TPD2E007DCKR
TPD2E007DCKR
    LEIDITECH(雷卯电子)
    SOT-23
    ESD 15V截止
TPD2E007DCKR 数据手册
TPD2E007DCKR BIDIRECTIONAL TVS DIODE ARRAY FOR LATCH-UP PROTECTION Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 15V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 10A (8/20μs) RoHS Compliant Dimensions SOT-23 Pin Configuration Applications ● ● ● ● ● ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers RS-232 Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-23 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 350 W ±30 VESD Kv ±30 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ Rev : 01.06.2014 1/3 www.leiditech.com TPD2E007DCKR Electrical Characteristics(TA=25°C unless otherwise specified) Vc Device Marking Part Number TPD2E007DCKR 15C VRWM (V) VBR (V) IT (mA) VC @1A 15 16.7 1 24 (Max) 38 (@A) IR μA (Max) C (Pf) (Typ.) 1 60 10 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) Rev : 01.06.2014 2/3 www.leiditech.com TPD2E007DCKR SOT-23 Package Outline & Dimensions Millimeters Inches Symbol Soldering Footprint Min. Nom. Max. Min. Nom. Max. A 0.89 1.00 1.11 0.035 0.040 0.044 A1 0.01 0.06 0.10 0.001 0.002 0.004 b 0.37 0.44 0.50 0.15 0.18 0.020 c 0.09 0.13 0.18 0.003 0.005 0.007 D 2.80 2.90 3.04 0.110 0.114 0.120 E 1.20 1.30 1.40 0.047 0.051 0.055 e 1.78 1.90 2.04 0.070 0.075 0.081 L 0.35 0.54 0.69 0.014 0.021 0.029 HE 2.10 2.40 2.64 0.083 0.094 0.104 Symbol Millimeters Inches X 0.80 0.031 X1 0.95 0.037 Y 0.90 0.035 Z 2.00 0.079 Shanghai Leiditech Electronic Co.,Ltd Email: sale1@leiditech.com Tel : +86- 021 50828806 Fax : +86- 021 50477059 Rev : 01.06.2014 3/3 www.leiditech.com
TPD2E007DCKR
物料型号:TPD2E007DCKR
器件简介:双向TVS二极管阵列,用于锁存保护。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 超低漏电流:纳安级别 - 工作电压:15V - 低钳位电压 - 符合以下标准:IEC 61000-4-2 (ESD) 空气放电 ±30kV,接触放电 ±30kV;IEC61000-4-4 (EFT) 40A (5/50ns);IEC61000-4-5 (闪电) 10A (8/20μs) - 符合RoHS标准
功能详解: - 峰值脉冲功率:350W(8/20μs) - 工作温度范围:-55℃ 至 +125℃ - 存储温度范围:-55℃ 至 +150℃
应用信息: - USB 2.0 电源和数据线 - 机顶盒和数字电视 - 数字视频接口(DVI) - 笔记本电脑 - RS-232端口 - 10/100以太网
封装信息: - 封装类型:SOT-23 - 引脚完成:无铅 - UL阻燃等级:94V-0 - 每卷数量:3,000件 - 卷径:7英寸
电气特性: - 型号:TPD2E007DCKR - VRWM (V):15 - VBR (V):16.7 - IT (mA):1 - VC @1A:24 - Vc IR μA (Max):38 - C (Pf) (Typ.):10 - C (Pf) (Max):60
特性曲线图包括8/20μs脉冲波形、ESD脉冲波形(根据IEC 61000-4-2)和功率降额曲线。
TPD2E007DCKR 价格&库存
很抱歉,暂时无法提供与“TPD2E007DCKR”相匹配的价格&库存,您可以联系我们找货
TPD2E007DCKR
    • 1+0.44980
    库存:3
