RC1180-MBUS3
RC1180-MBUS3
    OTHER
    RC1180-MBUS3
RC1180-MBUS3 数据手册
Radiocrafts Embedded Wireless Solutions RC1180-MBUS Wireless M-Bus Multi-Mode RF Transceiver Module (EN 13757-4:2013) Product Description The RC1180-MBUS RF Transceiver Module is a compact surface-mounted high performance module with embedded Wireless M-Bus protocol. The module has a UART interface for serial communication and configuration, and a one-pin antenna connection. The module is precertified for operation under the European radio regulations for license-free use and measures only 12.7 x 25.4 x 3.7 mm with shielding. When used with quarter-wave antennas a line-of-sight range of typ 800 meter can be achieved. The RC1180-MBUS meets the Wireless M-Bus specification S, T and R2 modes, and operates in 12 channels in the 868 MHz frequency band. Applications • Wireless M-Bus • Automatic Meter Reading (AMR) • Advanced Metering Infrastructure (AMI) • Electricity meters • Gas and Water meters • Heat meters, Heat cost allocators • Readers and concentrators Features • Embedded Wireless M-Bus protocol supporting EN 13757-4:2013 mode S, T, C and R2 • 12.7 x 25.4 x 3.7 mm compact module for SMD mounting • Easy to use UART interface for communication and configuration • Wide supply voltage range, 2.0 – 3.6 V • Ultra low power modes for extended battery lifetime • 2 channels (868.3, 868.95 MHz) in mode S, T and C • 10 channels in mode R2 (868.03 + n x 0.06 MHz) • No external components except antenna • Configurable Manufacturer ID and serial number • Conforms with EU RED directive (EN 300 220, EN 301 489, EN 60950) • Designed for EX compliance Quick Reference Data Parameter Frequency bands Number of channels Data rate Max output power Sensitivity, R/S/T Supply voltage Current consumption, RX / TX Current consumption, SLEEP Temperature range (S and T mode) ©2018 Radiocrafts AS RC1180-MBUS 868.0 – 870.0 12 4.8, 32.768, 100 9 -106/-102/-101 2.0 – 3.6 24 / 37 Typ 0.3 -40 to +85 RC1180-MBUS Data Sheet (rev. 2.23) Unit MHz kchip/s dBm dBm Volt mA uA C Page 1 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS RC1180-MBUS Embedded Firmware Solutions The RC1180-MBUS module is available with different embedded firmware solutions, implementing specific feature sets on the same hardware. Detailed information on how to use the different feature sets are described in the MBUS User Manual. See the Radiocrafts’ webpage for latest revision. Typical application circuit 2.0 – 3.6 V Optional { To host meter or RS232/422/485 driver GND RTS CTS CONFIG TXD RXD GND GND VCC RESET NC GND RF GND Antenna NC NC See page 8-9 for additional schematic information regarding recommended Reset and Power supply filtering, and how to include a firmware upgrade connector. Wireless M-Bus Modem The standard RC1180-MBUS module acts like a wireless M-Bus modem with a UART interface. The embedded protocol transmits and receives the wireless M-Bus data packets based on application messages from an external source (the meter or the concentrator). The module is configured through its UART interface using a simple command set. Configuration parameters are stored in non-volatile memory. The module can be set in Sleep mode with very low current consumption, and wake up on a UART command. See MBUS User Manual for details about the embedded wireless MBUS protocol from Radiocrafts. RXD Meter TXD RC1180-MBUS (modem) RC1180-MBUS (modem) UART ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) UART to: RS232 RS485 USB Ethernet Page 2 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS RF Frequency, Output Power Levels and Data Rates The following table shows the available RF channels and their corresponding frequencies, nominal output power levels and available data rates. The combination of frequency and data rate is determined by the M-Bus mode. For R mode the RF channel selection must be selected between 1-10. Model RF channel RC1180- 1-10: MBUS fRF=868.03+(N-1)*0.06 MHz where N is the channel number 11 (used in S and T2 mode): fRF=868.300 MHz Output power 1: -20 dBm 2: -10 dBm 3: 0 dBm 4: 5 dBm 5: 9 dBm Data rate 1: 4.8 kchip/s 2: 32.768 kchip/s 3: 100 kchip/s 12 (used in T1 and T2 mode): fRF=868.950 MHz Factory setting: 1: 868.030 MHz (apply for R mode only) C mode frequency same as T mode For more details on changing the RF channel, output power or M-Bus mode, refer to the MBUS User Manual. