ASMD1812-260-16V
ASMD1812-260-16V
    JDTFUSE(集电通)
    SMD1812
ASMD1812-260-16V 数据手册
PRODUCT DATASHEET ASMD1812 Series Surface Mount PTC Devices ASMD1812 Series Surface Mount PTC Devices Description The ASMD1812 series provides surface mount resettable overcurrent protection with holding current from 0.1A to 4.0A. This series offers complete portfolio in terms of holding current and working voltage, and is suitable for wide range of applications. Features ● RoHS compliant and lead-free ● Low profile ● Halogen-free ● Fast response to fault current ● Compact design saves board space ● Compatible with high temperature solders Agency Approvals Agency Applications File Number E472196 ● USB hubs, ports and peripherals ● Motherboard USB & IEEE 1394 protection ● Set-top-box and HDMI ● Optical disk drives ● Game console port protection ● General electronics Regulation Standard 2002/95/EC EN14582 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 1/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices Performance Specification Model V max (V dc) I max (A) I hold I trip Pd @25°C (A) @25°C (A) Typ. (W) Maximum Time To Trip Resistance Current (A) Time (Sec) R i min R1max (Ω) (Ω) ASMD1812-010 30.0 100 0.10 0.30 0.8 0.5 1.50 0.75 15.0 ASMD1812-010-33V 33.0 100 0.10 0.30 0.8 0.5 1.50 0.75 15.0 ASMD1812-010-60V 60.0 100 0.10 0.30 0.8 0.5 1.50 0.75 15.0 ASMD1812-014 60.0 100 0.14 0.34 0.8 1.5 0.15 0.65 6.00 ASMD1812-014-33V 33.0 100 0.14 0.34 0.8 1.5 0.15 0.65 6.00 ASMD1812-020 30.0 100 0.20 0.40 0.8 8.0 0.02 0.35 5.00 ASMD1812-020-33V 33.0 100 0.20 0.40 0.8 8.0 0.02 0.35 5.00 ASMD1812-020-60V 60.0 100 0.20 0.40 0.8 8.0 0.02 0.35 5.00 ASMD1812-030 30.0 100 0.30 0.60 0.8 8.0 0.10 0.25 3.00 ASMD1812-030-33V 33.0 100 0.30 0.60 0.8 8.0 0.10 0.25 3.00 ASMD1812-030-60V 60.0 100 0.30 0.60 0.8 8.0 0.10 0.25 3.00 ASMD1812-050 15.0 100 0.50 1.00 0.8 8.0 0.15 0.15 1.00 ASMD1812-050-33V 33.0 100 0.50 1.00 0.8 8.0 0.15 0.15 1.00 ASMD1812-050-60V 60.0 100 0.50 1.00 0.8 8.0 0.15 0.15 1.40 ASMD1812-075 13.2 100 0.75 1.50 0.8 8.0 0.20 0.09 0.45 ASMD1812-075-24V 24.0 100 0.75 1.50 0.8 8.0 0.20 0.09 0.45 ASMD1812-075-33V 33.0 100 0.75 1.50 0.8 8.0 0.20 0.09 0.45 ASMD1812-110 8.00 100 1.10 2.20 0.8 8.0 0.30 0.045 0.25 ASMD1812-110-16V 16.0 100 1.10 2.20 0.8 8.0 0.30 0.045 0.25 ASMD1812-110-24V 24.0 100 1.10 2.20 0.8 8.0 0.30 0.045 0.25 ASMD1812-110-33V 33.0 100 1.10 2.20 0.8 8.0 0.30 0.045 0.25 ASMD1812-125 16.0 100 1.25 2.50 0.8 8.0 0.40 0.05 0.20 ASMD1812-150 8.00 100 1.50 3.00 0.8 8.0 0.50 0.04 0.16 ASMD1812-150-12V 12.0 100 1.50 3.00 0.8 8.0 0.50 0.04 0.16 ASMD1812-150-24V 24.0 100 1.50 3.00 0.8 8.0 0.50 0.04 0.16 ASMD1812-160 8.00 100 1.60 2.80 0.8 8.0 1.00 0.03 0.13 ASMD1812-200 8.00 100 2.00 4.00 0.8 8.0 2.00 0.02 0.10 ASMD1812-200-16V 16.0 100 2.00 4.00 