HY5012W/A
N-Channel Enhancement Mode MOSFET
Features
Pin Description
125V/300A
RDS(ON)=2.9 m (typ.) @ VGS=10V
Avalanche Rated
Lead Free and Green Devices Available
Reliable and Rugged
(RoHS Compliant)
G
D
S
G
TO-247A-3L
D
S
TO-3P-3L
Applications
Power Management for Inverter Systems.
N Channel MOSFET
Ordering and Marking Information
Package Code
W
HY5012
A
HY5012
Date Code
Assembly Material
YYXXXJWW G
YYXXXJWW G
YYXXX WW
G : Lead Free Device
W : TO-247A-3L
A : TO-3P-3L
Note: HUAYI lead -free products contain molding compounds/die attach materials and 100% matte tin plate
Termination finish;which are fully compliant with RoHS. HUAYI lead -free products meet or exceed the leadFree requirements of IPC/JEDEC J-STD-020 for MSL classification at lead-free peak reflow temperature.
HUAYI defines “Green” to mean lead-free (RoHS compliant) and halogen free (Br or Cl does not exceed
900ppm by weight in homogeneous material and total of Br and Cl does not exceed 1500ppm by weight).
HUAYI reserves the right to make changes, corrections, enhancements, modifications, and improvements to
this pr-oduct and/or to this document at any time without notice.
www.hymexa.com
1
V1.0
HY5012W/A
Absolute Maximum Ratings
Symbol
Parameter
Rating
Unit
Common Ratings (TC=25°C Unless Otherwise Noted)
VDSS
Drain-Source Voltage
125
VGSS
Gate-Source Voltage
±25
Maximum Junction Temperature
175
°C
55 to 175
°C
TC=25°C
300
A
TC=25°C
1100**
A
TC=25°C
300
TC=100°C
196
TC=25°C
500
TC=100°C
250
TJ
TSTG
IS
Storage Temperature Range
Diode Continuous Forward Current
V
Mounted on Large Heat Sink
IDM
Pulsed Drain Current *
ID
Continuous Drain Current
PD
Maximum Power Dissipation
RJC
Thermal Resistance-Junction to Case
0.3
RJA
Thermal Resistance-Junction to Ambient
40
A
W
°C/W
Avalanche Ratings
EAS
Avalanche Energy, Single Pulsed
mJ
2000***
L=0.5mH
Note: * Repetitive rating ; pulse width limiited by junction temperature
** Drain current is limited by junction temperature
*** VD=100V
Electrical Characteristics
Symbol
Parameter
(TC = 25C Unless Otherwise Noted)
Test Conditions
HY5012
Min.
Typ.
Max.
VGS=0V, IDS=250A
125
VDS=125V, VGS=0V
1
10
Unit
Static Characteristics
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
VGS(th)
IGSS
RDS(ON)*
TJ=85°C
V
A
Gate Threshold Voltage
VDS=VGS, IDS=250A
2
3
4
V
Gate Leakage Current
VGS=±25V, VDS=0V
±100
nA
Drain-Source On-state Resistance
VGS=10V, IDS=150A
2.9
3.6
m
ISD=150 A, VGS=0V
0.8
1.3
V
70
ns
134
nC
Diode Characteristics
VSD *
Diode Forward Voltage
trr
Reverse Recovery Time
Qrr
Reverse Recovery Charge
www.hymexa.com
ISD=150 A, dlSD/dt=100A/s
2
V1.0
HY5012W/A
Electrical Characteristics (Cont.)
Symbol
Parameter
Test Conditions
HY5012
Min.
Typ.
Max.