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 3 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Full wireless M-Bus application (optional custom specific version) As an option, a full wireless M-Bus application layer can be integrated in the module based on customer specification. In this case all the application layer protocol and timing will be handled internally by the module. An S0 (1-pin) pulse interface and/or a serial interface can be used to read out values from any meter. Since the protocol for reading out meter information may differ from meter to meter, the embedded firmware is customized for each different meter and application. These are some of the features that can be used in a customized application: • 4 kB EEPROM for storing meter data • 32 kHz oscillator for real time clock time stamps • AES-128 encryption • Sleep timers • Message acknowledgement and re-transmissions • Digital I/O pins for tamper detection, alarms and installation • A/D converter for analogue sensors Please see chapter “Programming Interface” for a description of how to include a programming connector in your PCB layout to be able to receive updated firmware code from Radiocrafts in a pilot product phase. One-Button Installation (optional custom specific version) Due to the two-way transceiver capability of the RC1180-MBUS module, a simple and robust installation procedure can be used even for S1 and T1 (one-way) operation modes. In a full M-Bus application, the Radiocrafts unique “one-button” installation feature simplifies the installation and reduces installation time substantially. Using an external push-button and a LED connected to dedicated pins on the module, the installation procedure is very simple: • • • • Press the install button on concentrator Press the install button on meter Wait 5 seconds for two way communication between meter and concentrator See installation LED go on for OK installation (Blinking for error during installation) Please contact Radiocrafts for custom specific requests. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 4 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Block Diagram 2.0 - 3.6 V 8-bit MCU Pulse input (option) M-Bus Application (option) Wireless M-Bus RF Tranceiver UART interface Wireless M-Bus protocol 32 kHz Real Time Clock (option) 32 MHz clock 4kB EEPROM (option) EEPRO M 4kB (option) Circuit Description The module contains a communication controller with embedded Wireless M-Bus protocol software and a high performance RF transceiver. As an option the module can support a real time clock oscillator and EEPROM memory. The communication controller handles the radio packet protocol, the UART interface and controls the RF transceiver. Data to be sent by the host is received at the RXD pin and buffered in the communication controller. The data packet is then assembled with preamble, start-of-frame delimited (SOF), manufacturer ID, unique address information and CRC check sums before it is transmitted on RF. The RF transceiver modulates the data to be transmitted on RF frequency, and demodulates data that are received. Digital signal processing technology is used to enhance sensitivity and selectivity. Received data are checked for correct CRC by the communication controller. If no CRC errors were detected, the data packet is sent to the host on the TXD line. The data format is configurable, and optionally an RSSI value (signal strength of received packet) can be added to the message. The asynchronous UART interface consists of RXD and TXD. Optionally CTS or RTS can be used for hardware handshake flow control. When a 00h value is sent as the first byte (replacing the Length byte), or the CONFIG pin is asserted, the module enters configuration mode and the communication controller interprets data received on the RXD pin as configuration commands. There are commands to change the radio channel, the output power, etc. Permanent changes of the configuration is also possible and are then stored in internal non-volatile memory (Flash). The supply voltage is connected to the VCC pin. The module contains an internal voltage regulator for the RF transceiver and can therefore operate over a wide supply voltage range. The module can be set in Sleep mode by UART commands to reduce the power consumption to a minimum. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 5 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Pin Assignment 30 GND 29 28 27 26 25 24 23 1 14 GND 2 13 VCC RTS 3 12 RESET CONFIG 4 11 NC TXD 5 10 GND RXD 6 9 GND 7 CTS RF 8 15 16 17 18 19 20 21 GND 22 Pin Description Pin no Pin name 1 GND Description System ground 2 3 4 UART Clear to Send UART Request to Send Configuration Enable. Active low. Should normally be set high UART TX Data UART RX Data 5 6 CTS RTS CONFIG TXD RXD Use external max 8k2 kohm pullup resistor if connected to an open collector output from a host MCU or other high impedance circuitry like level shifters. 7 8 GND GND ©2018 Radiocrafts AS System ground System ground RC1180-MBUS Data Sheet (rev. 2.23) Equivalent circuit GND VCC Input: 20k VCC Output: GND Page 6 of 16 Radiocrafts Embedded Wireless Solutions 9 RF RC1180-MBUS RF I/O connection to antenna RF 10k 10 GND System ground 11 12 NC RESET Not connected Main reset (active low). Should normally be left open. Internal 12 kΩ pull-up resistor. GND VCC 12k RESET 13 VCC Supply voltage input. Internally regulated. 1.8 V VREG VCC 2u2 14 GND System ground 15-22 RESERVED 23-28 RESERVED 29 LED1 30 LED0 Test pins or pins reserved for future use. Do not connect! Test pins or pins reserved for future use. Do not connect! LED output using LED_CONTROL. If not used, do not connect. LED output using LED_CONTROL. If not used, do not connect. GND Note 1: For UART communication the TXD and RXD are used for serial data, and CTS and RTS for flow control (optional). RXD should be high when not sending data to the module. Note 2: The CONFIG pin can be used to enter configuration mode (change of default settings) as an alternative to the 0x00 command. Active low. Note 3: Other digital interfaces may be specified upon request. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 7 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Application circuit A typical application circuit is shown where a MCU is connected to the Radiocrafts module. In normal cases the UART (CTS/RTS is optional) and RESET line is connected to a host MCU running the application. CONFIG is optional since a UART command can replace the CONFIG pin on the MBUS modules. Pin 29/30 are LED drivers and D1/D2 can be mounted (optional) for debugging (State information). MCU considerations Some additional external components is needed depending on MCU output driver properties connected to the Radiocrafts module. If the RESET is driven by a push-pull output, an additional 0 ohm series resistor (R4) shall be inserted as shown in the figure, to allow an external programmer used for firmware upgrade to assert Reset low. During firmware upgrade, R4 must in this case be removed. In noisy surroundings and where RESET is not driven by a push-pull output, it is recommended to add an external pull-up on RESET using a 5k6 resistor (R3). If the pull-up is stronger the external programmer used for firmware upgrade will not be able to assert RESET low. In noisy surroundings and where RXD is not driven by a push-pull output, it is recommended to add an external pull-up on RXD using a 5k6 resistor (R3). ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 8 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Reset filter To minimize effect of noise on the Reset-line, the RESET pin on the module (pin 12) must be connected to an external circuitry via an RC-network. It is recommended to connect RESET to a microcontroller I/O-pin. The reset filter should be placed as close as possible to the RESET pin of the module. Power Supply Noisy external circuitry may under certain scenarios affect the transmitted signal on RX1180MBUS and precaution should be taken for EU R&TTE conformity. Example of circuits that can generate noise on the RC1180-MBUS transmitted spectrum may be DC/DC converters and some level converters like RS232 and RS485. To increase spectrum margin it is important to add an EMI filter bead (L1) on the VCC pin of the RC1180-MBUS module. Alternatively, the RC1180-MBUS may be powered (RC_VCC) from a separate voltage regulator. This will ensure that potential switching noise is filtered out from the power supply (RC_VCC) to the RC1180-MBUS. Component EMI filter bead (L1) Manufacturer Murata Part number BLM11A102S, ordering code BLM18xx102xN1D Programming Interface For future firmware updates and possible custom variants it is recommended to include a 2x5 pins programming connector to the module programming pins. The connector should be a 1.27 mm pitch pin-row (same pitch in both directions), SMD or through-hole version, with the connections shown below. RXD/TXD lines is not in use for firmware upgrade, but is included on spare pins on the connector for debugging purposes. