PA-SOD-2006-08
PA-SOD-2006-08
    LOGICALSYSTEMS
    SOIC
    ADAPTER 8-SOIC TO 8-SOIC
PA-SOD-2006-08 数据手册
PA-SOD-2006-xx Data Sheet 8-20 pin SO socket/20 pin SO receptacle (SO-Plugs NOT included) Supported Device/Footprints Adapter Construction Using this adapter, various pin count SO packages with a body width of 4.9mm - 5.4mm and lead pitch of 1.27mm can be socketed over their PCB footprints. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. Device Dimensions When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. This socket can accept devices of the following dimensions: The following chart lists the adapters described by this datasheet and their subassemblies. Adapter Test Socket Board PA-SOD-2006-20 20SD-06 20SOD06 PA-SOD-2006-18 18(20)SD-06 20SOD06 PA-SOD-2006-16 16(20)SD-06 20SOD06 PA-SOD-2006-14 14(20)SD-06 20SOD06 PA-SOD-2006-08 08(20)SD-06 20SOD06 Body mm (inches) min. typ. 4.9 5.3 (0.193) (0.208) Tip mm (inches) min. typ. 7.65 7.8 (0.301) (0.307) max. 5.4 (0.213) max. n/a Knee mm (inches) min. typ. n/a 6.8 (0.268) Body Length n/a max. 7.1 (0.279) Lead Pitch 1.27 (0.050) Adapter Dimensions Test Sockets LSC # 20SD-06 xx(20)SD-06 Style Lidded ZIF Lidded ZIF Mfgr/Pn Enplas FP-20-1.27-06 Enplas FP-xx(20H)-1.27-06 Notes 1. The xx(20)SD-06 sockets are depopulated 20SD-06 sockets. A “dam” is added to prevent incorrect alignment of the device. 2. The 20 pin version can be used for the reduced pin counts. The test socket has divider fingers that keep the device leads on their contacts. With modest care a reduced pin count device can be correctly aligned in the 20 pin test socket. 3. For all versions of the adapter, the board provides 20 positions to receive the SO-Plug. When using plugs with less than 20 pins orient the plug and the device, away from the pin 1 end of the board. Wiring Wiring is 1 to 1. Pin 1 of the SO device is wired to pin 1 of the plug. Pin 2 to pin 2 and so on around the adapter. SO Plugs SO Plugs are required to connect this adapter to the prototype. They are available separately. The two most common plugs are shown in the following chart. Other SO-Plugs will also mate with this adapter, contact us if you want assistance matching plugs to this adapter. Plug Kit PA-SOF-D250-xx PA-SOF-D310-xx A 0.310" 0.270" B 0.250" 0.310" Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA-SOD-2006-xx Data Sheet Doc: SOD2006.DOC Rev 01/11/00 Page 1 of 1
PA-SOD-2006-08 价格&库存
很抱歉,暂时无法提供与“PA-SOD-2006-08”相匹配的价格&库存,您可以联系我们找货
