AW39104FOR
AW39104FOR
    AWINIC(艾为)
    BGA-12
    停产 4-BIT双向电压电平转换器
AW39104FOR 数据手册
AW39104 Apr. 2020 V1.4 4-bit Bidirectional Voltage-Level Translator for Open-Drain and Push-Pull Applications Features General Description  AW39104 is a 4-bit high-performance voltage-level translator without direction control signal, which is a non-inverting converter and can be used to convert digital signal with mixed-voltage systems. It needs two separate power supply rails, with the A ports tracks the VCCA ranging from 1.65 V to 3.6 V, and the B ports tracks the VCCB ranging from 2.3 V to 5.5 V. This makes the chip has capabilities of support both lower and higher logic signal levels translation between any of the 1.8 V, 2.5 V, 3.3 V, and 5 V voltage nodes.    l No power supply sequencing requirements means either VCCA or VCCB can be powered up first, and OE should be enabled after both VCCA and VCCB are established. fi Applications a  If the voltage level of output-enable (OE) pin is low, the chip works in the high-impedance state, which costs ultra-low power-supply quiescent current. And the OE input circuit is supplied by VCCA. Meanwhile, OE is recommended to be tied to GND through a pull-down resistor to ensure the highimpedance state during power up or power down. ti  n  e  d  Voltage Level Translator Without DirectionControl Signal Maximum Data Rates - 24Mbps (Push Pull) - 2Mbps (Open Drain) Power Supply Range: - A Port and VCCA: 1.65 V to 3.6 V - B Port and VCCB: 2.3 V to 5.5 V - VCCA ≤ VCCB Pull Up Resistors are Integrated in A Port and B Port No Power-Supply Sequencing Required: Either VCCA or VCCB Can be Ramped First Support Ultra-Low Power Consumption Mode with OE Pin is Low Voltage Level I/O Pin ESD: - A Port: 2.5 kV (HBM) - B Port: 6 kV (HBM) Latch -Up Performance Exceeds ±200mA Under JESD 78 Standard FOR 1.87mm×1.37mm-12B Package I2C / SMBus  UART  GPIO  Handheld Devices Interface C o n  Application Circuit VCCA VCCB ic VCCA VCCB CVCCA=0.1μF in CVCCB=0.1μF a w 1.8V System Controller A1 B1 A2 B2 A3 AW39104 B3 A4 B4 3.3V System OE GND RPD Figure 1 Typical Application Circuit of AW39104 All trademarks are the property of their respective owners. www.awinic.com 1 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Pin Configuration and Top Mark AW39104FOR PIN Configuration AW39104FOR Marking (Top View) (Top View) 2 1 GND B4 C A3 OE B3 B A2 VCCA B2 A A1 VCCB B1 a A4 DQFW XXXX D l 3 ti DQFW – AW39104FOR n XXXX – Production tracing code d e Figure 2 Pin Configuration and Top Mark C o n Description A-port supply voltage. 1.65 V ≤ VCCA ≤ 3.6 V, VCCA ≤ VCCB. Input/output A1. Input/output A2. Input/output A3. Input/output A4. Ground. Output enable. Input/output B1. Input/output B2. Input/output B3. Input/output B4. B-port supply voltage. 2.3 V ≤ VCCB ≤ 5.5 V. in ic Pin Name VCCA A1 A2 A3 A4 GND OE B1 B2 B3 B4 VCCB w Pin No. B2 A3 B3 C3 D3 D2 C2 A1 B1 C1 D1 A2 fi Pin Definition a NOTE: The Pin number of Pin 1(Pin No.)is A3 instead of A1, and the Pin name is A1. www.awinic.com 2 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Functional Block Diagram VCCA VCCB ONESHOT EN R1 10kΩ EN R2 10kΩ G_BIAS A1 B1 R4 10kΩ G_BIAS ti EN a R3 10kΩ l ONESHOT EN B2 fi G_BIAS R6 10kΩ n EN d ONESHOT EN R5 10kΩ e n A2 B3 C o A3 EN ONESHOT R8 10kΩ G_BIAS in R7 10kΩ ic EN w A4 B4 a OE GND EN Figure 3 AW39104 Function Block www.awinic.com 3 