BWCU00121008900M02
BWCU00121008900M02
    CHILISIN(奇力新)
    SMD,1.25x1x0.8mm
    两路 贴片共模滤波器 阻抗90Ω@100MHZ
BWCU00121008900M02 数据手册
SMD Common Mode Choke – BWCU_02 Series BWCU_02 Series For USB 2.0, IEEE1394b, LVDS Applications A full series of common mode choke is designed for excellent noise attenuation with compact sizing for use in wide range of applications. Both standard series and custom designs are available. Features     Applications RoHS Compliant  USB line for personal computers and peripheral Miniature SMD type common mode filter for fully automated assembly  IEEE 1394 line for personal computers, DVC, STB Wide impedance range (30Ω ~ 2200Ω) for noise suppression  LVDS, panel line for liquid display panels, graph card,etc. Excellent solderability Product Identification Shape and Dimensions Recommended Pattern BWCU00160811/ 121008/ 321619 BWCU00201212 Dimensions in mm TYPE A B C D E F G H I BWCU00160811 1.60±0.2 0.80±0.2 1.10±0.2 0.25 0.33 0.25 0.75 0.61 2.29 BWCU00121008 1.25±0.2 1.00±0.2 0.8±0.1 0.32 0.33 0.36 1.00 0.59 1.75 BWCU00201212 2.05±0.2 1.25±0.2 1.20±0.2 0.50 0.40 0.50 1.27 0.80 2.60 BWCU00321619 3.20±0.2 1.60±0.2 1.90±0.2 0.50 0.60 0.40 1.60 1.60 3.70 SMD Common Mode Choke – BWCU_02 Series Shape and Dimensions Recommended Pattern BWCU00231512 Dimensions in mm TYPE A B C D E F G H I J K L BWCU00231512 2.29+0 1.52+0 1.20+0 0.5 1.27 2.03 0.5 0.40 0.5 0.38 0.9 0.8 SMD Common Mode Choke – BWCU_02 Series Electrical Characteristics Impedance (Ω) Part Number Tolerance (±%) Test Frequency (MHz) RDC (Ω) Max Irms (mA) Max Rated Voltage (Vdc) Withstamd (Vdc) Insulation Resistance (MΩ) Min Voltage BWCU00160811250M02 25 20,25 100 0.077 500 50 125 10 BWCU00160811600M02 60 20,25 100 0.109 500 50 125 10 BWCU00160811900M02 90 20,25 100 0.142 500 50 125 10 BWCU00160811121M02 120 20,25 100 0.160 500 50 125 10 BWCU00160811141M02 140 20,25 100 0.174 500 50 125 10 BWCU00160811221M02 220 20,25 100 0.209 500 50 125 10 Note: When ordering, please specify tolerance code. Tolerance: M=±20% , Y=±25%  Operating temperature range-40℃~105℃(Including self - temperature rise)  rms for 20℃ rise from 25℃ ambient  Measure Equipment: Z:Agilent HP4287A+Agilent 16197A RDC:HP4338B or Chroma 16502 (Single Wire Test Value) Irms:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4287A Material/Impedance Analyzer Typical Impedance vs. Frequency 1000 COMMON MODE 221 141 IIMPEDANCE(Ω) 100 121 600 900 250 10 221 1 141 250 0.1 1 900 600 121 10 NORMAL MODE 100 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 1000 SMD Common Mode Choke – BWCU_02 Series Electrical Characteristics Impedance (Ω) Part Number Tolerance (±%) Test Frequency (MHz) RDC (Ω) Max IDC (mA) Rated Voltage (Vdc) Withstamd (Vdc) Insulation Resistance (MΩ) Min Voltage BWCU00121008250T02 25 30 100 0.30 400 50 125 100 BWCU00121008600M02 60 20 100 0.40 300 50 125 100 BWCU00121008670M02 67 20 100 0.25 300 50 125 100 BWCU00121008900M02 90 20 100 0.30 250 50 125 100 BWCU00121008121M02 120 20 100 0.40 200 50 125 100 BWCU00121008161M02 160 20 100 0.43 160 50 125 100 BWCU00121008201M02 200 20 100 0.80 120 50 125 100 BWCU00121008331Y02 330 25 100 1.30 100 50 125 100 Note: When ordering, please specify tolerance code. Tolerance: M=±20% , Y=±25% , T=±30%  Operating temperature range-40℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current  Measure Equipment: Z:Agilent HP4287A+Agilent 16197A RDC:Chroma 16502 (Single Wire Test Value) IDC:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4287A Material/Impedance Analyzer Typical Impedance vs. Frequency 10000 Common Mode 161 IMPEDANCE(Ω) 1000 121 900 670 100 600 10 161 1 121 600 0.1 1 670 10 Normal Mode 900 100 1000 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 10000 SMD Common Mode Choke – BWCU_02 Series Electrical Characteristics Rated Withstamd Insulation Voltage Voltage Resistance (Vdc) (Vdc) (MΩ) Min 450 50 125 10 0.25 400 50 125 10 100 0.30 360 50 125 10 20 100 0.35 330 50 125 10 120 20 100 0.30 400 50 125 10 BWCU00201212161M02 160 20 100 0.35 350 50 125 10 