VL CONNECTOR
6.2mm pitch/Disconnectable Crimp style Wire-to-wire connectors
(Combined use for both wire-to-wire and wire-to-board connections)
Specifications –––––––––––––––––––
This VL connector is 6.2 mm pitch wire-to-wire
and wire-to-board connector, designed for
large current up to 20 A (1 or 2-circuit with
3.5 mm2 wire). Secondary retainer, which
prevents from insufficient insertion of contact
and coming off contact, may use and large
current circuit can be connected certainly and
safety.
• Housing lances
• Retainer
• Suited for large carrent
• Panel lock
Standards ––––––––––––––––––––
Recognized E60389
1 Certified LR20812
2R9351103
• Current rating: 20 A AC, DC max. (Refer to the following table.)
• Voltage rating: 600 V AC, DC max.
• Temperature range: -25˚C to +90˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 7 mΩ max.
After environmental tests/ 10 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 2,000 VAC/minute
• Applicable wire: AWG #22 to #12
0.3 to 3.5 mm2
• Applicable panel thickness: 0.5 to 2.0 mm
* In using the products, refer to "Handling Precaution for Terminal
and Connector" described on our website (Technical documents
of Product information page).
* Contact JST for details.
* RoHS2 compliance
Note: The current rating varies depending on the number of circuits and the wire
size used in each connector. The table below lists the current rating as a
function of the number of circuits and the wire size.
Current unit: A
No. of
circuits
1
2
3
4
6
8
12
#12
#14
18
16
16
15
15
15
14
13
12
11
10
Wire size (AWG)
#16
#18
10
10
9
9
8
7
7
#20
#22
6
6
6
6
5
5
4
4
4
4
4
3
3
3
8
8
8
7
7
6
6
Inner-housing lock
Inner-housing lock
12.2
19.3
(including retainer)
Panel layout and Assembly layout
40.5
40.5
44.1 (including retainer)
Outer-housing lock
14.6
21.7
Outer-housing lock
40.5
40.5
Shape I
Shape II
9.8±0.13
B
18.6±0.13
C
E
D
2
12.2±0.13
C
E
A
0.5±0.13
4.2±0.13
No. of
circuits
D
9.8
±0.13
3
4
4
(Single-row)
6
A
8
B
12
Receptacle
housing
Model No.
VLR-02V
VLR-03V
VLR-04V
VLR-04VN
VLR-06V
VLR-08V
VLR-12V
Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed.
2. The strength of the panel must be considered when punching two or more holes.
3. The connector must be inserted from the same side as the hole is punched.
1
Panel hole dimensions (mm)
General tolerance
Panel
hole
shape
A
B
C
D
E
1
13.8
20.6
5.7
8.5
1.4
1
20.0
26.8
5.7
8.5
1.4
2
13.8
20.6
7.0
15.4
4.2
1
26.2
33.0
5.7
8.5
1.4
2
20.0
26.8
7.0
15.4
4.2
2
26.2
33.0
7.0
15.4
4.2
2
38.9
45.4
7.0
15.4
4.2
A, B, D: 0.13 C, E: 0.1
Applicable
panel
thickness (mm)
0.5∼2.0
VL CONNECTOR
Contact
Applicable wire
mm2
AWG #
Model No.
Pin contact
Socket contact
Pin contact
SVF-42T-P2.0
SVM-61T-P2.0
SVF-61T-P2.0
SVM-81T-P2.0
SVF-81T-P2.0
4.1
3.2
TSJ
22.2
3.6
2
0.3∼1.25
22∼16
1.7∼3.2
0.3+0.3∼
0.5+0.75
22+22∼
20+18
1.7+1.7∼
2.5+2.7
0.5∼2.0
20∼14
1.9∼3.4
0.5+0.5∼
0.75+1.25
20+20∼
18+16
1.9+1.9∼
2.1+2.7
3.5
12
4.1
Q'ty/
reel
2,000
3.1
1.7
SVM-42T-P2.0
Insulation
O.D. (mm)
2
Material and Finish
Phosphor bronze, tin-plated (reflow treatment)
Socket contact
4.1
TSJ
RoHS2 compliance
Note: Contact JST for special products.
SVM-42T-P2.0
16.7
3.6
2
1.7
SVM-61T-P2.0
MKS-L
AP-K2N
Crimp applicator with dies
MK/SVF/M-42-20 APLMK SVF/M42-20
MKS-L
SVF-42T-P2.0
SVF-61T-P2.0
3.1
Applicator
Dies
Crimping
machine Crimp applicator
Contact
MK/SVF/M-61-20 APLMK SVF/M61-20
SVM-81T-P2.0
MKS-L
SVF-81T-P2.0
MK/SVF/M-81-20 APLMK SVF/M81-20
Note: Contact JST for fully automatic crimping applicator.