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 9 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Antenna Connection The antenna should be connected to the RF pin. The RF pin is matched to 50 Ohm. If the antenna connector is placed away from the module at the motherboard, the track between the RF pin and the connector should be a 50 Ohm transmission line. On a two layer board made of FR4 the width of a microstrip transmission line should be 1.8 times the thickness of the board, assuming a dielectric constant of 4.8. The line should be run at the top of the board, and the bottom side should be a ground plane. Example: For a 1.6 mm thick FR4 board, the width of the trace on the top side should be 1.8 x 1.6 mm = 2.88 mm. The simplest antenna to use is the quarter wave whip antenna. A quarter wave whip antenna above a ground plane yields 37 Ohm impedance and a matching circuit for 50 Ohm are usually not required. A PCB antenna can be made as a copper track where the ground plane is removed on the back side. The rest of the PCB board should have a ground plane as large as possible, preferably as large as the antenna itself, to make it act as a counterweight to the antenna. If the track is shorter than a quarter of a wavelength, the antenna should be matched to 50 ohms. The lengths of a quarter wave antenna for different operational frequencies are given in the table below. Frequency [MHz] 868 Length [cm] 8.2 Regulatory Compliance Information The use of RF frequencies and maximum allowed RF power is limited by national regulations. The RC1180-MBUS has been designed to comply with the RED directive 2014/53/EU. According to RED directives, it is the responsibility of Radiocrafts’ customers (this means RC1180-MBUS end user) to check that the host product (that means final product) is compliant with RED essential requirements. The use of a CE marked radio module can avoid re-certification of the final product, provided that the end user respects the recommendations given by Radiocrafts. A Declaration of Conformity is available from Radiocrafts on request. The relevant regulations are subject to change. Radiocrafts AS do not take responsibility for the validity and accuracy of the understanding of the regulations referred above. Radiocrafts only guarantee that this product meets the specifications in this document. Radiocrafts is exempt from any responsibilities related to regulatory compliance. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 10 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS PCB Layout Recommendations The recommended layout pads for the module are shown in the figure below. All dimensions are in thousands of an inch (mil). The circle in upper left corner is an orientation mark only, and should not be a part of the copper pattern. A PCB with two or more layers and with a solid ground plane in one of the inner- or bottom layer(s) is recommended. All GND-pins of the module shall be connected to this ground plane with vias with shortest possible routing, one via per GND-pin. On the back side of the module there are several test pads. These test pads shall not be connected, and the area underneath the module should be covered with solder resist. If any routing or vias is required under the module, the routing and vias must be covered with solder resist to prevent short circuiting of the test pads. It is recommended that vias are tented. Reserved pins should be soldered to the pads but the pads must be left floating. Note that Radiocrafts technical support team is available for schematic and layout review of your design. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 11 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Mechanical Drawing Mechanical Dimensions The module size is 12.7 x 25.4 x 3.7 mm. Carrier Tape and Reel Specification Carrier tape and reel is in accordance with EIA Specification 481. Tape width 44 mm Component Hole pitch pitch 16 mm 4 mm Reel diameter 13” Units per reel Max 1000 Soldering Profile Recommendation JEDEC standard IPC/JEDEC J-STD-020D.1 (page 7 and 8), Pb-Free Assembly is recommended. The standard requires that the heat dissipated in the "surroundings" on the PCB is taken into account. The peak temperature should be adjusted so that it is within the window specified in the standard for the actual motherboard. Aperture for paste stencil is normally areal-reduced by 20-35%, please consult your production facility for best experience aperture reduction. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 12 of 16 Radiocrafts Embedded Wireless Solutions Absolute Maximum Ratings Parameter Min Supply voltage, VCC -0.3 Voltage on any pin -0.3 Input RF level Storage temperature Operating temperature -50 -40 RC1180-MBUS Max 3.9 VCC+0.3V Max 3.9V 10 150 85 Unit V V dBm C C Caution ! ESD sensitive device. Precaution should be used when handling the device in order to prevent permanent damage. Under no circumstances the absolute maximum ratings given above should be violated. Stress exceeding one or more of the limiting values may cause permanent damage to the device. Fresh 3.6V Li batteries normally have a higher open circuit voltage than the nominal 3.6V, but can still be used to power the module as long as it is not exceeding the absolute maximum rating (3.9V). When the module operates in IDLE/RX/TX the loaded battery voltage will usually drop below 3.6V, which is inside the operation voltage range (2.0V – 3.6V). Electrical Specifications T=25C, VCC = 3.0V if nothing else stated. Parameter Min Operating frequency 868.0 Typ. Max Unit 870.0 MHz Condition / Note Number of channels 12 Input/output impedance Ohm 50 Chip rate S-mode T-mode R2-mode 32.768 100 4.8 kchip/s Data rate S-mode T-mode R2-mode 16.384 66.67 2.4 kbit/s S and R2 mode use Manchester coding. T mode uses 3-of-6 coding. T2 use a combination of both. +/-40 +/-20 ppm 1 ppm/year 10 dBm Including 10 years of aging. TBD limited temperature range for R2 mode Starting after 10 years Typical values are for default settings Frequency stability S and T mode R2 mode Frequency stability aging Transmit power -20 9 FSK deviation S-mode T-mode R2-mode Adjacent channel power +/- 50 +/- 50 +/- 6 TBD kHz dBc Occupied bandwidth TBD kHz 99.5% Spurious emission, TX < 1 GHz > 1 GHz ©2018 Radiocrafts AS -36 -30 dBm RC1180-MBUS Data Sheet (rev. 2.23) Page 13 of 16 Radiocrafts Embedded Wireless Solutions Sensitivity S-mode T-mode R2-mode -102 -101 -106 dBm Adjacent channel rejection 29 dB Alternate channel selectivity 53 dB Image channel rejection 28 dB Blocking / Interferer rejection / desensitization +/- 1 MHz +/- 2 MHz +/- 5 MHz +/- 10 MHz -100 -100 -105 RC1180-MBUS dB 30 35 50 60 43 49 68 72 Saturation -14 dBm Input IP3 TBD dBm Measured at 1% BER / 80% PER of 20 byte packets. Wanted signal 3 dB above sensitivity level, CW interferer. Minimum numbers corresponds to class 2 receiver requirements in EN300220. Spurious emission, RX Supply voltage 2.0 -57 dBm 3.6 V Current consumption, RX/IDLE UART IDLE RESET pin Input logic level, low Input logic level, high ©2018 Radiocrafts AS mA UART IDLE current depends on UART Baud Rate. Max value for baud rates >14.4 kbaud and 1.7 ma for lower baud rates Apply over entire supply voltage range 3.6 37 32 24 19 18 0.1 70 % 0 TBD 1.0 uA 30 % V Of VCC Of VCC TBD VCC 30 % V Minimum 250 ns pulse width 70 % UART Baud Rate tolerance Configuration memory write cycles Apply over entire supply voltage range 24 1.7 Current consumption, TX RF_POWER=5, 9 dBm RF_POWER=4, 5 dBm RF_POWER=3, 1 dBm RF_POWER=2, -10 dBm RF_POWER=1, -20 dBm Current consumption, SLEEP Digital I/O Input logic level, low Input logic level, high Output logic level, low (1µA) Output logic level, high(-1µA) mA +/- 2 % 1000 RC1180-MBUS Data Sheet (rev. 2.23) UART receiver and transmitter The guaranteed number of write cycles using the ‘M’ command is limited Page 14 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Document Revision History Document Revision 1.0 1.1 Changes First release Pin Assignment and Pin Description: Pin 2 = RTS, Pin 3 = CTS. Changed equivalent circuit to be pulled to VCC not VDD on relevant pins