0.8 8.0 2.00 0.02 0.10 ASMD1812-200-24V 24.0 100 2.00 4.00 0.8 8.0 2.00 0.02 0.10 ASMD1812-200-30V 30.0 100 2.00 4.00 0.8 8.0 2.00 0.02 0.10 ASMD1812-260 8.00 100 2.60 5.00 0.8 8.0 2.50 0.01 0.05 ASMD1812-260-16V 16.0 100 2.60 5.00 0.8 8.0 2.50 0.01 0.05 ASMD1812-300 8.00 100 3.00 5.00 0.8 8.0 4.00 0.01 0.04 ASMD1812-300-12V 12.0 100 3.00 5.00 0.8 8.0 4.00 0.01 0.04 ASMD1812-300-16V 16.0 100 3.00 5.00 0.8 8.0 4.00 0.01 0.04 ASMD1812-350 6.00 100 3.50 6.00 2.0 10.0 4.00 0.008 0.035 ASMD1812-350-16V 16.0 100 3.50 6.00 2.0 10.0 4.00 0.008 0.035 ASMD1812-400 6.00 100 4.00 7.00 2.0 10.0 4.00 0.005 0.025 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 2/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Pd Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change   Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Thermal Derating Curve Percentage of Derated Current Derating Curves for ASMD1812 Series 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 Temperature (°C ) JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 3/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices 4A 3.0A 3.5A 2.6A 1.6A 2.0A 1.5A 1.25A 0.75A 1.1A 0.30A 0.5A 0.14A 100 0.20A 0.10A Average Time-Current Curve TIME IN SECONDS 10 1 0.1 0.01 0.1 1 10 CURRENT IN AMPERES Thermal Derading Chart Model Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) - 40°C - 20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C ASMD1812-010 0.16 0.14 0.12 0.10 0.08 0.07 0.06 0.05 0.03 ASMD1812-014 0.23 0.19 0.17 0.14 0.12 0.10 0.09 0.08 0.06 ASMD1812-020 0.29 0.26 0.23 0.20 0.17 0.15 0.14 0.12 0.10 ASMD1812-030 0.44 0.39 0.35 0.30 0.26 0.23 0.21 0.18 0.15 ASMD1812-050 0.59 0.57 0.55 0.50 0.45 0.43 0.35 0.30 0.23 ASMD1812-075 1.10 0.99 0.87 0.75 0.63 0.57 0.49 0.45 0.35 ASMD1812-110 1.60 1.45 1.28 1.10 0.92 0.83 0.71 0.66 0.52 ASMD1812-125 2.00 1.75 1.52 1.25 1.00 0.95 0.90 0.75 0.53 ASMD1812-150 2.10 1.96 1.77 1.50 1.23 1.09 0.95 0.82 0.61 ASMD1812-160 2.30 2.05 1.88 1.60 1.26 1.12 0.98 0.84 0.63 ASMD1812-200 2.88 2.61 2.25 2.00 1.80 1.66 1.45 1.09 0.80 ASMD1812-260 3.90 3.42 2.96 2.60 2.33 2.07 1.94 1.35 1.00 ASMD1812-300 4.15 3.76 3.46 3.00 2.55 2.28 2.01 1.61 1.33 ASMD1812-350 4.84 4.39 4.04 3.50 2.98 2.66 2.35 1.88 1.55 ASMD1812-400 5.80 5.20 4.60 4.00 3.35 3.12 2.75 2.45 2.10 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 4/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices Soldering Parameters TP 20~40 S TP 260 Ramp-up Profile Feature Critical Zone TL to TP TL 217 tL Tsmax Temperature (°C ) Preheat Tsmin Ramp-down ts Preheat 60~180 s 25 3℃/second mac. (Ts max to T p) 60~150 s 200 150 Average Ramp-Up Rate Pb-Free Assembly t 25°C to peak -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: Time Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Physical