F1206VH3500TM
F1206VH3500TM
    AEM
    一次性保险丝(熔断) 3.5A 65V
F1206VH3500TM 数据手册
Revision of September 2018 SolidMatrix® Surface Mount Fuses VH Series (Voltage High), 1206 Size Features: • • • • • Clearing Time Characteristics: % of Current Rating Shape and Dimensions: Clearing Time at 25°C 100% Unit Inch mm 4 hours min. 200% (2.5 A - 5.0 A) 60 seconds max. 350% (6.0 A - 8.0 A) 5 seconds max. 1000% High inrush current withstanding capability Ceramic Monolithic structure Silver fusing element and silver termination with nickel and tin plating Symmetrical design with marking on both sides (optional) Operating temperature range: -55°C to +125°C (with derating) 0.0002 seconds min. L 0.126 ± 0.008 3.20 ± 0.20 W 0.063 ± 0.008 1.60 ± 0.20 T 0.034 ± 0.008 0.85 ± 0.20 B 0.020 ± 0.010 0.51 ± 0.25 0.02 seconds max. Agency Approval: L W Recognized Under the Components Program of UL. File Number: E232989. T Patents: Patent numbers “US6,034,589”, “US6,602,766”, “US7,268,661 B2”, “ZL00134544.3”, “ZL02114719.1”, “ZL200410104280.7”, “ZL201020551360.8”, “ZL201010299185.2”, “ZL201220030614.0”, “ZL201210020693.1”. B Ordering Information: 1. 2. 3. Part Number Current Rating (A) F1206VH2500TM 2.5 F1206VH3000TM 3.0 Voltage Rating (VDC) Interrupting Ratings 60A@ 65VDC 80A@48VDC 100A@32VDC Nominal Cold DCR(Ω)1 Nominal I2t (A2s)2 Marking3 0.065 1.15 J 0.042 2.40 K 0.033 2.80 L 0.026 3.80 M F1206VH3500TM 3.5 F1206VH4000TM 4.0 F1206VH4500TM 4.5 0.024 3.90 T F1206VH5000TM 5.0 0.018 4.40 N F1206VH6000TM 6.0 0.011 13.0 + F1206VH7000TM 7.0 0.009 19.0 - F1206VH8000TM 8.0 0.007 20.0 = 65V 48V 80A@48VDC 100A@32VDC o Measured at ≤ 10% rated current and 25 C ambient. Melting I2t at 10 times of rated current. Blue Marking Character Code. Website: www.aemchina.com & www.aemcomponents.com Revision of September 2018 SolidMatrix® Surface Mount Fuses VH Series (Voltage High), 1206 Size 8.0 A 7.0 A 6.0 A 5.0 A 4.5 A 4.0 A 3.5 A 3.0 A 2.5 A Average Pre-arcing Time Curves: 100 Pre-arcing Time (s) 10 1 0.1 0.01 0.001 0.0001 1 10 100 Current (A) Website: www.aemchina.com & www.aemcomponents.com 1000 Revision of September 2018 SolidMatrix® Surface Mount Fuses VH Series (Voltage High), 1206 Size Average I2t vs. t Curves: 10000 8.0 A 7.0 A 6.0 A 5.0 A 4.5 A 4.0 A 3.5 A 3.0 A 2.5 A I2t (A2s) 1000 100 10 1 0.1 0.01 0.0001 0.001 0.01 0.1 1 10 Time (s) Website: www.aemchina.com & www.aemcomponents.com 100 Revision of September 2018 SolidMatrix® Surface Mount Fuses Product Identification: F 0603 FA 1000 V032 T M F 1206 HC 20A0 T M (1) (1) (2) (3) (4) (5) (6) (7) (2) (3) (4) (5) (6) (1) Product Code: F-Chip Fuse (1) Product Code: F-Chip Fuse (2) Size Code: Standard EIA Chip Sizes (2) Size Code: L x W (inch), the first two digits-L (length), (3) Series Code: FA - Fast Acting, SB - Slow Blow, HI - High Inrush, FF - Very Fast Acting, HB - High Current the last two digits-W (width) (4) Current Rating Code: 1000 - 1000 mA (For HB, 10 - 10A) (3) Series Code: HC Series (5) Voltage Rating Code: V032 - 32 VDC (4) Current Rating Code: 20A0—20.0A (6) Package Code: T - Tape & Reel, B - Bulk (5) Package Code: T - Tape & Reel, B - Bulk (7) Marking Code: M - With Marking Recommended Land Pattern: 0.016 (0.40) 0.028 (0.70) 0.063 (1.60) Inch (mm) 0402 Size 0.059 (1.50) 0.031 (0.80) 0.087 (2.20) 0.039 (1.00) 0.173 (4.40) Inch (mm) Inch (mm) 0603 Size 0.071 (1.80) 1206 Size Environmental Tests: No. Test Requirement Test condition 1 Soldering heat resistance DCR change  10% No mechanical damage One dip at 260C for 60 seconds 2 Solderability Minimum 95% coverage One dip at 245C for 5 seconds 3 Thermal shock 4 Moisture resistance 5 Salt spray 6 Mechanical vibration 7 Mechanical shock 8 Life