PA17C42-PD
PA17C42-PD
    LOGICALSYSTEMS
    ADAPTER 44-PLCC TO 40-DIP
PA17C42-PD 数据手册
PA17C42-PD(Z) Data Sheet 44 pin PLCC socket/40 pin DIP 0.6” plug Supported Device/Footprints Adapter Parts & Part Numbers This adapter allows programming of Microchip's PIC17C42, '43 & '44 in the 44 pin PLCC package on 40 pin DIP programmers. The following chart shows the various socket and board part numbers that make up these adapters. Mfgr Microchip " " " Device Device Package PIC17C42 44 PLCC PIC17C42A " PIC17C43 " PIC17C44 " Footprint Device Plug PIC17C42 40 Pin DIP PIC17C42A " PIC17C43 " PIC17C44 " Adapter PA17C42-PD PA17C42-PDZ Test Socket 44-306 44-400 Circuit Board P42-PD P42-PZD Adapter Wiring The following chart shows the connections from the PLCC device to the adapter’s DIP plug. Adapter Construction The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket PLCC Auto-Eject test socket: Yamaichi Part #: IC120-0444-306 ZIF Lidded socket: Yamaichi Part #: IC51-0444-400 LSC Part #: 44-306 LSC Part #: 44-400 PA42-P(Z)D Accepts the test socket and remaps the signals to the DIP plug. Adapter Dimensions PA17C42-PD Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PLCC 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 SIGNAL Vdd RC0/AD0 RC1/AD1 RC2/AD2 RC3/AD3 RC4/AD4 RC5/AD5 RC6/AD6 RC7/AD7 Vss Vss RB0/CAP1 RB1/CAP2 RB2/PWM1 RB3/PWM2 RB4/TCLK12 RB5/TCLK3 RB6 RB7 OSC1 OSC2/CLKOUT DIP 1 N/C 2 3 4 5 6 7 8 9 10 10 11 12 13 14 15 16 17 18 19 20 DIP 1 40 39 38 37 36 35 34 33 32 31 31 30 29 28 27 26 25 24 23 22 21 SIGNAL Vdd RD0/AD8 RD1/AD9 RD2/AD10 RD3/AD11 RD4/AD12 RD5/AD13 RD6/AD14 RD7/AD15 MCLR/Vpp Vss Vss RE0/ALE RE1/OE RE2/WR TEST RA0/INT RA1/RT RA2 RA3 RA4/RX/DT RA5/TX/CK PLCC 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 PA17C42-PZD PA17C42-PD(Z) Data Sheet Doc: 17C42-PD.DOC Rev 5/11/99 Page 1 of 1
PA17C42-PD 价格&库存
很抱歉,暂时无法提供与“PA17C42-PD”相匹配的价格&库存,您可以联系我们找货
