PA40-44-33-DP-PP
PA40-44-33-DP-PP
    LOGICALSYSTEMS
    ADAPTER 40-DIP TO 44-PLCC
PA40-44-33-DP-PP 数据手册
PA40-44-33-DP(-PP) Data Sheet 40 pin DIP socket/44 pin PLCC plug Supported Device/Footprints Adapter Construction These adapters accept 40 pin DIP devices and plugs into 44 pin PLCC production sockets. They allow DIP devices, or emulators with DIP plugs, to be used during development of PLCC based products. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be easily replaced. The following DIP devices footprint are converted to the indicated PLCC footprint. Zilog: Z86E30/ E31/ E33/ 733/ E34/ E40/E43/743/E44 Footprint: Same device 44PLCC Other devices that require the same wiring would also be supported. Adapter Dimensions The following chart lists the adapters described by this datasheet and their subassemblies. Adapter Test Top Bottom Socket Board Board PA40-44-33-DP 40-ADZ * 44-40-33-DIP 44PLUG PA40-44-33-DP-PP none * 44-40-33-DIP 44PLUG * The top board always has a 40 pin DIP production socket. The optional test socket plugs into the production socket. Test Sockets LSC # 40ADZ Style DIP ZIF Mfgr/Pn Aries 40-6554-11 When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Points are available using the two rows of header pins. Adapter Wiring The following chart shows the connections from the DIP device to the adapter’s PLCC plug. PA40-44-33-DP DEVICE 1 2 3 4 5 6 7 8 9 10 11 11 12 13 14 15 16 17 18 19 20 SIGNAL NC R/WP25 P26 P27 P04 P05 P06 P14 P15 P07 VCC VCC P16 P17 XTAL2 XTAL1 P31 P32 P33 P34 AS- PLUG 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 PLUG 34 35 36 37 38 39 40 41 42 43 44 1 2 3 4 5 6 7 8 9 10 11 SIGNAL R/RLRST P35 P37 P36 P30 P00 P01 P10 P11 P02 GND GND P12 P13 P03 P20 P21 P22 P23 P24 DS- DEVICE 21 22 23 24 25 26 27 28 29 30 31 31 32 33 34 35 36 37 38 39 40 Skip short notation: 1, 12, 23, 34 (1-2), (23-24)PLCC rotated CCW (+11). PA40-44-33-DP-PP Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA40-44-33-DP(-PP) Data Sheet Doc: 404433DP.DOC Rev 02/08/00 Page 1 of 1
PA40-44-33-DP-PP 价格&库存
很抱歉,暂时无法提供与“PA40-44-33-DP-PP”相匹配的价格&库存,您可以联系我们找货
