PA28-28
PA28-28
    LOGICALSYSTEMS
    ADAPTER 28-PLCC TO 28-DIP
PA28-28 数据手册
PA28-28(Z) Data Sheet 28 pin PLCC socket/28 pin DIP 0.6” plug Supported Device/Footprints Adapter Construction This adapter allows programming of several PLCC and CLCC devices in their DIP footprint. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. Following is a partial list: Mfgr Several " " " " " " " " " " " " " " Device Device 87C752 EPB2002 CY7330 CY7331 CY7332 CY7C361 CY7C344 29PL141 PLS100 PLS101 PLS103 PLS104 PLS105 PLS105/A PLUS405 Footprint Package Device Plug PLCC 87C752 28 Pin DIP " EPB2002 " " CY7330 " " CY7331 " " CY7332 " " CY7C361 " " CY7C344 " " 29PL141 " " PLS100 " " PLS101 " " PLS103 " " PLS104 " " PLS105 " " PLS105/A " " PLUS405 " Adapter Dimensions PA28-28 When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket PLCC Auto-Eject test socket: Yamaichi Part #: IC120-0284-508 PLCC Lidded ZIF socket: Yamaichi Part #: IC51-0284-399 LSC Part #: 28-508 LSC Part #: 28-399 PA28-28(Z) Connects the PLCC pinout to the DIP footprint. Adapter Wiring The following chart shows the connections from the PLCC device to the adapter’s DIP plug. DEVICE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PLUG 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PA28-28Z Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA28-28(Z) Data Sheet Doc: PA2828.DOC Rev 9/7/98 Page 1 of 1
PA28-28 价格&库存
很抱歉,暂时无法提供与“PA28-28”相匹配的价格&库存,您可以联系我们找货