BWCU00201212181M02 180 20 100 0.35 330 50 125 10 BWCU00201212201M02 200 20 100 0.35 330 50 125 10 BWCU00201212221M02 220 20 100 0.35 310 50 125 10 BWCU00201212261M02 260 20 100 0.40 300 50 125 10 BWCU00201212301M02 300 20 100 0.40 290 50 125 10 BWCU00201212361M02 360 20 100 0.45 280 50 125 10 BWCU00201212371M02 370 20 100 0.45 280 50 125 10 BWCU00201212501M02 500 20 100 0.55 170 50 125 10 BWCU00201212671M02 670 20 100 0.60 140 50 125 10 BWCU00201212801M02 800 20 100 0.88 300 50 125 10 BWCU00201212901M02 900 20 100 0.60 80 50 125 10 Impedance Tolerance (Ω) (±%) BWCU00201212300M02 30 20 BWCU00201212670M02 67 BWCU00201212750M02 Test RDC IDC (Ω) Max (mA) 100 0.20 20 100 75 20 BWCU00201212900M02 90 BWCU00201212121M02 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current  Measure Equipment: Z:Agilent HP4287A+Agilent 16197A RDC:Chroma 16502 (Single Wire Test Value) IDC:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4291A Material/Impedance Analyzer Typical Impedance vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_02 Series Electrical Characteristics Rated Withstamd Insulation Voltage Voltage Resistance (Vdc) (Vdc) (MΩ) Min 370 50 125 10 0.3 370 50 125 10 100 0.4 340 50 125 10 20 100 0.4 320 50 125 10 260 20 100 0.5 310 50 125 10 BWCU00321619601M02 600 20 100 0.8 260 50 125 10 BWCU00321619102M02 1000 20 100 1.0 230 50 125 10 BWCU00321619222M02 2200 20 100 1.2 200 50 125 10 Impedance Tolerance (Ω) (±%) BWCU00321619900M02 90 20 BWCU00321619121M02 120 BWCU00321619161M02 Test RDC IDC (Ω) Max (mA) 100 0.3 20 100 160 20 BWCU00321619221M02 220 BWCU00321619261M02 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current  Measure Equipment: Z:Agilent HP4287A+Agilent 16197A RDC:Chroma 16502 (Single Wire Test Value) IDC:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4291A Material/Impedance Analyzer Typical Impedance vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU Series Electrical Characteristics Rated Withstamd Insulation Voltage Voltage Resistance (Vdc) (Vdc) (MΩ) Min 1300 50 125 10 0.20 1300 50 125 10 100 0.25 1200 50 125 10 20 100 0.27 1000 50 125 10 120 20 100 0.30 900 50 125 10 BWCU00231512181M02 180 20 100 0.40 700 50 125 10 BWCU00231512261M02 260 20 100 0.60 700 50 125 10 Impedance Tolerance (Ω) (±%) BWCU00231512300M02 30 20 BWCU00231512420M02 42 BWCU00231512670M02 Test RDC IDC (Ω) Max (mA) 100 0.20 20 100 67 20 BWCU00231512900M02 90 BWCU00231512121M02 Part Number Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: M=±20%  Operating temperature range-40℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current.  Measure Equipment: Z:Agilent HP4291A RDC:HP4338B or Chroma 16502 (Single Wire Test Value) IDC:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4291A Material/Impedance Analyzer Typical Impedance vs. Frequency BWCU00231512900M02 CMM0805-900M-S 1000 IMPEDANCE(Ω) 100 COMMON MODE 10 NORMAL MODE 1 0.1 1 10 100 1000 10000 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_02 Series Packaging Specifications Tape Dimensions Reel Dimensions 4.0 ± 0.1 2.0 ± 0.05 1.5 +0.1/-0.0 T 1.75 ± 0.1 F BB W A K Trailer P O End O Blank part (160mm min.) O Blank Compartments with Cover Tape and Leader (330mm min.) Dimensions in mm Tape Dimensions TYPE Reel Dimensions Quantity A B T W P F K A B C D BWCU00160811 0.95 1.70 0.24 8 4 3.5 1.15 178 60 12 1.5 2000 BWCU00121008 1.15 1.45 0.24 8 4 3.5 1.00 178 60 12 1.5 2000 BWCU00201212 1.50 2.25 0.24 8 4 3.5 1.35 178 60 12 1.5 2000 BWCU00231512 1.60 2.42 0.26 8 4 3.5 1.14 178 60 12 1.5 2000 BWCU00321619 1.76 3.47 0.22 8 4 3.5 2.05 178 60 12 1.5 2000 PCS / Reel SMD Common Mode Choke – BWCU_03 Series BWCU_03 Series For HDMI, USB 3.0 A full series of common mode choke is designed for excellent noise attenuation and compact sizing for use in wide range of applications. Both standard series and custom designs are available. Features Applications  RoHS Compliant  HDMI  Miniature SMD type common mode filter for fully automated assembly  USB lines (for personal computers and peripheral), DVC, STB,  