PA48QD-806
PA48QD-806
    LOGICALSYSTEMS
    ADAPTER QFP TO DIP
PA48QD-806 数据手册
PA48QD-806 Data Sheet 48 pin QFP socket/48 pin DIP 0.6” plug Supported Device/Footprints Adapter Construction This is a generic package adapter. It takes a QFP and wires all pins to a DIP plug. The adapter is made up of 2 sub-assemblies. They assemble via connectors making the adapter modular. This way the subassemblies can be replaced when they wear out. The QFP socket accepts packages with the dimension sets listed below: When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. Adapter PA48QD-806 Socket 48QJ-806 Body 7.0 mm typ Knee 6 mm typ 7.8 mm max Tip 9 mm typ Pitch 0.5 mm Adapter Dimensions Test Socket LSC Socket 48QJ-806 Test Socket 48QJ-806 Style Lidded ZIF Circuit Board 48QD-806 Mfgr/Pn Yamaichi IC51-0484-806 Adapter Wiring The adapter is wired 1-1. Pin 1 of the QFP device connects to pin 1 of the DIP plug, pin 2 to pin 2, and so on around the adapter. PA48QD-806 Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA48QD-806 Data Sheet Doc: 48QD-806.DOC Rev 01/03/03 Page 1 of 1
PA48QD-806 价格&库存
很抱歉,暂时无法提供与“PA48QD-806”相匹配的价格&库存,您可以联系我们找货