Contact position location numbers
Retainer
Retainer
Contact position numbers are stamped
Receptacle housing
Plug housing
Receptacle housing
5
4
9
3
8
2
7
1
12
11
10
9
8
7
L JST
10
1
5
L JST
11
2
6
L JST
4
3
2
1
6
12
L JST
1
4
1
8
7
6
5
3
7
2
2
1
6 3
5 2
4 1
4
3
5
L JST
1
3
1
L JST
6
3
2
L JST
L JST
4 2
3 1
8
4
2
4
3
2
1
3
2
1
2
1
4
3
2
1
6
5
4
3
2
1
Plug housing
L JST
3
2
4
2 4
1 3
L JST
4
3
2
1
12
11
8
7
9
L JST
10
5
4
3
8
7
6
5
2
L JST
6
1
5
L JST
4
3
2
1
1
8
7
4
3
3 6
2 5
1 4
2
6
5
3
4
L JST
12
11
10
9
8
7
2
10
9
8
1
7
L JST
6
5
4
3
2
1
1
12
11
6
5
4
3
5
8
7
6
5
2
8
7
6
L JST
3
4
5
4
2
1
6
3
2
1
L JST
3 6
2 5
1 4
4
3
2
1
6
1
1
1
3
2
3
2
1
3
L JST
2
1
2
L JST
2
L JST
4
2
2 4
1 3
1
1
3
2
JST
2
1
1
3
3
2
1
L
2
L JST
1
1
4
L JST
6
5
4
3
2
1
12
11
10
9
8
7
L JST
2
VL CONNECTOR
Housing
Material: Housing...PA 66, UL94V-0, white
Retainer...Glass-filled PA 66, UL94V-0, ivory
No. of Voltage Current
rating
circuits rating
Receptacle housing (for pin contact)
20A
Q'ty/
bag
VLS-01V
Q'ty/
bag
500
9.2
3
Q'ty/
bag
11
2.8
7.3
VLP-02V
Q'ty/
bag
L JST
13.4
2
L JST
13.4
1,000
500
9.4
2
3.4
VLR-02V
13
29.5
6.2
600V
VLP-01V
7.2
1
Q'ty/
bag
Retainer
7.2
VLR-01VF (Without panel lock product)
Plug housing (for socket contact)
9.4
VLS-02V
(commonly used for
2-circuit housing and
4-circuit housing)
Q'ty/
bag
1
1
13
20A
8.2
11
2.8
8.4
29.5
3
500
VLP-02V-1
500
9.4
1
L JST
15
L JST
2
13.4
1,000
5.9
2
VLR-02VF (Without panel lock product)
11.4
600V
3.4
2
1
8.2
13
29.5
3
Q'ty/
bag
5.2
8.4
Q'ty/
bag
VLP-03V
Q'ty/
bag
2
JST
1
L
3.4
VLS-03V
(commonly used for
3-circuit housing and
6-circuit housing)
19.6
3
VLR-03V
11
3
11
2.8
8.4
VLP-03V-1
500
1,000
29.5
19.6
3
5.9
9.4
1
8.2
2
L JST
3.4
3
1
500
17.6
19A
2
L JST
600V
19.6
13
3
13
5.2
8.4
VLP-04V
Q'ty/
bag
VLS-02V
Q'ty/
bag
3
1
13.4
2
4
13.4
2
4
Q'ty/
bag
3.4
VLR-04V
11
1
3
L JST
L JST
2.8
15.4
11.4
3
15
11
29.5
500
VLP-04V-1
500
3
13.4
1
L JST
1
L JST
15
3
13
29.5
VLR-04VN
5.2
15.4
VLP-04VN-1
Q'ty/
bag
VLS-08V
(commonly used for
4-circuit housing and
8-circuit housing)
500
Q'ty/
bag
4
3.4
Q'ty/
bag
11
23.8
18A
3
600V
9.4
15
2
4
4
1,000
5.9
2
VLR-04VF (Without panel lock product)
4
3.4
13
25.8
2
L JST
25.8
3
L JST
3
4
2
500
3.4
1
1
13
8.2
3
RoHS2 compliance
Note: 1. Contact JST for special products.
2. Contact JST for Glow Wire compliant connectors.
3
29.5
11
5.2
8.4
5.9
9.4
1,000
VL CONNECTOR
Housing
Voltage
rating
Current
rating
VLR-06V
VLP-06V
Q'ty/
bag
5
VLS-03V
(commonly used for
6-circuit housing)
Q'ty/
bag
4
1
3.4
2
6
3
Q'ty/
bag
Retainer
19.6
No. of
circuits
L JST
2.8
15.4
17.6
19.6
11
2
16A
5
600V
3
6
6
13
500
VLP-06V-1
500
1,000
1
4
6
5.9
9.4
1
4
5
29.5
2
3
15
19.6
3.4
3
L JST
13
L JST
15.4
VLP-08V
Q'ty/
bag
7
VLS-08V
(commonly used for
8-circuit housing)
6
1
5
2
3.4
L JST
3
8
Q'ty/
bag
4
Q'ty/
bag
5.2
25.8
VLR-08V
11
L JST
4
8
25.8
16A
15.4
L JST
600V
2.8
3
7
8
11
23.8
13
6
2
100
200
VLP-08V-1
1,000
1
5
7
5.9
L JST
29.5
9.4
1
5
2
6
3
15
25.8
3
3.4
4
8
L JST
13
L JST
15.4
VLP-12V
11
10
5
8
9
L JST
4
2
3
3.4
7
1
L JST
11
2.8
36.2
3
15.4
100
VLP-12V-1
1,000
100
2
8
12
11
5.9
10
29.5
8
2
RoHS2 compliance
11
5.2
7
1
13
9.4
9
L JST
4
3
3
15
38.2
3.4
6
1
7
5
38.2
4
9
13
L JST
10
15A
5
11
600V
Q'ty/
bag
6
12
12
VLS-12V
12
Q'ty/
bag
6
Q'ty/
bag
5.2
38.2
VLR-12V
11
15.4
4
很抱歉,暂时无法提供与“VLR-04VN”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.142371+0.40793
- 50+2.9604450+0.38432
- 100+2.43947100+0.31669
- 300+2.10043300+0.27267
- 500+2.02600500+0.26301
- 1000+1.976391000+0.25657
- 4000+1.935044000+0.25120