Excellent solderability LVDS, panel line for liquid display panels, etc. Product Identification Shape and Dimensions Recommended Pattern BWCU00121008 BWCU00201212 Dimensions in mm TYPE A B C D E F G H I BWCU00121008 1.25±0.2 1.00±0.2 0.80±0.1 0.32 0.33 0.36 1.00 0.59 1.75 BWCU00201212 2.05±0.2 1.25±0.2 1.20±0.2 0.50 0.40 0.50 1.27 0.80 2.60 SMD Common Mode Choke – BWCU_03 Series Electrical Characteristics Impedance Tolerance (Ω) (±%) BWCU00121008220Y03 22 25 BWCU00121008600Y03 60 BWCU00121008900Y03 90 Part Number Test Rated Withstamd Insulation Voltage Voltage Resistance (Vdc) (Vdc) (MΩ) Min 400 50 125 100 0.40 250 50 125 100 0.30 250 50 125 100 RDC IDC (Ω) Max (mA) Max 100 0.20 25 100 25 100 Frequency (MHz) Note: When ordering, please specify tolerance code. Tolerance: Y=±25%  Operating temperature range-40℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current.  Measure Equipment: Z:HP4286A/HP4287A/Agilent E4991A+Agilent16197A RDC:Chroma 16502 (Single Wire Test Value) IDC:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4291A Material/Impedance Analyzer Typical Impedance vs. Frequency Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00121008220Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00121008600Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00121008900Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series Electrical Characteristics Part Number Impedance Tolerance (Ω) (±%) Test Frequency (MHz) RDC IDC (Ω) Max (mA) Max Withstamd Insulation Voltage Voltage Resistance (Vdc) (Vdc) (MΩ) Min Rated BWCU00201212500Y03 50 25 100 0.20 500 50 125 10 BWCU00201212670Y03 67 25 100 0.30 500 50 125 10 BWCU00201212900Y03 90 25 100 0.30 500 50 125 10 BWCU00201212121Y03 120 25 100 0.35 330 50 125 10 BWCU00201212131Y03 130 25 100 0.40 300 50 125 10 Note: When ordering, please specify tolerance code. Tolerance: Y=±25%  Operating temperature range-40℃~105℃(Including self - temperature rise)  IDC for Inductance drop 10% from its value without current.  Measure Equipment: Z:HP4286A/HP4287A/Agilent E4991A+Agilent16197A RDC:Chroma 16502 (Single Wire Test Value) IDC:HP4284A+HP42841A/HP4285A+HP42841A Insulation Resistance:Agilent HP4339B Test Instruments:HP4291A Material/Impedance Analyzer Typical Impedance vs. Frequency 1000 121 COMMON MODE 131 900 670 IIMPEDANCE(Ω) 100 500 10 131 121 900 1 670 NORMAL MODE 500 0.1 1 10 100 1000 FREQUENCY(MHz) Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. 10000 SMD Common Mode Choke – BWCU_03 Series BWCU00201212500Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00201212670Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00201212900Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00201212121Y03 Insertion Loss For HDMI2.0 Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI2.0 Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI2.0 Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series BWCU00201212131Y03 Insertion Loss For HDMI Testing: Insertion Loss For USB3.0 Testing: TDR For HDMI Testing: TDR For USB3.0 Testing: Eye Diagram For HDMI Testing: Eye Diagram For USB3.0 Testing: Please be sure to request approval specifications that provide further details of the products. Kindly note that the content of these specifications are subject to change or may be discontinued without prior notice. This product may not be designed/used in medical or high risk applications without Chilisin approval. Please contact our sales department before ordering. SMD Common Mode Choke – BWCU_03 Series Packaging Specifications Tape Dimensions Reel Dimensions 4.0 ± 0.1 2.0 ± 0.05 1.5 +0.1/-0.0 T 1.75 ± 0.1 F B B W A K Trailer P O C Leader End O Blank part (160mm min.) O Blank Compartments with Cover Tape End and Leader (330mm min.) Dimensions in mm Tape Dimensions Reel Dimensions Quantity TYPE A B T W P F K A B C D PCS / Reel BWCU00121008 1.15 1.45 0.25 8 4 3.5 1.00 178 60 12 1.5 2000 BWCU00201212 1.50 2.25 0.24 8 4 3.5 1.35 178 60 12 1.5 2000
BWCU00121008900M02 价格&库存
很抱歉,暂时无法提供与“BWCU00121008900M02”相匹配的价格&库存,您可以联系我们找货
