Subminiature, LAN Modular Jack Connectors
■Features
24
1. Fast Ethernet Support
Other series
TM21R--5C--88--LP
2. Subminiature Design Contributes to
Saving Space in the Equipment
17.5
15
Having built-in optical indicators, with height of
only 11.5mm, width of 15mm and depth of
17.5mm the connectors can be used in
extremely limited spaces.
3. Built-in Optical Indicators
Optical indicators are integral part of the
connectors help saving space on customer’s
board.
Compared with LED type indicators, they do not
emit any electrical noise.
21
13.4
Conforms to the TIA/EIA-568-A data wiring
standard and meets requirements of CAT5
transmission performance for 1,2-3,6 conductor
pairs. As such, these products fully support Fast
Ethernet (100BASE-TX) transmission.
16
14.5
11.5
Sep.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
TM11R-5M2 Series
TM11R--5M2--88--LP
Space saving
housing
LED optical indicators are taking place
4. EMI protection
Metal shield covers the outer surfaces of the
connectors assuring complete protection against
electromagnetic interference.
Built-in multiple shield and ground contacts
assure reliable connection with the mounting
panel as well as with the mating connectors.
5. Environmental considerations
EMI protection
Plating is lead-free in order to protect environment.
6. FCC Standards
Meets requirements of FCC Title 47, Part 68,
Subpart F.
■Applications
Telecom Hubs, Routers, Bridges and ATM
Transmission Equipment, Ethernet Switches and
Networking Equipment, Test and Measurement
Equipment, Medical Diagnostic Equipment.
Built-in LED type
Built-in Optical pipe type
(Possibility of electromagnetic
noise emission and interference.)
(No electromagnetic
noise emission.)
2018.8②
1
TM11R-5M2 Series●Subminiature, LAN Modular Jack Connectors
■Product Specifications
Current rating
1A
Voltage rating
125V AC
Operating temperature range : -25ç to +80ç (Note)
Rating
Item
Specification
Conditions
1. Insulation resistance 100Mø min.
100V DC
2. Dielectric Withstanding Voltage
No flashover or insulation breakdown
(between adjacent contacts)
500V AC applied for 1minute
3. Withstanding voltage
(between contact and shield
1500V AC / 1minute
4. Contact resistance
230mø max.
100mA
5. Vibration
No electrical discontinuity of 5μ sec. or more.
Contact resistance : 250mø max.
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
2 hours / 3 axis
6. Shock
Acceleration of 490 m/s2, 11ms duration,
sine half-wave waveform, 3 cycles in each of the 3 axis
7. Durability
(mating/un-mating)
200 cycles
Temperature : -55ç/+15ç to +35ç/+85ç/+15ç to +35ç
Duration : 30/2 to 3/30/2 to 3 (Minutes)
5 cycles
8. Temperature cycle
Insulation resistance : 100Mø min.
9. Humidity
Insulation resistance : 1Mø min. (High humidity)
Insulation resistance : 10Mø min. (Dry state)
10. Salt Spray
500 hours at temperature of 40ç and humidity
of 90% to 95%
Exposed to density 5% salt water for 48 hours
Note : Includes temperature rise caused by current flow.
■Materials / Finish
Material
Finish
Remarks
Insulator
Part
PBT
Color : Black
UL94V-0
Contact
Copper alloy
Contact area : Gold plating
Termination area : Tin alloy plating
Polycarbonate
Color : Transparent
UL94V-0
Copper alloy
Tin plating
Optical pipe
Shield
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Jacks
TM11 R - 5M2 - 8 8 - LP
1
2
3
4 5
6
1 Series name
TM11 Series
2 Connector type
R : Jack
3 Jack type
5M2 : PCB Right-angle through hole type
4 Jack opening code 8 : 8 contacts
5 Number of inserted contacts
6 Optical pipe
8 : 8 contact
LP : With optical pipe inserted
Blank : Without optical pipe
2
■Modular Jack Connectors Supporting CAT5 (for 1,2-3,6 pair)
●Single Port With Built-in Optical Pipe
14.5
( 4.25 )
0.8
15
0.45
0.25
3.6
0.6
3
1.7
11.5
Contact No. 1
11.5
Contact No. 8
0.3
(2)
11.4
1
14.75
5.55
3.1
11.25
YES
(4.25)
222-2905-0
TM11R--5M2 1 PC
Contact No. 8
3.1
TM11R-5M2-88-LP
2.54
RoHS
(4.25)
HRS No.
