PA28-PP
PA28-PP
    LOGICALSYSTEMS
    PLCC
    ADAPTER 28-PLCC TO 28-PLCC
PA28-PP 数据手册
PA28-P(Z)P Data Sheet 28 pin PLCC socket/28 pin PLCC plug Supported Device/Footprints Adapter Construction The PA28-PP adapter accepts 28 pin PLCC devices and plugs into 28 pin PLCC production sockets. The adapter is made up of 3 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. Mfgr Many Socket Device 28 pin Package PLCC Device 28 pin Plug Package PLCC When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket Auto-eject test socket: Yamaichi Part #: IC120-0284-508 Lidded ZIF test socket: Yamaichi Part #: IC51-0284-399 Adapter Dimensions LSC Part #: 28-508 LSC Part #: 28-399 28LIF or 28PLZ Accepts the test socket and connects to the the bottom board. 28PLUG Connects to the top board and remaps the pins to the PLCC plug. Adapter Wiring This adapter is wired 1 to 1. The following chart shows the connections from the PLCC device to the adapter’s PLCC plug. PA28-PP PA28-PZP Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com DEVICE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PLUG 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 PA28-P(Z)P Data Sheet Doc: 28PZP-N.DOC Rev 3/11/97 Page 1 of 1
PA28-PP 价格&库存
很抱歉,暂时无法提供与“PA28-PP”相匹配的价格&库存,您可以联系我们找货