Dimensions(mm.) Termination Pad Characteristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 5/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices A Model B C D E Min. Max. Min. Max. Min. Max. Min. Min. ASMD1812-010 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-010-33V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-010-60V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-014 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-014-33V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-020 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-020-33V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-020-60V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-030 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-030-33V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-030-60V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-050 4.37 4.73 3.07 3.41 0.4 1.0 0.3 0.25 ASMD1812-050-33V 4.37 4.73 3.07 3.41 0.4 1.0 0.3 0.25 ASMD1812-050-60V 4.37 4.73 3.07 3.41 0.6 1.5 0.3 0.25 ASMD1812-075 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-075-24V 4.37 4.73 3.07 3.41 0.6 1.3 0.3 0.25 ASMD1812-075-33V 4.37 4.73 3.07 3.41 0.6 1.3 0.3 0.25 ASMD1812-110 4.37 4.73 3.07 3.41 0.4 1.0 0.3 0.25 ASMD1812-110-16V 4.37 4.73 3.07 3.41 0.4 1.0 0.3 0.25 ASMD1812-110-24V 4.37 4.73 3.07 3.41 0.6 1.3 0.3 0.25 ASMD1812-110-33V 4.37 4.73 3.07 3.41 0.6 1.3 0.3 0.25 ASMD1812-125 4.37 4.73 3.07 3.41 0.4 1.0 0.3 0.25 ASMD1812-150 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-150-12V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-150-24V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-160 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-200 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-200-16V 4.37 4.73 3.07 3.41 0.5 1.1 0.3 0.25 ASMD1812-200-24V 4.37 4.73 3.07 3.41 0.5 1.5 0.3 0.25 ASMD1812-200-30V 4.37 4.73 3.07 3.41 0.5 1.5 0.3 0.25 ASMD1812-260 4.37 4.73 3.07 3.41 0.5 1.5 0.3 0.25 ASMD1812-260-16V 4.37 4.73 3.07 3.41 0.5 1.5 0.3 0.25 ASMD1812-300 4.37 4.73 3.07 3.41 0.8 1.5 0.3 0.25 ASMD1812-300-12V 4.37 4.73 3.07 3.41 0.8 1.5 0.3 0.25 ASMD1812-300-16V 4.37 4.73 3.07 3.41 0.8 1.5 0.3 0.25 ASMD1812-350 4.37 4.73 3.07 3.41 0.8 1.5 0.3 0.25 ASMD1812-350-16V 4.37 4.73 3.07 3.41 0.8 1.5 0.3 0.25 ASMD1812-400 4.37 4.73 3.07 3.41 0.8 1.5 0.3 0.25 JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 6/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices Packaging Quantity and Marking 3.2±0.1 Part Number 3.2±0.1 Quantity ASMD1812 Series 1,500 pcs/reel ASMD1812-350-16V 1,000 pcs/reel ASMD1812-400 1.78±0.1 Tape & reel packaging per EIA481-1 1.78±0.1 Tape And Reel Specifications (mm) Governing Specifications EIA 481-1 W 12 ± 0.3 P0 4.0 ± 0.10 P1 8.0 ± 0.10 P2 2.0 ± 0.05 A0 3.5 ± 0.10 B0 5.1 ± 0.10 B1max. 5.9 D0 1.50 + 0.1, -0 F 5.5 ± 0.05 E1 1.75 ± 0.10 E2min. 10.25 T 0.6 T1max. 0.1 K0 0.9 ± 0.1 Leader min. 390 Trailer min. 160 Reel Dimensions   A max. 178 N min. 60 W1 12.4 ± 0.5 W2 18.4 Storage And Handling ● Storage conditions:40°C max, 70% R.H. ● Devices may not meet specified performance if storage conditions are exceeded.Technology Corp. JDT Fuse Industrial Co., Ltd www.jdtfuse.com P1 P2 D0 P0 E1 F W T D2 K0 A0 B0 H W4 W3 D C W2 W F W1 H1 Page 7/8 Revised 08/19/21 ASMD1812 Series Surface Mount PTC Devices Part Number System ASMD 1812 - Special Voltage Rating(Optional) Holding Current Rating Device Dimensions: Length/width(Unit:1/100 inch) Size 4532 mm / 1812 inch Surface Mount Device Cross Reference Cross Reference Model Tyco / PolySwitch® Littelfuse / POLY-FUSE® Polytronics / EVERFUSE® ASMD1812-010 miniSMDC010F 1812L010 SMD1812P010TF ASMD1812-014 miniSMDC014F 1812L014 SMD1812P014TF ASMD1812-020 miniSMDC020F 1812L020 SMD1812P020TF ASMD1812-030 - 1812L035 SMD1812P030TF ASMD1812-050 miniSMDC050F 1812L050 SMD1812P050TF ASMD1812-050-33V miniSMDC050F/33V 1812L050/30 SMD1812P050TF/30 ASMD1812-050-60V - - - ASMD1812-075 miniSMDC750F 1812L075 SMD1812P075TF ASMD1812-075-24V miniSMDC750F/24V 1812L075/24 SMD1812P075TF/24 ASMD1812-110 miniSMDC110F 1812L110 SMD1812P110TF ASMD1812-110-16V miniSMDC110F/16 1812L110/16 SMD1812P110TF/16 ASMD1812-110-24V miniSMDC110F/24 1812L110/24 SMD1812P110TF/24 ASMD1812-110-33V miniSMDC110F/33 1812L110/33 SMD1812P110TF/33 ASMD1812-125 miniSMDC125F 1812L125 SMD1812P125TF ASMD1812-150 miniSMDC150F 1812L150 SMD1812P150TF ASMD1812-150-16V miniSMDC150F/12 1812L150/12 SMD1812P150TF/12 ASMD1812-150-24V miniSMDC150F/24 1812L150/24 SMD1812P150TF/24 ASMD1812-160 miniSMDC160F 1812L160 SMD1812P160TF ASMD1812-200 miniSMDC200F 1812L200 SMD1812P200TF ASMD1812-260 miniSMDC260F 1812L260 SMD1812P260TF ASMD1812-300 miniSMDC300F 1812L300 SMD1812P300TF ASMD1812-300-30V miniSMDC300F/30 1812L300/30 SMD1812P300TF/30 ASMD1812-350 - - - ASMD1812-400 - - - “PolySwitch” is a registered trademark of Tyco Electronics. “POLY-FUSE” is a registered trademark of Littelfuse,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. JDT Fuse Industrial Co., Ltd www.jdtfuse.com Page 8/8 Revised 08/19/21
ASMD1812-260-16V
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外遥控接收器。
2. 器件简介:EL817是一款用于红外遥控系统的接收器,具有高灵敏度和低功耗的特点。
3. 引脚分配:EL817共有3个引脚,分别为Vcc、Out和GND。
4. 参数特性:工作电压范围为3-6V,工作电流小于0.5mA,接收频率范围为38kHz。
5. 功能详解:EL817能够接收红外信号并输出相应的电信号,用于控制各种电子设备。
6. 应用信息:广泛应用于电视、空调、音响等家用电器的遥控系统中。
7. 封装信息:EL817采用SOP16封装,尺寸为7.5mm x 3mm。
ASMD1812-260-16V 价格&库存
很抱歉,暂时无法提供与“ASMD1812-260-16V”相匹配的价格&库存,您可以联系我们找货
ASMD1812-260-16V
  • 5+0.54439
  • 50+0.43034
  • 150+0.37332
  • 1500+0.33055
  • 3000+0.29633
  • 4500+0.27923
库存:2508