0.5
16300
1570
930
55
49
122
98
352
46
136
Unit
Dynamic Characteristics
RG
Gate Resistance
Ciss
Input Capacitance
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
td(ON)
Turn-on Delay Time
Tr
Turn-on Rise Time
td(OFF)
Turn-off Delay Time
Tf
VGS=0V,VDS=0V,F=1MHz
VGS=0V,
VDS=25V,
Frequency=1.0MHz
VDD=62.5 V, R G=6 ,
IDS=150A, VGS=10V,
Turn-off Fall Time
pF
ns
Gate Charge Characteristics
Qg
Total Gate Charge
Qgs
Gate-Source Charge
Qgd
Gate-Drain Charge
VDS=100V, VGS=10V,
IDS=150A
nC
Note * : Pulse test ; pulse width 300s, duty cycle2%.
www.hymexa.com
3
V1.0
HY5012W/A
Typical Operating Characteristics
Power Dissipation
Drain Current
ID - Drain Current (A)
Ptot - Power (W)
500
400
300
200
320
limited by package
280
240
200
160
120
100
80
o
TC=25 C
o
TC=25 C,VG=10V
40
20 40 60 80 100 120 140 160 180 200
Tc - Case Temperature (°C)
Safe Operation Area
1000
it
im
)L
n
s(o
Rd
100us
100
10ms
1ms
10
DC
1
0.1
10
1
100
400
VDS - Drain - Source Voltage (V)
Thermal Transient Impedance
Normalized Effective Transient
1
Duty = 0.5
0.1
0.2
0.1
0.01
0.05
0.02
0.001
0.01
Mounted on minimum pad
o
RJA : 40 C/W
Single
0.0001
0.0001
0.001
0.1
0.01
1
10
Square Wave Pulse Duration (sec)
www.hymexa.com
4
V1.0
HY5012W/A
Typical Operating Characteristics (Cont.)
Output Characteristics
Drain-Source On Resistance
4.0
400
VGS= 6,7,8,9,10V
350
RDS(ON) - On - Resistance (m)
5.5V
300
5V
250
200
4.5V
150
100
50
0.5
1.0
1.5
2.0
3.0
2.5
2.0
3.0
160
320
1.6
Normalized Threshold Vlotage
5.0
4.0
3.0
2.0
5
6
7
8
9
VGS - Gate - Source Voltage (V)
www.hymexa.com
1.4
1.2
1.0
0.8
0.6
0.4
0.2
-50 -25
10
400
IDS =250A
IDS=150A
4
240
6.0
1.0
VGS=10V
VDS - Drain-Source Voltage (V)
7.0
2.5
3.5
50
75 100 125 150 175
Tj - Junction Temperature (°C)
5
V1.0
HY5012W/A
Source-Drain Diode Forward
2.4
VGS = 10V
2.2
1000
IDS =150A
1.8
IS - Source Current (A)
Normalized On Resistance
2.0
1.6
1.4
1.2
1.0
0.8
o
Tj=175 C
100
o
Tj=25 C
10
0.6
0.4
o
0.2
-50 -25
RON@Tj=25 C: 2.9m
50
1
0.0
75 100 125 150 175
0.6
0.8
1.0
1.2
VSD - Source-Drain Voltage (V)
Capacitance
Gate Charge
1.4
10
Frequency=1MHz
20000
VDS= 100V
9
VGS - Gate-source Voltage (V)
Ciss
18000
C - Capacitance (pF)
0.4
22000
16000
14000
12000
10000
8000
6000
4000
Coss
2000
5
10
15
30
35
7
6
5
4
3
2
www.hymexa.com
8
1
Crss
IDS= 150A
100 150 200 250 300 350 400
QG - Gate Charge (nC)
6
V1.0
HY5012W/A
Avalanche Test Circuit
Switching Time Test Circuit
Gate Charge Test Circuit
www.hymexa.com
7
V1.0
HY5012W/A
Device Per Unit
Package Type
Unit
Quantity
TO-247A-3L
Tube
30
Package Information
TO-247A- 3L
6
很抱歉,暂时无法提供与“HY5012W”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+17.34480
- 10+15.06600
- 30+12.22560
- 100+10.76760
- 500+10.10880
