PA44-40-P64Z
PA44-40-P64Z
    LOGICALSYSTEMS
    ADAPTER 44-PLCC ZIF TO 40-DIP
PA44-40-P64Z 数据手册
PA44-40-P64(Z) Data Sheet 44 pin PLCC socket/40 pin DIP 0.6” plug Supported Device/Footprints Adapter Parts & Part Numbers Using this adapter, the Microchip PIC16C64 in either PLCC or CLCC package can be programmed on 40 pin DIP programmers. The following chart shows the various socket and board part numbers that make up these adapters. Device Footprint Mfgr Device Package Device Plug Microchip PIC16C64 PLCC, PIC16C64 40 pin DIP PIC16C64A CLCC PIC16C64A PIC16C65 PIC16C65 PIC16C65A PIC16C65A PIC16C74 PIC16C74 PIC16C74A PIC16C74A Adapter Dimensions Adapter PA44-40-P64 PA44-40-P64Z Test Socket 44-306 44-400 Circuit Board P64-PD P64-PZD Adapter Construction The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Test Socket PLCC Auto-Eject test socket: Yamaichi Part #: IC120-0444-306 ZIF Lidded socket: Yamaichi Part #: IC51-0444-400 LSC Part #: 44-306 LSC Part #: 44-400 P64-P(Z)D Accepts the test socket and remaps the signals to the DIP plug. Adapter Wiring The following chart shows the connections from the PLCC device to the adapter’s DIP plug. PA44-40-P64 DEVICE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 SIGNAL N/C MCLR/Vpp RA0 RA1 RA2 RA3 RA4/TOCK1 RA5 RE0/RD RE1/WR RE2/CS VD0 Vss OSC1/CLKIN OSC2/CLKOUT RC0/T1CLK1 N/C RC1/T1CK0 RC2/CCPI RC3/SCK/SCL RD0/PSP0 RD1/PSP1 PLUG PLUG SIGNAL 40 RB7 1 39 RB6 2 38 RB5 3 37 RB4 4 N/C 5 36 RB3 6 35 RB2 7 34 RB1 8 33 RB0/INT 9 32 VD0 10 31 Vss 11 30 RD7/PSP7 12 29 RD6/PSP6 13 28 RD5/PSP5 14 27 RD4/PSP4 15 26 RC7 N/C 16 25 RC6 17 24 RC5/SD0 18 23 RC4/SDI/SDA 19 22 RD3/PSP3 20 21 RD2/PSP2 DEVICE 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 PA44-40-P64Z Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA44-40-P64(Z) Data Sheet Doc: 4440P64B.DOC Rev 6/16/99 Page 1 of 1
PA44-40-P64Z 价格&库存
很抱歉,暂时无法提供与“PA44-40-P64Z”相匹配的价格&库存,您可以联系我们找货