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Typical Application Circuits VCCA VCCB VCCA VCCB CVCCA=0.1μF CVCCB=0.1μF 1.8V System Controller A1 B1 A2 B2 A3 AW39104 B3 A4 B4 3.3V System OE GND RPD Figure 4 AW39104 Application Circuit Markin g AW39104FOR -40°C~85°C FOR 1.87mm×1.37mm-12B DQFW Moisture Sensitivity Level Environmenta l Information ti Package n Temperatur e MSL1 ROHS+HF Delivery Form 3000 units/ Tape and Reel a w in ic C o n fi d e Part Number a l Ordering Information www.awinic.com 4 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Absolute Maximum Ratings(NOTE1) PARAMETERS MIN MAX UNIT Supply voltage range VCCA(NOTE2) -0.5 5 V Supply voltage range VCCB(NOTE2) -0.5 6.5 V A port -0.5 5 V B port -0.5 6.5 V A port -0.5 5 V B port -0.5 6.5 V Operating free-air temperature range -40 85 °C Operating junction temperature TJ -40 125 °C -65 150 °C 260 °C Input voltage range, VI (NOTE2) Output voltage range in high or low state, VO ( NOTE2) Storage temperature TSTG Lead temperature (Soldering 10 seconds) ti a l NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages to the device. In spite of the limits above, functional operation conditions of the device should within the ranges listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged periods may affect device reliability. e n NOTE2: With respect to GND. d ESD Rating and Latch Up VALUE UNIT B Port HBM (Human Body Model) (NOTE 3) ±6 kV Other PINS HBM (Human Body Model) ±2.5 kV ±1.5 kV o n fi PARAMETERS C CDM(NOTE 4) Latch-Up(NOTE 5) +IT:200 -IT:-200 mA ic NOTE3: The human body model is a 100pF capacitor discharged through a 1.5kΩ resistor into each pin. Test method: ESDA/JEDEC JS-001-2017 NOTE4: Test method: ESDA/JEDEC JS-002-2018 a w in NOTE5: Test method: JESD78E www.awinic.com 5 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Recommended Operating Conditions VCCI is the VCC associated with the input port VIH High-level input voltage B-port OE input A-port VIL Low-level input voltage B-port OE input A-port (NOTE 7) Δt/ΔV Input transition rise or fall rate B-port (NOTE7) 3.6 V 2.3 5.5 V VCCI-0.4 VCCI V VCCI-0.4 VCCI V VCCA×0.65 5.5 V 0.4-IOL×RNPASS 0 Operating junction temperature T A V (NOTE6) 0.4-IOL×RNPASS 0 V (NOTE6) 0 VCCA×0.35 V 10 ns/V 10 ns/V 10 ns/V -40 85 °C d TA 1.65 e Control input VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V VCCA=1.65V~3.6V VCCB=2.3V~5.5V UNIT l A-port MAX a VCCB Supply voltage for A port Supply voltage for B port MIN ti VCCA CONDITIONS n PARAMETERS fi NOTE6: IOL is the current from external resistor to output port, RNPASS is equal internal resistor of NMOSFET between A port and B port. n NOTE7: The parameter is defined for push-pull driving. C o Thermal Information VALUE UNIT Junction-to-ambient thermal resistance θJA 120 °C /W a w in ic PARAMETERS www.awinic.com 6 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Electrical Characteristics DC Electrical Characteristics Operating under recommended conditions, VCCA ≤ VCCB, T A=25°C for typical values (unless otherwise noted) ICCB+ ICCA RPU 1.65~3.6 2.3~5.5 IOH= -20μA VIA≥VCCA-0.4V 1.65~3.6 2.3~5.5 IOL=1mA VIA≤0.15V 1.65~3.6 2.3~5.5 1.65~3.6 2.3~5.5 1.65~3.6 OE=VIH VI=VO=Open IO=0 TA=-40°C to 85°C OE=VIH VI=VO=Open IO=0 TA=-40°C to 85°C Combined supply current Resistor pull-up value VI=VO=Open IO=0 T TA=-40° =25°CC to 85°C The resistor of NMOSFET between A port and B port OE=VIH