PA-DSO-2806Z-D420-28/2 数据手册
DIP to SO-Plug Prototyping Adapter Kits
These adapters will convert a small outline land pattern to a DIP package. The adapter provides a solder down SOplug on the bottom and a detachable 300 or 600 mil wide open-frame DIP socket on the top. They are also available
with optional, detachable Aries ZIF sockets. This allows an emulator or DIP device to be plugged in. We support
1.27mm pitch devices in pin counts from 8 - 44 and body sizes of 150 mil (3.8mm) - 520 mil (13.5mm).
Use the searches or the manufacturer pages on our website at www.logicalsys.com to identify the correct SO-Plug for
the device you are using or compare your prototype's land pattern to the recommended land patterns for each size
plug. Select the kit or individual components that fit your needs. Confirm the DIP pin count and row spacing with your
emulator or prototyping devices.
Part number format - PA-DSO-bbbb(Z)-Dwww-pp/x
bbbb
(Z)
www
pp
x
Device
Width
150 mil
200 mil
300 mil
330 mil
450 mil
520 mil
Board pin count (08 - 44) + width (03 or 06)
Optional ZIF socket
Plug width (250 – 630)
Plug pin count (08 – 44)
Number of plugs in kit
Part Numbers to Order
Pins
8
14
16
8
14
16
18
16
18
28
14
16
18
28
32
40
44
Kits with one DIP board and two plugs
300 mil wide DIP top
600 mil wide DIP top
(optional ZIF socket)
PA-DSO-0803-D250-08/2
N/A
PA-DSO-1403(Z)-D250-14/2 N/A
PA-DSO-1603(Z)-D250-16/2 N/A
PA-DSO-0803-D310-08/2
N/A
PA-DSO-1403(Z)-D310-14/2 N/A
PA-DSO-1603(Z)-D310-16/2 N/A
PA-DSO-1803(Z)-D310-18/2 N/A
PA-DSO-2003(Z)-D310-20/2 N/A
PA-DSO-1403(Z)-D420-14/2 N/A
PA-DSO-1603(Z)-D420-16/2 N/A
PA-DSO-1803(Z)-D420-18/2 N/A
PA-DSO-2003(Z)-D420-20/2 N/A
PA-DSO-2403(Z)-D420-24/2 PA-DSO-2406(Z)-D420-24/2
PA-DSO-2803(Z)-D420-28/2 PA-DSO-2806(Z)-D420-28/2
PA-DSO-1403(Z)-D470-14/2 N/A
PA-DSO-1603(Z)-D470-16/2 N/A
PA-DSO-1803(Z)-D470-18/2 N/A
PA-DSO-2003(Z)-D470-20/2 N/A
PA-DSO-2403(Z)-D470-24/2 PA-DSO-2406(Z)-D470-24/2
PA-DSO-2803(Z)-D470-28/2 PA-DSO-2806(Z)-D470-28/2
N/A
PA-DSO-3206(Z)-D560-32/2
N/A
PA-DSO-4006(Z)-D560-40/2
N/A
PA-DSO-4406(Z)-D630-40/2
Extra Boards
Open frame socket
Open frame socket
(ZIF socket)
(ZIFsocket)
PA-DSO-0803
N/A
PA-DSO-1403(Z)
N/A
PA-DSO-1603(Z)
N/A
PA-DSO-0803
N/A
PA-DSO-1403(Z)
N/A
PA-DSO-1603(Z)
N/A
PA-DSO-1803(Z)
N/A
PA-DSO-2003(Z)
N/A
PA-DSO-1403(Z)
N/A
PA-DSO-1603(Z)
N/A
PA-DSO-1803(Z)
N/A
PA-DSO-2003(Z)
N/A
PA-DSO-2403(Z)
PA-DSO-2406(Z)
PA-DSO-2803(Z)
PA-DSO-2806(Z)
PA-DSO-1403(Z)
N/A
PA-DSO-1603(Z)
N/A
PA-DSO-1803(Z)
N/A
PA-DSO-2003(Z)
N/A
PA-DSO-2403(Z)
PA-DSO-2406(Z)
PA-DSO-2803(Z)
PA-DSO-2806(Z)
N/A
PA-DSO-3206(Z)
N/A
PA-DSO-4006(Z)
N/A
PA-DSO-4406(Z)
Extra Plugs
Packages of six
PA-SOF-D250-08/6
PA-SOF-D250-14/6
PA-SOF-D250-16/6
PA-SOF-D310-08/6
PA-SOF-D310-14/6
PA-SOF-D310-16/6
PA-SOF-D310-18/6
PA-SOF-D310-20/6
PA-SOF-D420-14/6
PA-SOF-D420-16/6
PA-SOF-D420-18/6
PA-SOF-D420-20/6
PA-SOF-D420-24/6
PA-SOF-D420-28/6
PA-SOF-D470-14/6
PA-SOF-D470-16/6
PA-SOF-D470-18/6
PA-SOF-D470-20/6
PA-SOF-D470-24/6
PA-SOF-D470-28/6
PA-SOF-D560-32/6
PA-SOF-D560-40/6
PA-SOF-D630-44/6
SO-Plug Dimension Drawings
Device Width & Part Numbers
Lead Span
150 mil
Plug six-pack part numbers
PA-SOF-D250-08/6
PA-SOF-D250-14/6
PA-SOF-D250-16/6
1
Footprint
Lead Span
Footprint
200 mil
PA-SOF-D310-08/6
PA-SOF-D310-14/6
PA-SOF-D310-16/6
PA-SOF-D310-18/6
PA-SOF-D310-20/6
300 mil
PA-SOF-D420-14/6
PA-SOF-D420-16/6
PA-SOF-D420-18/6
PA-SOF-D420-20/6
PA-SOF-D420-24/6
PA-SOF-D420-28/6
330 mil
PA-SOF-D470-14/6
PA-SOF-D470-16/6
PA-SOF-D470-18/6
PA-SOF-D470-20/6
PA-SOF-D470-24/6
PA-SOF-D470-28/6
450 mil
PA-SOF-D560-32/6
PA-SOF-D560-40/6
520 mil
PA-SOF-D630-44/6
DIP Board Dimensions
Part Numbers
8 - 28 pins
300 mil wide
24 – 44 pins
600 mil wide
Part Numbers
300 mil board
part numbers
600 mil board
part numbers
PA-DSO-0803
PA-DSO-1403
PA-DSO-1603
PA-DSO-1803
PA-DSO-2003
PA-DSO-2403
PA-DSO-2803
PA-DSO-2406
PA-DSO-2806
PA-DSO-3206
PA-DSO-4006
PA-DSO-4006
2
PA-DSO-2806Z-D420-28/2 价格&库存
很抱歉,暂时无法提供与“PA-DSO-2806Z-D420-28/2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+587.295291+76.32052
