PA-DSO-2003-D420-20/2
    LOGICALSYSTEMS
    ADAPTER 20DIP BD W/2 20SO PLUGS
PA-DSO-2003-D420-20/2 数据手册
DIP to SO-Plug Prototyping Adapter Kits These adapters will convert a small outline land pattern to a DIP package. The adapter provides a solder down SOplug on the bottom and a detachable 300 or 600 mil wide open-frame DIP socket on the top. They are also available with optional, detachable Aries ZIF sockets. This allows an emulator or DIP device to be plugged in. We support 1.27mm pitch devices in pin counts from 8 - 44 and body sizes of 150 mil (3.8mm) - 520 mil (13.5mm). Use the searches or the manufacturer pages on our website at www.logicalsys.com to identify the correct SO-Plug for the device you are using or compare your prototype's land pattern to the recommended land patterns for each size plug. Select the kit or individual components that fit your needs. Confirm the DIP pin count and row spacing with your emulator or prototyping devices. Part number format - PA-DSO-bbbb(Z)-Dwww-pp/x bbbb (Z) www pp x Device Width 150 mil 200 mil 300 mil 330 mil 450 mil 520 mil = = = = = Board pin count (08 - 44) + width (03 or 06) Optional ZIF socket Plug width (250 – 630) Plug pin count (08 – 44) Number of plugs in kit Part Numbers to Order Pins 8 14 16 8 14 16 18 20 14 16 18 20 24 28 14 16 18 20 24 28 32 40 44 Kits with one DIP board and two plugs 300 mil wide DIP top 600 mil wide DIP top (optional ZIF socket) (optional ZIF socket) PA-DSO-0803-D250-08/2 N/A PA-DSO-1403(Z)-D250-14/2 N/A PA-DSO-1603(Z)-D250-16/2 N/A PA-DSO-0803-D310-08/2 N/A PA-DSO-1403(Z)-D310-14/2 N/A PA-DSO-1603(Z)-D310-16/2 N/A PA-DSO-1803(Z)-D310-18/2 N/A PA-DSO-2003(Z)-D310-20/2 N/A PA-DSO-1403(Z)-D420-14/2 N/A PA-DSO-1603(Z)-D420-16/2 N/A PA-DSO-1803(Z)-D420-18/2 N/A PA-DSO-2003(Z)-D420-20/2 N/A PA-DSO-2403(Z)-D420-24/2 PA-DSO-2406(Z)-D420-24/2 PA-DSO-2803(Z)-D420-28/2 PA-DSO-2806(Z)-D420-28/2 PA-DSO-1403(Z)-D470-14/2 N/A PA-DSO-1603(Z)-D470-16/2 N/A PA-DSO-1803(Z)-D470-18/2 N/A PA-DSO-2003(Z)-D470-20/2 N/A PA-DSO-2403(Z)-D470-24/2 PA-DSO-2406(Z)-D470-24/2 PA-DSO-2803(Z)-D470-28/2 PA-DSO-2806(Z)-D470-28/2 N/A PA-DSO-3206(Z)-D560-32/2 N/A PA-DSO-4006(Z)-D560-40/2 N/A PA-DSO-4406(Z)-D630-40/2 Extra Boards Open frame socket Open frame socket (ZIF socket) (ZIFsocket) PA-DSO-0803 N/A PA-DSO-1403(Z) N/A PA-DSO-1603(Z) N/A PA-DSO-0803 N/A PA-DSO-1403(Z) N/A PA-DSO-1603(Z) N/A PA-DSO-1803(Z) N/A PA-DSO-2003(Z) N/A PA-DSO-1403(Z) N/A PA-DSO-1603(Z) N/A PA-DSO-1803(Z) N/A PA-DSO-2003(Z) N/A PA-DSO-2403(Z) PA-DSO-2406(Z) PA-DSO-2803(Z) PA-DSO-2806(Z) PA-DSO-1403(Z) N/A PA-DSO-1603(Z) N/A PA-DSO-1803(Z) N/A PA-DSO-2003(Z) N/A PA-DSO-2403(Z) PA-DSO-2406(Z) PA-DSO-2803(Z) PA-DSO-2806(Z) N/A PA-DSO-3206(Z) N/A PA-DSO-4006(Z) N/A PA-DSO-4406(Z) Extra Plugs Packages of six PA-SOF-D250-08/6 PA-SOF-D250-14/6 PA-SOF-D250-16/6 PA-SOF-D310-08/6 PA-SOF-D310-14/6 PA-SOF-D310-16/6 PA-SOF-D310-18/6 PA-SOF-D310-20/6 PA-SOF-D420-14/6 PA-SOF-D420-16/6 PA-SOF-D420-18/6 PA-SOF-D420-20/6 PA-SOF-D420-24/6 PA-SOF-D420-28/6 PA-SOF-D470-14/6 PA-SOF-D470-16/6 PA-SOF-D470-18/6 PA-SOF-D470-20/6 PA-SOF-D470-24/6 PA-SOF-D470-28/6 PA-SOF-D560-32/6 PA-SOF-D560-40/6 PA-SOF-D630-44/6 SO-Plug Dimension Drawings Device Width & Part Numbers Lead Span 150 mil Plug six-pack part numbers PA-SOF-D250-08/6 PA-SOF-D250-14/6 PA-SOF-D250-16/6 1 Footprint SO-Plug Dimension Drawings Device Width & Part Numbers Lead Span Footprint 200 mil Plug six-pack part numbers PA-SOF-D310-08/6 PA-SOF-D310-14/6 PA-SOF-D310-16/6 PA-SOF-D310-18/6 PA-SOF-D310-20/6 300 mil Plug six-pack part numbers PA-SOF-D420-14/6 PA-SOF-D420-16/6 PA-SOF-D420-18/6 PA-SOF-D420-20/6 PA-SOF-D420-24/6 PA-SOF-D420-28/6 330 mil Plug six-pack part numbers PA-SOF-D470-14/6 PA-SOF-D470-16/6 PA-SOF-D470-18/6 PA-SOF-D470-20/6 PA-SOF-D470-24/6 PA-SOF-D470-28/6 450 mil Plug six-pack part numbers PA-SOF-D560-32/6 PA-SOF-D560-40/6 520 mil Plug six-pack part numbers PA-SOF-D630-44/6 DIP Board Dimensions Part Numbers 8 - 28 pins 300 mil wide 24 – 44 pins 600 mil wide Part Numbers 300 mil board part numbers 600 mil board part numbers PA-DSO-0803 PA-DSO-1403 PA-DSO-1603 PA-DSO-1803 PA-DSO-2003 PA-DSO-2403 PA-DSO-2803 PA-DSO-2406 PA-DSO-2806 PA-DSO-3206 PA-DSO-4006 PA-DSO-4006 2
PA-DSO-2003-D420-20/2 价格&库存
很抱歉,暂时无法提供与“PA-DSO-2003-D420-20/2”相匹配的价格&库存,您可以联系我们找货
  • 1+304.403051+39.45643
