PA40-44-01-DP-PP
PA40-44-01-DP-PP
    LOGICALSYSTEMS
    ADAPTER 40-DIP TO 44-PLCC
PA40-44-01-DP-PP 数据手册
PA40-44-01-DP(-PP) Data Sheet 40 pin DIP socket/44 pin PLCC plug Supported Device/Footprints Adapter Construction These adapters accept 40 pin DIP devices and plugs into 44 pin PLCC production sockets. They allow DIP devices, or emulators with DIP plugs, to be used during development of PLCC based products. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be easily replaced. The following DIP devices footprint are converted to the indicated PLCC footprint. Zilog: Z86C21/ E21/ C61/ E61 Footprint: Same device 44PLCC Other devices that require the same wiring would also be supported. Adapter Dimensions The following chart lists the adapters described by this datasheet and their subassemblies. Adapter Test Top Bottom Socket Board Board PA40-44-01-DP 40-ADZ * 44-40-01-DIP 44PLUG PA40-44-01-DP-PP none * 44-40-01-DIP 44PLUG * The top board always has a 40 pin DIP production socket. The optional test socket plugs into the production socket. Test Sockets LSC # 40ADZ Style DIP ZIF Mfgr/Pn Aries 40-6554-11 When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Points are available using the two rows of header pins. Adapter Wiring The following chart shows the connections from the DIP device to the adapter’s PLCC plug. PA40-44-01-DP PA40-44-01-DP-PP Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com DIP Socket 1 2 3 4 5 N/C 6 7 8 9 10 11 12 13 14 15 N/C 16 17 18 19 20 PLCC Plug 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 PLCC Plug 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 DIP Socket 40 39 38 37 36 N/C 35 34 33 32 31 30 29 28 27 26 N/C 25 24 23 22 21 Skip and short notation: (6, 17, 28, 39) PA40-44-01-DP(-PP) Data Sheet Doc: 404401DP.DOC Rev 02/08/00 Page 1 of 1
PA40-44-01-DP-PP 价格&库存
很抱歉,暂时无法提供与“PA40-44-01-DP-PP”相匹配的价格&库存,您可以联系我们找货