TA=25°C A 0.4 V VCCB×0.67 V V -1 1 μA 2.3~5.5 -2 2 μA 1.65~3.6 2.3~5.5 -1 1 μA 1.65~3.6 2.3~5.5 -2 2 μA 1.65~3.6 2.3~5.5 1 μA 3.6 0 1 μA 0 5.5 -1 μA 2.3~5.5 16 μA 0 -1 μA 0 5.5 1 μA 1.65~3.6 2.3~5.5 18 μA 1.65~3.6 2.3~5.5 12 kΩ 1.8 3.3 1.65~3.6 3.6 a 0.4 ti VI=VCCI or GND, TA=25°C VI=VCCI or GND, TA=-40°C to 85°C OE=VIL TA=25°C OE=VIL TA=-40°C to 85°C V 8 10 Ω 28 in RNPASS VCCB supply current IOL=1mA VIB≤0.15V UNIT l ICCB VCCA supply current VCCA×0.67 n ICCA 2.3~5.5 e IOZ A or B port output current in high impedance state 1.65~3.6 MAX d II OE input leakage current IOH= -20μA VIB≥VCCB-0.4V TYP fi VOLB MIN o VOHB VCCB(V) C VOLA Port A output high voltage Port A output low voltage Port B output high voltage Port B output low voltage VCCA(V) ic VOHA TEST CONDITION n PARAMETER Timing Requirements (NOTE1) w Output load: CL=15pF, push-pull driver, and TA=-40°C to 85°C. VCCA=1.8V±0.15V / 2.5V±0.2V / 3.3V±0.3V a PARAMETER Data Rate tw www.awinic.com Pulse Duration TEST CONDITION MIN MAX VCCB=2.5V±0.2V 21 VCCB=3.3V±0.3V 24 VCCB=5V±0.5V 24 VCCB=2.5V±0.2V 45 VCCB=3.3V±0.3V 40 7 UNIT Mbps ns Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 PARAMETER TEST CONDITION MIN VCCB=5V±0.5V MAX UNIT 40 NOTE1: The parameter’s variation is guaranteed by design, not production tested. Switch Characteristics(NOTE2) Output load: CL=15pF, TA=25°C for typical values (unless otherwise noted), VCCA=1.8V VCCB=2.5V PARAMETER VCCB=5V UNIT MIN MAX Push-pull tPHL(NOTE3) VCCB=3.3V TEST CONDITION MIN 11 MAX MIN 7.0 MAX 5.0 A-B ns Open-drain 2.3 8.8 Push-pull tPLH(NOTE3) 2.4 7.5 9.6 2.6 6.7 10 5.7 A-B ns 45 260 36 208 27 198 Push-pull tPHL(NOTE3) 9.0 5.3 Push-pull tPLH(NOTE3) 1.1 7.4 OE-A or B 200 tfA Input fall time A port fall time tfB Input fall time B port fall time Open-drain 38 Push-pull 4 ns 4 4.1 ns 27 102 35 30 ns 200 200 ns 9.5 2.3 9.3 2 7.6 165 30 132 22 95 10.8 2.7 9.1 2.7 7.6 n B port rise time 3.2 o trB Input rise time Push-pull C A port rise time ns ns Open-drain 34 145 23 106 10 58 Push-pull 2 5.9 1.9 6 1.7 13.3 4.4 6.9 4.3 6.4 4.2 6.1 Push-pull 2.9 13.8 2.8 16.2 2.8 16.2 Open-drain 6.9 13.8 7.5 16.2 7 16.2 ns Open-drain in trA Input rise time 140 e 45 fi OE-A or B 36 d 175 5 ic ten Enable time tdis disable time 45 1.2 5.8 B-A Open-drain 4.4 ti 1.9 n Open-drain w ns Channel to channel skew 1 1 1 ns a tSK Skew time output 5.5 B-A a l Open-drain www.awinic.com 8 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Output load: CL=15pF, TA=25°C for typical values (unless otherwise noted), VCCA=2.5V VCCB=2.5V PARAMETER VCCB=5V UNIT MIN MAX Push-pull tPHL(NOTE3) VCCB=3.3V TEST CONDITION MIN 3.2 MAX MIN 3.7 MAX 3.8 A-B ns Open-drain 1.7 6.3 Push-pull tPLH(NOTE3) 2 3.5 6 2.1 4.1 5.8 4.4 A-B ns Open-drain 45 250 Push-pull tPHL(NOTE3) 36 3 206 27 190 3.6 4.3 B-A ns Open-drain 1.8 4.7 Push-pull tPLH(NOTE3) 2.6 2.5 4.2 1.2 1.6 4 1 B-A ns 37 140 OE-A or B 200 Open-drain 38 150 28 Push-pull 3.2 8.3 Open-drain 34 151 Push-pull 1.9 Open-drain 4.4 tfA Input fall time A port fall time tfB Input fall time B port fall time tSK Skew time output Channel to channel skew Push-pull 2.2 5.1 1.8 5.6 121 24 89 2.9 7.2 2.4 6.1 24 112 12 64 1.9 5.5 1.8 5.3 6.9 4.3 6.4 4.2 5.8 7.8 2.4 6.7 2.6 6.6 8.8 5.4 9.4 5.4 10.4 5.7 ns ns ns ns 1 1 1 ns a w in ic Open-drain ns 6.6 n B port rise time o trB Input rise time 200 n 2.6 ns e 7.4 d 2.8 A port rise time 30 fi Push-pull trA Input