ULC0511CDN
ULC0511CDN
    JKSEMI(金开盛)
    ULC0511CDN
ULC0511CDN 数据手册
ULC0511CDN 1-Line Bi-directional Low Capacitance TVS Diode DESCRIPTION The ULC0511CDN is a bi-directional TVS diode, utilizing leading monolithic silicon technology to provide fast resp -onse time, very low capacitance and low ESD clamping voltage, making this device an ideal solution for protecti -ng voltage sensitive data and power line.The ULC0511 CDN complies with the IEC 61000-4-2 (ESD) standard with ±15kV air and ±8kV contact discharge. It is assembl -ed into an ultra-small 1.0x0.6x0.5mm lead-free DFN pac -kage. The small size and very low capacitance make UL C0511CDN an ideal choice to protect cell phone, digital cameras, audio players, data interface and many other portable applications. APPLICATIONS  Cellular Handsets and Accessories.  Personal Digital Assistants.  Notebooks and Handhelds.  Portable Instrumentation.  Digital Cameras.  Peripherals.  Audio Players.  Keypads, Side Keys, USB 2.0, LCD Displays. FEATURES  Ultra small package: 1.0x0.6x0.5mm.  Protects one data or power line.  Ultra low leakage: nA level.  Working voltage: 5V.  Low clamping voltage.  2-pin leadless package.  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV.  – IEC61000-4-5 (Lightning) 2A (8/20μs). MECHANICAL CHARACTERISTICS  Package: DFN1006-2 (1.0×0.6×0.5mm)  Lead Finish: NiPdAu  Case Material: “Green” Molding Compound.  UL Flammability Classification Rating 94V-0  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See BelowDFN10062(0402) Package.  Tape & Reel : 10,000pcs.  Reel Size : 7 inch.  RoHS Compliant. Http://www.jksemi.com ULC0511CDN ULC0511CDN DEVICE CHARACTERISTICS Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol ESD per IEC 61000−4−2 (Air) Value ±15 VESD ESD per IEC 61000−4−2 (Contact) kV ±8 TJ −55 to +125 °C Tstg −55 to +150 °C Operating Temperature Range Storage Temperature Range Unit ELECTRICAL CHARACTERISTICS(TA=25°C unless otherwise specified) Parameter Symbol Test Condition Reverse Working Voltage VRWM Breakdown Voltage VBR Reverse Leakage Current IR Clamping Voltage VC Junction Capacitance CJ Min Typ Max 5.0 V 6 2.5 Unit V IT = 1mA 0.2 µA VRWM = 5.0 V 10 V IPP = 1A (8 x 20µs pulse) 3 pF VR = 0V, f = 1MHz ELECTRICAL PARAMETER Symbol Parameter IT Test Current IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @IPP Http://www.jksemi.com ULC0511CDN ULC0511CDN TYPICAL CHARACTERISTICS(TA=25°C unless otherwise Specified) Http://www.jksemi.com ULC0511CDN ULC0511CDN SOLDERING PARAMETERS Reflow Condition Pb-Free assembly (see FIG.5) Pre Hea -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp 3℃/sec. Max t (TL) to peak) Ts(max) to TL - Ramp-up Rate Reflow 3℃/sec. Max -Temperature(TL)(Liquid us) +217℃ -Temperature(tL) 60-150 secs. Peak Temp (Tp) +260(+0/-5)℃ Time within 5℃ of actual Peak Temp 30 secs. Max (tp) Ramp-down Rate 6℃/sec. Max xTime 25℃ to Peak Temp (TP) 8 min. Max Do not exceed +260℃ Http://www.jksemi.com ULC0511CDN ULC0511CDN DFN1006-2(0402) PACKAGE OUTLINE & DIMENSIONS SUGGESTED LAND PATTERN Website:http://www.jksemi.com For additional information, please contact your local SalesRepresentative. ©Copyright 2016, jksemi is a registered trademark of jksemi All rights arereserved Http://www.jksemi.com ULC0511CDN
ULC0511CDN 价格&库存
很抱歉,暂时无法提供与“ULC0511CDN”相匹配的价格&库存,您可以联系我们找货
