSIONS
INCHES
MILLIMETERS
(.098)
.055
.037
.024
.043
.141
(2.50)
1.40
0.95
0.60
1.10
3.60
P
4
很抱歉,暂时无法提供与“TPESD0502S6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.68937
- 50+0.55977
- 150+0.49497
- 500+0.44637
- 3000+0.37055
- 6000+0.35100