rise time 102 ti 35 27 l 170 OE-A or B C ten Enable time tdis disable time 44 a Open-drain www.awinic.com 9 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Output load: CL=15pF, TA=25°C for typical values (unless otherwise noted), VCCA=3.3V PARAMETER VCCB=3.3V MIN MAX TEST CONDITION Push-pull tPHL(NOTE3) UNIT 3.1 ns A-B 1.3 Push-pull (NOTE3) 4.2 1.4 4.6 4.2 4.4 ns A-B Open-drain 36 Push-pull tPHL(NOTE3) 204 27 165 2.5 3.3 ns B-A Open-drain 1 Push-pull (NOTE3) 124 1 97 2.5 3.3 ns B-A Open-drain ten Enable time tdis disable time 3 139 3 105 30 a l OE-A or B tfB Input fall time B port fall time Open-drain 25 116 Push-pull 2.5 6.4 Open-drain 26 Push-pull 2 Open-drain Push-pull 4.8 19 85 2.1 7.4 116 14 72 5.4 1.9 5 4.3 6.4 4.2 5.7 2.3 7.4 2.4 7.6 Open-drain 7.6 4.8 8.3 5 ti A port fall time 1.9 n tfA Input fall time 5.6 fi B port rise time 2.3 n trB Input rise time Push-pull o A port rise time C trA Input rise time 200 d OE-A or B e tPLH VCCB=5V MAX 2.4 Open-drain tPLH MIN 1 ns ns ns ns ns ns ic tSK Channel to channel skew 1 Skew time output NOTE2: The parameters is guaranteed by design, not production tested. ns a w in NOTE3: tPHL presents propagation delay from high to low, and tPLH presents propagation delay from low to high. www.awinic.com 10 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Typical Characteristics Test Information input output AW39104 15pF 1MΩ Test Circuit for Date Rate, Pulse Duration, Propagation Delay, Rise Time and Fall Time Figure 5 Load Circuit of Push-Pull Driver input output a l AW39104 1MΩ n ti 15pF e Test Circuit for Date Rate, Pulse Duration, Propagation Delay, Rise Time and Fall Time d Figure 6 Load Circuit of Open-Drain Driver fi S1 50k C o 15pF Open n 50k From Output Under Test 2×Vcco S1 tPZL/tPLZ (tdis) 2 × Vcco tPHZ/tPZH (ten) Open in ic TEST tPLZ and tPHZ are the same as tdis. 2. tPZL and tPZH are the same as ten. 3. VCCI is the VCC associated with the input port. 4. VCCO is the VCC associated with the output port. 5. The resistance and Capacitance values at output notes above are the total effective values. a w 1. Figure 7 Load Circuit for Enable-Time and Disable-Time Measurement www.awinic.com 11 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 tw Data in 0.5×VCCI 0.5×VCCI Data in tPLH tPHL 0.5×VCCO 0.9×VCCO 0.9×VCCO 0.1×VCCO 0.1×VCCO 0.5×VCCO Data out tr tf a l The input pulses should have the following characteristics: ti 1. fIN ≤10MHz. d e Figure 8 Timing Parameter Definition n 2. dv/dt ≥ 1V/ns. VCCA/2 VCCA/2 n fi OE input tPZL o Output Waveform 1 S1 at 2×VCCO(1) VCCA 0V tPLZ VOH C VCCO×0.9 VOH×0.9 ic VOL tPHZ tPZH Output Waveform 2 (2) S1 at OPEN VOH×0.1 VOH VCCO×0.1 in 0V (1) The Waveform 1 is obtained under the condition that the input is low and S1 at 2*V CCO. Figure 9 Enable and Disable Times a w (2) The Waveform 2 is obtained under the condition that the input and S1 at OPEN. www.awinic.com 12 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Typical Curve TA=25°C VCCA=3.3V, OE=1, VILA=0.15V Figure 11 Low-Level Output Voltage vs Low Level Current a Low-Level Output Voltage vs Low-Level Current C o n fi d e n ti Figure 10 l VCCA=1.8V, OE=1, VILA=0.15V VCCA=1.8V, VCCB=3.3V, OE=1, Push-Pull Driver Signal is translated from A port to B port ic Level Translation of a 1MHz Signal Figure 13 Level Translation of a 2.5MHz Signal a w in Figure 12 VCCA=1.8V, VCCB=3.3V, OE=1, Push-Pull