Contact No. 1
11.1
Contact No. 7
Contact No. 2
●Single Port Without Optical Pipe
14.5
(4.25)
0.8
15
Contact No. 1
3.6
0.6
3
11.5
11.5
Contact No. 8
0.45
(2)
0.25
0.3
1
11.4
5.55
14.75
0.8
YES
(4.25)
RoHS
3.1
HRS No.
222-2906-2
2.54
Part No.
TM11R-5M2-88
3.1
0.8
(4.25)
Part No.
17.5
0.8
0.8
Contact No. 8
Contact No. 1
Contact No. 7
Contact No. 2
3
BRecommended PCB mounting patterns
●With Built-in Optical Pipe
●Without Optical Pipe
11.1
8.89
6.35
8.89
3.81
6.35
LED location area
3.81
LED light emission area
Printed board edge
14.75
1
2MIN
2
2
2-Ø2.4
11.4 MIN
18.1MIN
4
3
4
No conductive &
ground traces
11.4
Printed board
edge
Connector
front edge
11.4 MIN
14.75
18.1 MIN
Suggested LEDs
3.2MAX
LED light emitting center
2.7 MAX
1.5 MAX
*Recommendations for PCB Design
1
2
3
4
Areas indicated should be free of conductive traces.
Area indicated should be free of conductive & ground traces.
Recommended board thickness : 1.6mm.
To assure that the indicator light pipes operates correctly the LED’s must be installed directly on the
PCB, within recommended dimensions and with light emitting center in upward direction.
Contact applicable manufacturer for LED specification.
BPanel Cutout
●For Both Types, With and Without Built-in Optical Pipe
(33)
Lock lever
1MIN 1
1
3±1 1
TM21P--88P
15.4
4.5MIN
12
PCB mounting surface
0.3
Connector front edge
11.4
5
6
2- Ø1.6
2
No conductive &
ground traces
8
5MIN
3.1
2-Ø1.6
2- Ø2.4
11.4 MAX
Contact No.
8- Ø1
7
2 MIN
8 6 4 2
11.4 MAX
5 MIN
3.1
7 5 3 1
1
No conductive traces
1.27
2.54
8-Ø1
3.1MAX
11.25
2.54
Contact No.
1
3.1MAX
1.27
Panel side
1
Connector front surface
1
3.1MAX
*Recommendations for Panel Design
5.55
1 The shield contacts should connect with the panel cut-out on all sides.
Note : IPA cleaning at room temperature is recommended for the cleaning of this product.
When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of
polycarbonate resin) may change color; therefore, please make a selection based on a table showing
the effects on the resin. These tables are issued by the various manufacturers of cleaning agents.
4
BCAT5 Transmission Characteristics Data
For fully mated receptacle (TM11R-5M2-88-LP) and plug (TM21P-88P).
●Signal Attenuation
0.5
0.3
0.2
0.1
60
80
100
80
100
80
100
Frequency(MHz)
1,2
3,6
CAT5 Spec
NEXT(dB)
●Near-End Crosstalk (NEXT)
90
80
70
60
50
40
30
60
Frequency(MHz)
1,2-3,6
CAT5 Spec
●Return Loss
Return Loss(dB)
Attenuation(dB)
0.4
80
70
60
50
40
30
40
60
Frequency(MHz)
3,6
CAT5 Spec
5
GUIDANCE FOR MODULAR CONNECTORS
■Modular Connector Terminal Numbers
Unless otherwise specified, see the figures below for the terminal numbers of the product.
Plug
Jack
(mating face)
Contact
No.1
Contact
No.8
Contact
No.8
Contact
No.1
■Attention to Plug Mating
FCC PLUG DIMENSIONS
5.89 - 6.15
Use only plugs conforming to FCC standards.
Please pay particular attention to dimensions shown right.
■Opening Size and Number of Conductors(6-Conductor)
See the figures below for the relationship between the opening size and the number of conductors of the jack connectors.
Model 66
Model 64
Model 62
Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66.
For details, please contact us for drawings because only standard models are shown in the catalogs.
■Recommended Soldering for Modular Dip Connectors
●Flow solder (automatic soldering machine)
Pre-heat
: 90 - 130ç
Pre-heat time
: 120 seconds maximum
Solder temperature
: 240 - 260ç
Soldering time
: 10 seconds maximum
●Hand soldering
Soldering iron tip temperature : 350ç
Soldering temperature
: 5 seconds maximum
Soldering iron output
: 30 - 40W
Note : When soldering, use care not to apply excessive force to the connector terminals.
●Recommended Solder composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu
6
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 08/2018. Contents are subject to change without notice for the purpose of improvements.
