ST-2
SURFACE MOUNT CERMET TRIMMERS (SINGLE TURN)
RoHS compliant
INTERNAL STRUCTURE
8
2
3
6
4
7
1
!1
9
5
!0
Part name
■ FEATURES
RoHS compliant
Compact and low-profile □2 mm single turn type
Sealed constructio
Resin materials are UL Recognized 94V-0 or 94V-1 equivalent
Material
①
Housing
②
Rotor
Polyphenylenesulphide
③
Wiper
Stainless steel (SUS 304)
④
Terminal #2
⑤
Terminal #1, #3
⑥
Cover
⑦
substrate
⑧
Pin
Blass, Sn-plated
⑨
“O” ring
Silicone rubber
⑩
Terminations
Ag-Pd cermet
⑪
Resistive element
RuO2 cermet
Epoxy
Copper alloy, Sn-Cu-plated
Ceramic
■ PART NUMBER DESIGNATION
S T - 2 T A 1 0 0Ω ( 1 0 1 )
Series name
Resistance code
Form of packaging
Resistance value
T:Taping (Reel)
Blank:Bulk in plastic bag
Product shape (Shape of terminal)
A:J-hook (Top adjustment)
※ Please refer to the LIST OF PART NUMBERS when placing orders.
ST-2
SURFACE MOUNT TRIMMERS
■ LIST OF PART NUMBERS
Adjustment
position
Form of packaging
Shape of
terminal
Top adjustment A ( J-hook
Pieces in package
〈Nominal resistance values〉
Taping (reel)
Plastic bag
ST-2TA
ST-2A
500 pcs./reel
100 pcs./pack
Resistance tolerance
200 Ω
500 Ω
1 kΩ
2 kΩ
5 kΩ
20 kΩ
50 kΩ
100 kΩ
200 kΩ
500 kΩ
1 MΩ
10 kΩ
Fig.1
■ ELECTRICAL CHARACTERISTICS
Nominal resistance range
100 Ω
※ The part numbers on the left are all available with the
respective combination of (Fig. 1).
※ Verify the above part numbers when placing orders.
※ Taping version is not sold separately and must be purchased in
reel units.
■ MECHANICAL CHARACTERISTICS
100 Ω ~ 1 MΩ
Mechanical angle
270 ° (1 turn)
± 20 %
Operating torque
5 mN·m {51 gf·cm} maximum
Power ratings
0.1 W (70 °C) 0 W (125 °C)
Stop strength
8 mN·m {78.4 gf·cm} minimum
Resistance law
Linear law
Rotational life
50 cycles [ΔR/R ≦ ± (2 Ω + 5 %)]
Maximum input voltage
DC50 V or power rating, whichever is smaller
Thrust to rotor
3 N {0.31 kgf} minimum
Maximum wiper current
I = P/R
A
Effective electrical angle
Solderability
245 ± 3 °C, 2 ~ 3 s
240 ° (1 turn)
Shear (Adhesion)
5 N {0.51 kgf} 10 s
End resistance
1 % or 2 Ω , whichever is greater
Substrate bending
Width 90 mm, bend 3 mm, 5 s, 1 time
C.R.V.