Driver Signal is translated from A port to B port www.awinic.com 13 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Detailed Functional Description AW39104 is a 4-bit high-performance voltage-level translator without direction control signal, which is a noninverting converter and can be used to convert digital signal with mixed-voltage systems. Port A can support I/O voltages from 1.65 V to 3.6 V, while Port B is able to support I/O voltage range from 2.3 V to 5.5 V. The chip uses a transmission gate architecture with an rising edge rate accelerator (one-shot), to increase overall data rate. Also, 10kΩ pull-up resistors are integrated in the chip, which ensures the chip not only supports push-pull applications but also can be used in open-drain applications directly. One-shot Accelerator ti a l The One-Shot rising edge accelerator circuit speeds up the rising edge to help increasing the chip's data rate. Once the chip has detected the rising edge of the input signal from low to high, the one-shot circuit generates a pulse signal of approximately 25ns, which enables the internal pull-up PMOS transistor between power supply and output, thereby accelerating the output port from low to high. During this acceleration phase, the output resistance of the driver is reduced from 10kΩ to approximately 60Ω. While detecting the output has been turned up, the one-shot pulse signal is finished and pull-up PMOS transistor is quickly turned off. This architecture reduces the average dynamic power consumption of the chip while allowing it to meet different drive requirements. n Gate Bias fi d e For the bidirectional voltage translator AW39104, a NMOS switch transistor is used between the input and output. When translating high level, the NMOS transistor is turned off, and the input and output terminals are isolated so that they do not impact each other. When the low level is translated, the NMOS switch transistor is fully turned on, so that the output terminal can be quickly pulled down to the low voltage level. Therefore, the gate bias voltage of the NMOS switch transistor is set to a fixed value about VCCA+VTH. It is also because of this architecture that VCCA≤VCCB needs to be guaranteed in the applications. o n Enable Control in Input Driver ic C The AW39104’s OE pin can disable the chip by setting OE to low voltage level, allowing all I/O to operate in the Hi-Z state. The disable time (tdis) represents the delay time from OE going low to the chip turns to Hi-Z state. In the Hi-Z state, the chip consumes ultra-low current. And the enable time (ten) indicates the delay from OE going high to the chip working in translation state. Meanwhile, OE is recommended to be tied to GND through a pull-down resistor to ensure the high-impedance state during power up or power down. The minimum value of the resistor is determined by the current-sourcing capability of the driver. a w The rising edge time of the signal (trA, trB) and propagation delay from low to high (tPLH) are determined by the rising edge rate of the input signal, the ONE-SHOT accelerator’s pull-up capability, and the capacitive load of the port. The falling edge time of the signal (t fA, tfB) depends on the falling edge rate of the input signal, the output impedance of the external driver, and the capacitive load on the data line. Similarly, t PHL and the maximum data rate also depend