PA32SO1-OT
PA32SO1-OT
    LOGICALSYSTEMS
    SOIC
    SOIC PROG ADAPT FOR SOIC PKG
PA32SO1-OT 数据手册
PAxxSO1-OT Data Sheet xx pin SO Socket/xx pin DIP 0.6" plug Supported Device/Footprints Adapter Dimensions Using this adapter, the 32 and 40 pin SO EPROM packages can be programmed on DIP programmers. Device Device 32 pin 40 pin Mfgr Many " Package SO " Footprint Programmers Plug Many 40 pin DIP " " Both SOP sockets accept packages with the dimensions listed below: (The PA40SO1-OT is shown) Body 11.4mm typ 11.8 max Knee 12.4mm typ Tip 14.1mm typ 14.3 max. Pitch 1.27mm Length n/a Adapter Wiring The following chart shows the connections from the SO device to the adapter’s DIP plug. Adapter Parts & Part Numbers The following chart shows the various socket and board part numbers that make up these adapters. Adapter PA32SO1-OT PA40SO1-OT Socket 32SD-01 40SD-01 Board 32SO-01 40SO-01 Adapter Construction The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket Open top SO socket: for PA32SO1-OT: Enplas Part #: OTS-32-1.27-01 LSC Part #: 32SD-01 for PA40SO1-OT: Enplas Part #: OTS-40-1.27-01 LSC Part #: 40SD-01 32SO-01 or 40SO-01 Accepts the test socket and connects to the 32 or 40 pin DIP footprint. Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com DEVICE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 PLUG 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 On PA40SO1 -OT Only: DEVICE 33 34 35 36 37 38 39 40 PLUG 33 34 35 36 37 38 39 40 PAxxSO1-OT Data Sheet Doc: xxSO1-OT.DOC Rev 1/28/97 Page 1 of 1
PA32SO1-OT 价格&库存
很抱歉,暂时无法提供与“PA32SO1-OT”相匹配的价格&库存,您可以联系我们找货
