PA40-44-P64-DZ-QF
PA40-44-P64-DZ-QF
    LOGICALSYSTEMS
    ADAPTER 4-PIN ZIF TO 44PIN QFP
PA40-44-P64-DZ-QF 数据手册
PA40-44-P64-Dx-QF Data Sheet 40 pin DIP socket/44 pin QFP plug Supported Device/Footprints Adapter Dimensions The PA40-44-P64-Dx-QF adapter accepts 40 pin DIP devices and has a removable 44 pin QFP solder-down plug. This allows DIP devices, or emulators with DIP plugs, to be used during development of QFP based products. Other devices that require the same wiring and footprint would also be supported. The following DIP device footprints are converted to the indicated QFP footprint. Microchip: PIC16C64,PIC16C64A, PIC16C65, PIC16C65A, PIC16C74, PIC16C74A, PIC16C77 Footprint: Same device 44MQFP This QFP plug will fit most 44 pin. 0.8mm pitch, QFP land patterns. Usually the pads extend from the body past the tip of the device leads. This plug will fit on pads that have a minimum span of 10.0mm or less and a maximum span of 12.0mm or more. Inner pad span Outer pad span 10.0mm or less 12.0mm or more PA40-44-P64-DP-QF The QFP Plug’s leads are dimensioned as follows. Plug PQF-44 Body 10.0 mm typ Knee 9.6 mm typ Tip 12.0 mm typ Pitch 0.8 mm Adapter Construction The adapter is made up of 2 or 3 sub-assemblies. They assemble via connectors making the adapter modular. This way the sub-assemblies can be replaced easily. When disassembling the adapter take care not to bend the pins. When reassembling the adapter note the pin 1 indicators to align the parts correctly. The following chart lists the adapters described by this datasheet and their subassemblies. Adapter PA40-44-P64-DZ-QF PA40-44-P64-DP-QF Test Socket 40-ADZ * none * Circuit Board P64-DQ P64-DQ QFP Plug PQF-44 PQF-44 * The circuit board always has a 40 pin DIP production socket. The optional test socket plugs into the production socket. Test Socket LSC # 40ADZ Style DIP ZIF Mfgr/Pn Aries 40-6554-11 QFP Plug The QFP plug is removable. One is included with the adapter. Additional QFP plugs may be ordered as PQF-44. This allows the adapter to be used on several prototypes without desoldering. Logical Systems Corporation PO Box 6184, Syracuse, NY 13217-6184 USA Tel (315) 478-0722, FAX (315) 479-6753 S Y S T E M S www.logicalsys.com, Email: info@logicalsys.com PA40-44-P64-DZ-QF Note: QFP Pin 1 is in the lower right corner. Microchip packaged the QFP with a 180 degree rotation from the DIP & PLCC. Adapter Wiring The following chart shows the connections from the DIP device to the adapter’s QFP plug. DEVICE SIGNAL 1 MCLR/Vpp 2 RA0 3 RA1 4 RA2 5 RA3 6 RA4/TOCKI 7 RA5/SS 8 RE0/RD 9 RE1/WR 10 RE2/CS 11 VDD 12 VSS 13 OSC1/CLKIN 14 OSC2/CLKOUT 15 RC0/T1CKI N/C N/C 16 RC1/T1CKO 17 RC2/CCP1 18 RC3/SCK/SCL 19 RD0/PSP0 20 RD1/PSP1 PLUG PLUG 18 17 19 16 20 15 21 14 22 13 23 12 24 11 25 10 26 9 27 8 28 7 29 6 30 5 31 4 32 3 33 2 34 1 35 44 36 43 37 42 38 41 39 40 SIGNAL RB 7 RB 6 RB 5 RB 4 N/C N/C RB 3 RB 2 RB 1 RB0/INT VDO VSS RD7/PSP7 RD6/PSP6 RD5/PSP5 RD4/PSP4 RC7 RC6 RC5/SDO RC4/SDI/SDA RD3/PSP3 RD2/PSP2 DEVICE 40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 PA40-44-P64-Dx-QF Data Sheet Doc: 40P64DQ.DOC Rev 06/19/00 Page 1 of 1
PA40-44-P64-DZ-QF 价格&库存
很抱歉,暂时无法提供与“PA40-44-P64-DZ-QF”相匹配的价格&库存,您可以联系我们找货