on the output impedance of the external driver. So, the test conditions for t rA, trB, tfA, tfB, tPLH, tPHL and maximum data rate in the data sheet are that the output impedance of the external driver is less than 50Ω. Output Load It is recommended that a PCB layout with short PCB layout length: www.awinic.com 14 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 1. Avoid excessive capacitive load triggers ONE-SHOT circuit falsely; 2. It can ensure that the round trip delay of any reflection is less than a single ONE-SHOT duration; 3. Improve signal integrity. a w in ic C o n fi d e n ti a l Meanwhile, the pulse width of the ONE-SHOT circuit is approximately 25 ns, which determines the maximum output load capacitance that the chip can drive. For very heavy output capacitive loads, the one-shot accelerator will time-out before the output is fully pulled to high level, at which case the signal transmission will be distorted. So the ONE-SHOT duration design requires a trade-off between dynamic power consumption, capacitive load driving capability and maximum data rate. The signal tw at the maximum translation rate should be greater than the maximum pulse width of the ONE-SHOT circuit, and the delay caused by the output capacitive load should be less than the maximum pulse width of the ONE-SHOT circuit. www.awinic.com 15 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Application Information VCCA VCCB VCCA VCCB CVCCA=0.1μF CVCCB=0.1μF 1.8V System Controller A1 B1 A2 B2 A3 AW39104 B3 A4 B4 3.3V System OE GND RPD ti a l Figure 14 AW39104 Application Circuit AW39104 is a 4-bit voltage-level translator without direction control signal, which is suitable for interfacing devices or systems operating at different interface voltages with one another. Port A can supports I/O voltages from 1.65 V to 3.6 V, while Port B is able to support I/O voltage range from 2.3 V to 5.5 V. Also, 10kΩ pull-up resistors are integrated in the chip, which ensures the chip not only supports push-pull applications but also can be used in open-drain applications directly. n VCC Capacitor Selection d e The device is a 4-bit high-performance voltage-level translator that requires adequate power supply decoupling. Place a low equivalent-series-resistance (ESR) ceramic capacitor, recommend 0.1μF or larger than 0.1μF. fi RPD Selection o n Drive OE pin HIGH to enable the device. If the voltage level of OE pin is low, the device works in Highimpedance mode. OE pin is recommended to be tied to GND through a pull-down resistor to ensure the highimpedance state during power up or power down. OE pin is high impedance without internal pull down resistor, a w in ic C customer can choose the resistor value based on the source drive capability and current consumption. www.awinic.com 16 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 PCB Layout Consideration To make full use of the performance of AW39104, the guidelines below should be followed. 