PA28-28-DP(-PP) Data Sheet
28 pin DIP ZIF socket/28 pin PLCC plug
Supported Device/Footprints
Adapter Construction
The PA28-28-DP adapter accepts 28 pin DIP devices and plugs
into 28 pin PLCC production sockets. This allows DIP devices or
emulators with DIP plugs to be used during development of
PLCC based products.
The adapter is made up of 3 sub-assemblies. They assemble via
connectors making the adapter modular. This way the subassemblies can be replaced when they wear out.
The PA28-28-DP-PP has a production socket only.
When disassembling the adapter take care not to bend the pins.
When reassembling the adapter note the pin 1 indicators to align
the parts correctly.
Test Socket
Aries Part #: 28-6554-11
LSC Part #: 28ADZ
Adapter Dimensions
28-28-1-DIP
Accepts the test socket and connects to the the bottom board
28PLUG
Accepts the top board and provides the PLCC Plug.
Adapter Wiring
This adapter is wired 1 to 1. The following chart shows the
connections from the DIP device to the adapter’s PLCC plug.
PA28-28-DP
PA28-28-DP-PP
S Y S T E M S
Logical Systems Corporation
PO Box 6184, Syracuse, NY 13217-6184 USA
Tel (315) 478-0722, FAX (315) 479-6753
www.logicalsys.com, Email: info@logicalsys.com
DEVICE
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
PLUG
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
23
24
25
26
27
28
Doc: 28DP.DOC
Rev 1/28/97
Page 1 of 1
很抱歉,暂时无法提供与“PA28-28-DP-PP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+898.365881+116.36980
