PA52-PP
PA52-PP
    LOGICALSYSTEMS
    PLCC
    ADAPTER 52-PIN PLCC
PA52-PP 数据手册
PA52-P(Z)P Data Sheet 52 pin PLCC socket/52 pin PLCC plug Supported Device/Footprints Adapter Construction These adapters accepts 52 pin PLCC devices and plugs into 52 pin PLCC production sockets. Test points are provided near the edges of the circuit board. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. Mfgr Many Socket Device 52 pin Package PLCC Device 52 pin Plug Package PLCC Adapter Dimensions When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. The adapters described by this datasheet and their subassemblies are: Adapter Test Socket Board PA52-PP 52-307 52-PP PA52-PZP 52-411 52-PZP Test Socket LSC # 52-307 52-411 Style Auto-Eject Lidded ZIF Mfgr/Pn Yamaichi IC120-0524-307 Yamaichi IC51-0524-411 Test Points These adapters offer Test Points. The Test Points are rows of plated-thru-holes (PTH) along the 4 edges of the adapter. Grabbers may be used to hook onto the holes. Alternately, 0.050” pitch 13 pin strips can be soldered into the holes and connections made to the strip’s pins. Right angle strips should be considered for easier access to the pins. PA52-PP Adapter Wiring This adapter is wired 1 to 1. Pin 1 of the socket is connected to pin 1 of the plug. Pin 2 to pin 2 and so on around the adapter. PA52-PZP Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA52-P(Z)P Data Sheet Doc: 52PP.DOC Rev 08/06/99 Page 1 of 1
PA52-PP 价格&库存
很抱歉,暂时无法提供与“PA52-PP”相匹配的价格&库存,您可以联系我们找货