Power supply chapter added. Frequency stability aging added. Pin Assignment for Pin 2 and Pin 3 swapped, Pin 2 = CTS. Added chapter “Programming interface”. Changed Test mode 2 description, added Test mode 3 description. UART_BAUD _RATE settings corrected. Added R-C network on Reset-pin Apply for firmware revision 1.15 and above (1.xx) Added ‘F’ (set C-field) and ‘G’ (set M-Bus mode) commands Added ‘T’ (set Destination Address / module ID) command Minor corrections MBUS protocol info separated into a User Manual Mechanical drawing update, Product status change and minor corrections -Voltage range clarified to be 3.9V -removed protocol information that is available in User Manual - Minor corrections - C mode added - improved application circuit - Absolut max voltage vs Max Supply voltage clarification - Updated Mechanical drawing and height information. Please refer to Hardware PCN for revision history. - Updated regulatory compliance - Updated MBUS compliance 1.2 1.3 1.4 1.5 1.6 2.0 2.10 2.20 2.21 2.22 2.23 Product Status and Definitions Current Data Sheet Identification Status Product Status Advance Information Planned or under development Preliminary Engineering Samples and First Production No Identification Noted Full Production Obsolete Not in Production X ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Definition This data sheet contains the design specifications for product development. Specifications may change in any manner without notice. This data sheet contains preliminary data, and supplementary data will be published at a later date. Radiocrafts reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. This data sheet contains final specifications. Radiocrafts reserves the right to make changes at any time without notice in order to improve design and supply the best possible product. This data sheet contains specifications on a product that has been discontinued by Radiocrafts. The data sheet is printed for reference information only. Page 15 of 16 Radiocrafts Embedded Wireless Solutions RC1180-MBUS Disclaimer Radiocrafts AS believes the information contained herein is correct and accurate at the time of this printing. However, Radiocrafts AS reserves the right to make changes to this product without notice. Radiocrafts AS does not assume any responsibility for the use of the described product; neither does it convey any license under its patent rights, or the rights of others. The latest updates are available at the Radiocrafts website or by contacting Radiocrafts directly. As far as possible, major changes of product specifications and functionality, will be stated in product specific Errata Notes published at the Radiocrafts website. Customers are encouraged to check regularly for the most recent updates on products and support tools. Trademarks RC232™ is a trademark of Radiocrafts AS. The RC232™ Embedded RF Protocol is used in a range of products from Radiocrafts. The protocol handles host communication, data buffering, error check, addressing and broadcasting. It supports point-to-point, point-to-multipoint and peer-to-peer network topologies. All other trademarks, registered trademarks and product names are the sole property of their respective owners. Life Support Policy This Radiocrafts product is not designed for use in life support appliances, devices, or other systems where malfunction can reasonably be expected to result in significant personal injury to the user, or as a critical component in any life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. Radiocrafts AS customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify Radiocrafts AS for any damages resulting from any improper use or sale. Radiocrafts Technical Support Knowledge base: Application notes library: Whitepapers: Technology overview: RF Wireless Expert Training: https://radiocrafts.com/knowledge-base/ https://radiocrafts.com/resources/application-notes/ https://radiocrafts.com/resources/articles-white-papers/ https://radiocrafts.com/technologies/ https://radiocrafts.com/resources/rf-wireless-expert-training/ Contact Radiocrafts Sales requests: https://radiocrafts.com/contact/ © 2018, Radiocrafts AS. All rights reserved. ©2018 Radiocrafts AS RC1180-MBUS Data Sheet (rev. 2.23) Page 16 of 16
RC1180-MBUS3 价格&库存
很抱歉,暂时无法提供与“RC1180-MBUS3”相匹配的价格&库存,您可以联系我们找货
