PA44-40-01-PDZ
PA44-40-01-PDZ
    LOGICALSYSTEMS
    ADAPTER 44-PLCC ZIF TO 40-DIP
PA44-40-01-PDZ 数据手册
PA44-40-01-PD(Z) Data Sheet 44 pin PLCC socket/40 pin DIP 0.6” plug Supported Device/Footprints Adapter Construction These adapters connect a PLCC package to a 40 pin DIP footprint. They allow programming of some 44 PLCC devices in their 40 DIP footprint. These adapters are made up of 3 sub-assemblies. They assemble via connectors making the adapter modular. This way the sub-assemblies can be replaced easily. Other devices that require the same mapping are also supported. Below is a partial list of devices known to work with this adapter. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Zilog: Z86C21/ E21/ C61/ E61 Footprint: Same device 40 DIP The following chart lists the adapters described by this datasheet and their subassemblies. Adapter Dimensions Adapter PA44-40-01-PD PA44-40-01-PDZ Test Sockets LSC # 44-306 44-400 Test Socket 44-306 44-400 Style Auto-Eject Lidded ZIF Top Board 44PL2-3 44PL2-Z Bottom Board 44-40-01 44-40-01 Mfgr/Pn Yamaichi IC120-0444-306 Yamaichi IC51-0444-400 Adapter Wiring The following chart shows the connections from the PLCC device to the adapter’s DIP plug. PA44-40-01-PD PLCC Socket 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 DIP Plug 1 2 3 4 5 N/C 6 7 8 9 10 11 12 13 14 15 N/C 16 17 18 19 20 DIP Plug 40 39 38 37 36 N/C 35 34 33 32 31 30 29 28 27 26 N/C 25 24 23 22 21 PLCC Socket 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 Skip and short notation: (6, 17, 28, 39) PA44-40-01-PDZ Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA44-40-01-PD(Z) Data Sheet Doc: 444001PD.DOC Rev 02/08/00 Page 1 of 1
PA44-40-01-PDZ 价格&库存
很抱歉,暂时无法提供与“PA44-40-01-PDZ”相匹配的价格&库存,您可以联系我们找货
