PA20QS-OT
PA20QS-OT
    LOGICALSYSTEMS
    ADAPTER20-QSOPTO20-DIP
PA20QS-OT 数据手册
PAxxQS-OT Data Sheet 20-24 pin QSOP socket/20-24 pin DIP 0.6” plug Supported Device/Footprints Adapter Construction Using this adapter QSOP packaged devices can be programmed on programmers with DIP sockets in the device’s DIP footprint. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. Cypress Semiconductor offers programmable logic device in the 20 and 24 pin QSOP packages. Some of the devices are 16L8, 16R4, 16R6, 16R8, 16V8 and 22V10. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. This adapter accepts packages with the dimensions listed below: Test Socket Wells Part #: 656-4242011 or 656-4242211 LSC Part #: 20QSH-W or 24QSH-W The 24 pin socket is depopulated to 20 pins to fit smaller devices. The part numbers are listed in the following chart. Body 3.9 mm (0.154”) typical Knee 4.7 mm (0.185”) typical Tip 6.0 mm (0.236”) typical Pitch 0.025" Length 8.65 mm (0.341”) typical Some of the package codes that fit this adapter are: Manufacturer 20QSOP 24QSOP JEDEC MO-137AD MO-137AE Cypress Semi. Q5 Q13 Quality Semi. PSS-20A PSS-24A Pericom Q20 Q24 Circuit Board This is a 24QS-OT board that is depopulated for the 20 pin adapter. The various part numbers for this board are listed in the following chart. Adapter Parts & Part Numbers The following chart shows the various socket and board part numbers that make us these adapters. Adapter PA20QS-OT PA24QS-OT Socket 20QSH-W 24QSH-W Board 24QS-OT-20 24QS-OT Adapter Wiring Adapter Dimensions The adapter is wired 1-1. Pin 1 of the QSOP device connects to pin 1 of the DIP plug, pin 2 to pin 2, and so on around the adapter. The PA24QS-OT is shown Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PAxxQS-OT Data Sheet Doc: 24QS-OT.DOC Rev 1/6/99 Page 1 of 1
PA20QS-OT 价格&库存
很抱歉,暂时无法提供与“PA20QS-OT”相匹配的价格&库存,您可以联系我们找货
PA20QS-OT
  • 1+953.235821+123.25936