DCR change  10% No mechanical damage DCR change  15% No excessive corrosion DCR change  10% No excessive corrosion DCR change  10% No mechanical damage DCR change  10% No mechanical damage 100 cycles between -65C and +125C 10 cycles 48 hour exposure 0.4 ” D.A. or 30 G between 5 – 3000 Hz 1500 G, 0.5 ms, half-sine shocks Test reference MIL-STD-202 Method 210 MIL-STD-202 Method 208 MIL-STD-202 Method 107 MIL-STD-202 Method 106 MIL-STD-202 Method 101 MIL-STD-202 Method 204 MIL-STD-202 Method 213 No electrical “opens” during 80% rated current (75% for < 1 A fuses) testing Refer to AEM for 2000 hours at ambient temperature voltage drop change shall be QIQ106 between +20C and +30C less than 20% of initial value Website: www.aemchina.com & www.aemcomponents.com Revision of September 2018 SolidMatrix® Surface Mount Fuses Electrical Specification: Clearing Time Characteristics: Same as specified on the Short Form Data Sheet Insulation Resistance after Opening: 20,000 ohms typical when cleared with rated voltage applied. Fuse clearing under low voltage conditions may result in lower after clearing insulation resistance values. (Note: Under normal fault conditions (low or rated voltage conditions), AEM SolidMatrix fuses provide sufficient after clearing insulation resistance values for circuit protection.) Current Carrying Capacity: 100% rated current at +25°C ambient for 4 hours minimum when evaluated per MIL-PRF-23419 Interrupt Ratings: Fuse Selection and Temperature De-rating Guideline: The ambient temperature affects the current carrying capacity of fuses. When a fuse is operating at a temperature higher than 25°C, the fuse shall be “de-rated”. To select a fuse from the catalog, the following rule may be followed: Catalog Fuse Current Rating = Nominal Operating Current / 0.75 / % De-rating at the maximum operating temperature. Example: At maximum operating temperature of 65°C, % De-rating is 90%. The nominal operating current is 4 A. The current rating for fuse selected from the catalog shall be: 4 / 0.75 / 90% = 5.9 or 6 A. Specifications and descriptions in this literature are as accurate as known at the time of publish, but are subject to change without notice. Website: www.aemchina.com & www.aemcomponents.com Revision of September 2018 SolidMatrix® Surface Mount Fuses Soldering Temperature Profile: * Recommended Temperature Profile for Reflow Soldering Profile Feature * Recommended Temperature Profile for Wave Soldering Pb-Free Assembly Preheat/Soak Temperature Min (Tsmin) Temperature Max(Tsmax) Time(ts) from (Tsmin to Tsmax) 150°C 200°C 60~120 seconds Ramp-uprate (TL to Tp) 3°C/second max. Liquidous temperature(TL) Time(tL) maintained above TL 217°C 60~150 seconds Peak package body temperature (Tp) 260°C Time (tp)*within 5°C of the specified classification temperature (Tc) 30 seconds * Ramp-down rate (Tp to TL) 6°C/second max. Time 25°C to peak temperature 8 minutes max. * Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum Notice: Wave Soldering is suitable for 1206 and 0603 size. Packaging: Chip Size Parts on 7 inch (178 mm) Reel 0402 (1005) 10,000 0603 (1608) 4,000 0603FF (1608) 6,000 1206 (3216) 3,000 Website: www.aemchina.com & www.aemcomponents.com
F1206VH3500TM
- 物料型号:F1206VH系列,包括2.5A至8.0A的电流额定值。 - 器件简介:这些保险丝具有高浪涌电流承受能力,陶瓷单体结构,银熔断元件和银端子,镀镍和锡,对称设计(可选双面标记)。 - 引脚分配:文档中没有提供具体的引脚分配图,但提到了尺寸信息,长度(L)、宽度(W)、厚度(T)和间隙(B)。 - 参数特性:包括在25°C下不同电流百分比下的断开时间特性,操作温度范围为-55°C至+125°C(需降额),以及尺寸公差。 - 功能详解:提供了保险丝的电气规格,包括断开时间特性、绝缘电阻、电流承载能力和中断额定值。 - 应用信息:文档中没有直接提供应用信息,但根据保险丝的特性,它们适用于需要高电压和高浪涌电流保护的场合。 - 封装信息:提供了推荐的焊盘图案和环境测试要求,包括焊接热抗性、可焊性、热冲击、耐湿性、盐雾、机械振动、机械冲击和寿命测试。
F1206VH3500TM 价格&库存
很抱歉,暂时无法提供与“F1206VH3500TM”相匹配的价格&库存,您可以联系我们找货
