HG1V107M0608PC
HG1V107M0608PC
    HONOR(荣誉)
    AEC-D6.3X8MM_TM
    100UF ±20% 35V
HG1V107M0608PC 数据手册
SOLID POLYMER ELECTROLYTIC CAPACITOR 固态高分子电解电容 导电性高分子固体铝电解电容器 HG series High Voltage/High Reliability Dimensions & Characteristics (尺寸及特性) Features (特点) ★ High voltage and high reliability, Large permissible ripple current (高压电高可靠性,允许大纹波电流). ★ Low ESR at high frequency range (在高频范围内的低ESR). Capacitance LC. (V) (uF) (UA,2min) 10 15 70 105 0.12 0.12 22 154 0.12 33 231 0.12 39 273 0.12 47 329 0.12 56 392 0.12 68 476 0.12 82 574 0.12 100 700 0.12 220 330 470 10 15 22 33 39 47 56 82 1540 2310 3290 100 150 220 330 390 470 560 820 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 0.12 ★ Applicable to the power circuit and industrial electronic qeuipment (such as: military products, high-end industrial power, LED lighting drive power supply), can satisfy lead-free soldering conditions. 适用于电源电路及工业电子设备(如:军工产品、高端工业电源、LED照明驱动电源等),可萍踪无铅焊锡条件。 Specifications (产品规格) item Performance Characteristics 项目 Operating Temperature Range 工作温度范围 Rated Voltage Range 额定电压范围 性能、特点 35 -55~+105℃ 35~50vdc ±20%(120Hz,+20℃) Capacitance Tolerance (容量公差) ≤0.2CV(uA,after 2 minutes) 充电2分钟后漏电≤0.2cv Not to exceed the value specified 不超过指定值 Leakage Current(+20℃,max) 漏电流 Dissipation Factor (损耗系数) (tanδ,at 20℃,120Hz) Not to exceed the value specified 不超过指定值 Within ±20% of the value before test 测试前的值的±20%以内 Not to exceed the value specified 不超过指定值 Not to exceed 150% of the value specified 不超过指定值的150% Not to exceed 150% of the value specified 不超过指定值的150% Within ±20% of the value before test 测试前的值的±20%以内 Not to exceed the value specified 不超过指定值 Not to exceed 150% of the value specified 不超过指定值的150% Not to exceed 150% of the value specified 不超过指定值的150% ESR(100KHz) Capacitance Change Endurance (耐久性) 105℃,2000h,at rated voltage Leakage Current 105℃,2000h,不超过额定电压 ESR Dissipation Factor Capacitance Change Moisture Resistance (耐湿性) Stored at 60℃,RH90~95%,2000h Leakage Current 存放在60℃,RH90~95%,2000h ESR Dissipation Factor tgδ W.V 50 ESR (120Hz,20℃) (mΩ,100KHz) 45 45 45 35 35 35 30 35 30 30 28 30 28 30 28 30 28 28 28 28 45 45 45 45 45 45 45 45 Ripple Current(mA.rms) at 105℃,100KHz Maximun Permissible Size Current(mA,rms) φDXL(mm) 2000 2000 2600 2600 2600 2600 2980 2600 2980 2980 3800 2980 3800 2980 3800 2980 3800 3800 3800 3800 2000 2000 2600 2600 / 2700 2700 / 2900 2900 2900 2900 6.3×8 6.3×8 6.3×8 8×8 8×8 8×8 8×11.5 8×8 8×11.5 8×11.5 10×12.0 8×11.5 10×12.0 8×11.5 10×12.0 8×11.5 10×12.0 10×12.0 10×12.0 10×12.0 6.3×8 6.3×8 8×8 8×8 / 8×11.5 8×11.5 / 10×12.0 10×12.0 10×12.0 10×12.0 Srequency Coefficient for Ripple Current (纹波电流的频率系数) Frequency 120Hz≤freq.
HG1V107M0608PC 价格&库存
很抱歉,暂时无法提供与“HG1V107M0608PC”相匹配的价格&库存,您可以联系我们找货
HG1V107M0608PC
  • 5+0.99953
  • 50+0.82071
  • 150+0.73134
  • 1000+0.58339
  • 2000+0.52973
  • 5000+0.50295
库存:1709
