PA44-40-33-PDZ
PA44-40-33-PDZ
    LOGICALSYSTEMS
    ADAPTER 44-PLCC ZIF TO 40-DIP
PA44-40-33-PDZ 数据手册
PA44-40-33-PD(Z) Data Sheet 44 pin PLCC socket/40 pin DIP 0.6” plug Supported Device/Footprints Adapter Construction These adapters connect a PLCC package to a 40 pin DIP footprint. They allow programming of some 44 PLCC devices in their 40 DIP footprint. These adapters are made up of 3 sub-assemblies. They assemble via connectors making the adapter modular. This way the sub-assemblies can be replaced easily. Other devices that require the same mapping are also supported. Below is a partial list of devices known to work with this adapter. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Zilog: Z86E30/ E31/ E33/ 733/ E34/ E40/E43/743/E44 Footprint: Same device 40 DIP The following chart lists the adapters described by this datasheet and their subassemblies. Adapter Dimensions Adapter PA44-40-33-PD PA44-40-33-PDZ Test Sockets LSC # 44-306 44-400 Test Socket 44-306 44-400 Style Auto-Eject Lidded ZIF Top Board 44PL2-3 44PL2-Z Bottom Board 44-40-33 44-40-33 Mfgr/Pn Yamaichi IC120-0444-306 Yamaichi IC51-0444-400 Adapter Wiring The following chart shows the connections from the PLCC device to the adapter’s DIP plug. PA44-40-33-PD PLCC Socket 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 DIP Plug 31 31 32 33 34 35 36 37 38 39 40 1 2 3 4 5 6 7 8 9 10 DIP Plug 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 11 PLCC Socket 44 43 42 41 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 Skip short notation: 1, 12, 23, 34 (1-2), (23-24)PLCC rotated CCW (+11). PA44-40-33-PDZ Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA44-40-33-PD(Z) Data Sheet Doc: 444033PD.DOC Rev 02/08/00 Page 1 of 1
PA44-40-33-PDZ 价格&库存
很抱歉,暂时无法提供与“PA44-40-33-PDZ”相匹配的价格&库存,您可以联系我们找货
