FR107W
Surface Mount Fast Recovery Rectifiers
Forward Current - 1 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Simplified outline SOD-123F and symbol
MECHANICAL DATA
• Case: SOD-123F
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 15mg 0.00053oz
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
F R107 W
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
1000
V
Maximum RMS voltage
V RMS
700
V
Maximum DC Blocking Voltage
V DC
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Forward Voltage at 1 A
VF
1.3
V
IR
5
100
μA
Cj
15
pF
t rr
500
ns
RθJA
85
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yongyutai.com
PAGE 1
FR107W
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
100
T J =25°C
10
1
0.5
1.0
1.5
2.0
2.5
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
www.yongyutai.com
PAGE 2
FR107W
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123F
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
Top View
mil
Bottom View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
g
pad
e
E
A
pad
HE
7°
The recommended mounting pad size
2.0
(79)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.yongyutai.com
PAGE 3
很抱歉,暂时无法提供与“FR107W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.05433
- 500+0.04266
- 3000+0.03770
- 6000+0.03381
- 24000+0.03035
- 51000+0.02862