1. CVCCA and CVCCB should be placed on the top layer as close as possible to the VCCA and VCCB pin. 2. The trace of signals should be short enough to avoid any reflection when transmitted. CVCCA=0.1μF CVCCB=0.1μF VCCB A1 B2 VCCA A2 B3 OE A3 B4 GND A4 ti a B1 l U1 n ROE e GPIO Top layer 2nd layer 2nd layer (GND) GND on Top layer fi d via a w in ic C o n Figure 15 AW39104 Layout Example www.awinic.com 17 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Tape and Reel Information TAPE DIMENSIONS REEL DIMENSIONS P1 P0 P2 K0 W B0 D1 A0 Cavity A0:Dimension designed to accommodate the component width B0:Dimension designed to accommodate the component length K0:Dimension designed to accommodate the component thickness W:Overall width of the carrier tape P0:Pitch between successive cavity centers and sprocket hole P1:Pitch between successive cavity centers P2:Pitch between sprocket hole D1:Reel Diameter D0:Reel Width a l D0 Pin 1 ti QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE Q2 Q1 Q2 Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 Q3 Q4 Q3 Q4 User Direction of Feed e Q1 n Sprocket Holes a w in ic C o n fi d Pocket Quadrants www.awinic.com 18 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Package Description(POD) 1.370 ±0.025 PIN1 CORNER 1.870 ±0.025 0.624 MAX a l Top View n ti 0.025±0.005 0.181 ±0.020 e 0.381 ±0.012 0.120 d 0.080 o n fi Side View 1 a w in 1.500 TYP C ic 0.500 TYP 2 3 12X(∅0.236±0.020) D C B A 0.500 TYP 1.000 TYP SYMM ℄ Bottom View www.awinic.com SYMM 19 Unit: mm Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Land Pattern Data 1 3 2 12X(∅0.200) A 0.500 TYP B SYMM C D 0.500 TYP ti a l SYMM ℄ n 0.05 MIN All AROUND 0.05 MAX All AROUND SOLDER MASK OPENING e SOLDER MASK OPENING METAL UNDER SOLDER MASK fi d METAL SOLDER MASK DEFINED Unit: mm a w in ic C o n NON-SOLDER MASK DEFINED www.awinic.com 20 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Revision History Date Change Record V1.0 Jun. 2019 Official Released V1.1 Sept. 2019 Update the EC Table V1.2 Dec. 2019 Update the Definition of VIL V1.3 Feb. 2020 Add the definition of Pin No. V1.4 Apr. 2020 Delete the spaces of AW39104 FOR a w in ic C o n fi d e n ti a l Version www.awinic.com 21 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD AW39104 Apr. 2020 V1.4 Disclaimer Information in this document is believed to be accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. AWINIC Technology reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. Customers shall obtain the latest relevant information before placing orders and shall verify that such information is current and complete. This document supersedes and replaces all information supplied prior to the publication hereof. l AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC Technology product can reasonably be expected to result in personal injury, death or severe property or environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. ti a Applications that are described herein for any of these products are for illustrative purposes only. AWINIC Technology makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. n All products are sold subject to the general terms and conditions of commercial sale supplied at the time of order acknowledgement. d e Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. n fi Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices. AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject to additional restrictions. a w in ic C o Resale of AWINIC components or services with statements different from or beyond the parameters stated by AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for any such statements. www.awinic.com 22 Copyright © 2019 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW39104FOR 价格&库存
很抱歉,暂时无法提供与“AW39104FOR”相匹配的价格&库存,您可以联系我们找货