2 % or 3 Ω , whichever is greater
Pull-off strength
Within power ratings
Operating temp. range
− 55 ~ 125 °C
Temp. coefficient
± 150 10-6/°C
Insulation resistance
Dielectric strength
Net weight
1000 MΩ minimum (DC500 V)
AC500 V, 60 s
Approx. 0.032 g
5 N {0.51 kgf} 10 s
{ }:Reference only
ST-2
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Thermal shock
Humidity
Shock
Test conditions
Specifications
− 65 ~ 125 °C
(0.5 h), 5 cycles
− 10 ~ 65 °C (80 ~ 98 %),
10 cycles, 240 h
981 m/s2, 6 ms
6 directions for 3 times each
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
Vibration
(Amplitude) 1.52 mm or
(Acceleration) 196 m/s2,
10 ~ 2000 Hz, 3 directions, 12 times each
Load life
70 °C, 0.1 W
1000 h
Low temp. operation
− 55 °C, 2 h
High temp. exposure
125 °C, 250 h
Immersion seal
85 °C, 60 s
[ Δ R/R ≦ 2 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 1 %]
[ Δ R/R ≦ 2 %]
[S.S. ≦ 2 %]
[ Δ R/R ≦ 3 %]
[S.S. ≦ 2 %]
No leaks (No continuous bubbles)
Reflow Peak temperature : 255 °C
(Please refer to the profile below)
■ MAXIMUM INPUT RATINGS
Nominal resistance
values ( Ω )
Maximum input
voltage (V)
Resistance code
Maximum wiper
current (mA)
100
200
500
101
201
501
3.16
4.47
7.07
31.6
22.4
14.1
1 k
2 k
5 k
10 k
20 k
50 k
102
202
502
103
203
503
10.0
14.1
22.3
31.6
44.7
50.0
10.0
7.1
4.5
3.2
2.2
1.0
100 k
200 k
500 k
1 M
104
204
504
105
50.0
50.0
50.0
50.0
0.5
0.25
0.1
0.05
[ Δ R/R ≦ ± 1 %]
Soldering heat Flow soldering:
260 ± 3 °C, 5 ~ 6 s, two times
maximum
Manual soldering:
350 ± 10 °C, 3 ~ 4 s
Δ R/R:Change in total resistance
S.S. :Setting stability
〈Reflow profile for soldering heat evaluation〉
■ RECOMMENDED P.C.B. PAD OUTLINE DIMENSIONS
(Unit : mm)
Peak : 250
+5
°C
0.8
(°C)
250
100
50
150 °C
90 ± 30 s
150
180 °C
Pre Heating Zone
30 ± 10 s
Heating time
Soldering Zone
リフロー回数:2回 Reflow : two times maximum
0.65
0.6
0.65
0.8
Temperature
Over 230 °C
200
Note) The zero point is the center of mounting.
ST-2
■ OUTLINE DIMENSIONS
Unless otherwise specified, tolerance : ± 0.3 (Unit : mm)
● ST-2A
①
Top adjustment
③
CW rotation
②
※ Note the terminal position.
0.7
t = 0.1
2 – 0.35
Resistance code
2.4
③
1.7
0.45
2.8
(1.9)
②
0.45
0.35 W × 1.5 L × 0.3 D
Production date code
①
1.25
■ ST-2/ST-32 ADJUSTMENT TOOL
● Compliant with two models (ST-2/ST-32)
Recommended models
130
φ 1.90
Material : Polyoxymethylene
1.20
For ST-32
■ Recommended screwdrivers for use
※ Note
Manufacturer
Model
ENGINEER INC.
DA-54
: Please do not use the tool for purposes other than adjustment of electronic components.
φ6
ST-2
φ 1.7
ST-32
Tip thickness 0.35
Tip 1.4 × 1.4
Tip thickness 0.4
Tip 1.7 × 1.1
For ST-2
ST-2
■ PACKAGING SPECIFICATIONS
● Taping version is packaged in 500 pcs. per reel.
Orders will be accepted for units of 500 pcs., i.e., 500, 1000, 1500 pcs., etc.
● Taping version is boxed with one reel (500 pcs.).
Maximum number of consecutive missing pieces=2
Leader length and reel dimension are shown in the diagrams below.
● EMBOSSED TAPE DIMENSIONS
● REEL DIMENSIONS
(Conforms to JIS C 0806-3)
Empty
Filled
(In accordance with EIAJ ET-7200A)
Empty
(Unit: mm)
13
Head
φ 21±0.8
40 mm min.
2±0.5
20 pitches min.
Leader
400 mm min.
Direction of feed
φ 13±0.2
φ 180 –1.5
1
5.5 ± 0.05
2
3
引き出し方向
Direction of feed
● Unit of bulk in a plastic bag is 100 pcs. per pack.
● Boxing of bulk in a plastic bag is performed with
500 pcs. per box.
0.3 ± 0.1
装着例
Installation example
(ST-2A)
12
+0.1
φ1
2 ± 0.05
1.75 ± 0.1
● ST-2TA
4 ± 0.1
φ 60 +10
End
+1
15.4±1
很抱歉,暂时无法提供与“ST-2A202”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+24.33920100+3.15278
