SJ1-3515-SMT-PI
SJ1-3515-SMT-PI
    CUIDEVICES
    SJ1-3515-SMT-PI
SJ1-3515-SMT-PI 数据手册
Additional Resources: Product Page date 10/09/2019 page 1 of 4 SERIES: SJ1-351X-SMT │ DESCRIPTION: AUDIO JACK FEATURES • • • • low profile design switch options include: no switch, tip switch, tip & ring switch gold flash plastic housing PART NUMBER KEY SJ1-351 X - SMT-TR - X Base Number Note: Switch Options: 3 = no switch 3C = ring switch 4 = tip switch 5 = tip and ring switch Package Style: SMT = surface mount Packaging: TR = Tape & Reel Color Options: “blank” = black BE1 = blue GR1 = green PI1 = pink 1. Tip and ring switch model only SPECIFICATIONS parameter conditions/description min rated input voltage typ 12 rated input current contact resistance2 between terminal and mating plug between terminal in a closed circuit insulation resistance at 500 Vdc voltage withstand for 1 minute 1 A 50 30 mΩ mΩ MΩ 0.3 operating temperature -25 life at a rate of 24 cycles/minute flammability rating UL94V-0 RoHS yes 500 Vac 3 kg 85 5,000 2. When measured at a current of less than 100 mA/1 kHz 3. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted. cuidevices.com units Vdc 100 insertion/withdrawal force Note: max °C cycles Additional Resources: Product Page CUI Devices │ SERIES: SJ1-351X-SMT │ DESCRIPTION: AUDIO JACK date 10/09/2019│ page 2 of 4 MECHANICAL DRAWING units: mm tolerance: X.X ±0.2 mm X.XX ±0.10 mm X.XXX ±0.050 mm PCB: ±0.05 mm MATERIAL PLATING terminal 1 copper alloy gold flash terminal 2 copper alloy gold flash terminal 3 copper alloy gold flash terminal 10 brass gold flash terminal 11 brass gold flash plastic PA10T Recommended PCB Layout Top View 1 3 2 Model No. SJ1-3513-SMT Schematic 14 Ø3.5 MATING PLUG SJ1-3513C-SMT 1 3 1 3 11 2 2 SJ1-3514-SMT SJ1-3515-SMT 1 3 1 3 11 10 2 10 2 PIN 1 sleeve sleeve sleeve sleeve 2 tip tip tip tip 3 ring ring ring ring 10 NP NP tip switch tip switch 11 NP ring switch NP ring switch cuidevices.com Additional Resources: Product Page CUI Devices │ SERIES: SJ1-351X-SMT │ DESCRIPTION: AUDIO JACK date 10/09/2019│ page 3 of 4 SOLDERABILITY parameter conditions/description reel storage at relative humidity
SJ1-3515-SMT-PI 价格&库存
很抱歉,暂时无法提供与“SJ1-3515-SMT-PI”相匹配的价格&库存,您可以联系我们找货
