CMBH1005S601JSP
CMBH1005S601JSP
    CYBERMAX(思博)
CMBH1005S601JSP 数据手册
CMBH CMBH1005S 1005S Series High Current Chip Ferrite Bead ◆ Features Pb 1 、 Internal silver printed layers and magnetic shielded structures to minimize crosstalk 2、Large withstand current (allowable current:up to 6A) 3、Can be used in a wide range of frequency to suppress EMI 4、Three types material and wide range of impedance values for various applications 5、RoHS Compliant. ◆ PRODUCT IDENTIFICATION ◆ Application 1、High current DC power lines. 2、Noise suppression for power line or large current signal of electric equipments such as computers and peripheral devices, DVD cameras, LCD TVs, communication equipments, OA equipments, etc. CMBH 1005 (1) (2) S (3) 601 J (4) (5) S P (6) (7) (1) Series Type (2) Chip Size(mm):Length X Width (3) Material Code (4) Nominal Impedance:600=60Ω;601=600Ω; 102=1000Ω (5) Rated Curren :E=300mA;F=500mA;J=800mA L =1000mA; M=1500mA; N=2000mA; P=2500mA; Q=3000mA; R=4000mA; U=5000mA W=6000mA. (6) Company Code (7) Packaging:P–Embossed paper tape, 7" reel E- Embossed plastic tape, 7" reel ◆ Dimensions Size(EIA) ( ) 1005 0402 Rev.01 Unit: mm L W T E 1.00±0.10 0.50±0.10 0.50±0.10 0.250±0.10 Page 1 of 3 www.cybermaxtech.com CMBH CMBH1005S 1005S Series ◆ Specifications Impedance (Ω) Test Freq. (MHz) DCR Max. (Ω) Rated Current (mA) CMBH1005S100PSP 10±25% 100 0.050 2500 CMBH1005S300PSP 30±25% 100 0.060 2500 CMBH1005S600PSP 60±25% 100 0.070 2500 CMBH1005S900NSP 90±25% 100 0.090 2000 CMBH1005S121NSP 120±25% 100 0.095 2000 CMBH1005S221JSP 220±25% 100 0.130 1000 CMBH1005S601JSP 600±25% 100 0.340 800 CMBH1005S102FSP 1000±25% 100 0.830 500 Part Number CMBH1005S Series ◆ General Technical Data Storage Condition ℃ ~ +125℃ Less than 40℃ and 70% RH Soldering Method Reflow or Wave Soldering Operating Temperature Range -55 ◆ Recommended Soldering Conditions Rev.01 Page 2 of 3 www.cybermaxtech.com CMBH CMBH1005S 1005S Series ◆ Characteristics CMBH1005S Series CMBH1005S100PSP CMBH1005S300PSP CMBH1005S600PSP CMBH1005S900NSP CMBH1005S121NSP CMBH1005S221JSP CMBH1005S601JSP CMBH1005S102FSP ◆ Characteristics ◆ Package Size EIA (EIA) Standard Packing Quantity (pcs / reel) Rev.01 1005 1608 2012 3216 4532 (0402) (0603) (0805) (1206) (1812) 10,000 4,000 4,000 4,000 1,000 Page 3 of 3 www.cybermaxtech.com
CMBH1005S601JSP
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗的特性,适用于高速光耦合器。
3. 引脚分配:EL817有3个引脚,分别为阳极、阴极和发射极。
4. 参数特性:主要参数包括最大正向电流150mA,最大反向电压5V,最小正向电压1.0V。
5. 功能详解:EL817通过光电效应实现电信号的传输,具有隔离作用,可以保护电路不受干扰。
6. 应用信息:EL817广泛应用于数字通信、测量设备、工业控制系统等领域。
7. 封装信息:EL817采用DIP-6封装,尺寸为9.1mm x 3.6mm x 4.9mm。
CMBH1005S601JSP 价格&库存
很抱歉,暂时无法提供与“CMBH1005S601JSP”相匹配的价格&库存,您可以联系我们找货
