ICMEF112P350MFR
ICMEF112P350MFR
    CHILISIN(奇力新)
    SMD
    两路 贴片共模滤波器 阻抗35Ω@100MHZ
ICMEF112P350MFR 数据手册
R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 1 Data Sheet - ITEM : COMMON MODE ESD FILTER - PART NO : ICMEF112P350MFR - CONDITION : 1. 2. 3. 4. R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 2 1. Generals • This specification covers the engineering requirements for the ICMEF112P350MFR (Common Mode ESD Filter) 2. Features • Effective for suppressing common mode noise and almost no effect for high speed differential data line • Two common mode filters and four ESD suppression devices integrated • Ultra low profile (1.27ⅹ1.00ⅹ0.60mm) • Ceramic multilayer type SMD component • Non-polarized product • It is a product conforming to RoHS directive. • 1210(0504) Multilayer array type 3. Applications • LVDS lines in notebook computers • USB2.0, UBS3.1 Gen 1, IEEE1394, DVI, HDMI lines in PDP, LCD TV, DVD Player, PC, Audio player, DSC • MDDI, MIPI in mobile phone 4. Product specifications 4. 1 Part number code ICMEF ① 11 ② 2P ③ 350 ④ M ⑤ F ⑥ R ⑦ ① Series name of ICT’s Common Mode ESD Filter ② Dimensions, 1.27mm (L) ⅹ 1.0mm (W) ③ Number of lines, 2P= 2 lines ④ Common Mode Impedance (at 100MHz), 350= 35Ω ⑤ Tolerance of common mode impedance, M= ±25% ⑥ Type of electrode plating: F= Lead Free ⑦ Packing Type, R= Reel R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 3 4. 2 Specification of electrical characteristics Common Mode Impedance Characteristics Resistance CTF Leakage Current Capacitance Insulation Resistance Rated Voltage Rated Current CTF symbol ZCM RDC IL C IRCR VR IR Units Ω Ω ㎂ pF MΩ Volt mA Test Condition @100MHz 25℃±2℃ 5V 0.5Vrms @1MHz 5V Value 35(±25%) Max 4.0 Max 1.0 Max 1.7 Min 10 - Impedance Curves 1000 Z11 25℃±2℃ 25℃±2℃ 5 Max100 -Transmission characteristics (S-parameter) LOG - LOG S21 LOG 10 dB/REF 0 dB Differential Mode S21 0 S21(dB) IMPEDANCE () 100 10 -20 1 0.1 1M -10 10M 100M FREQUENCY (Hz) 1G 10G -30 1M 10M 100M 1G FREQUENCY(Hz) 4. 3 Operating Temperature DESCRIPTION REQUIREMENTS Operating Temperature -40℃ ∼ + 85℃ (including self-temperature rise) 10G R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 4 5. Equivalent Circuit & Recommended Foot print & Stencil mask PIN NUMBER DESCRIPTION ①~④ DATA LINE ⑤, ⑥ GROUND ① Unit : mm Stencil Mask T : 0.10mm ② ⑤ ⑥ ④ ③ [ Equivalent circuit ] [ Foot print ] [ Stencil Mask ] 6. Appearance and Dimension Unit : mm 0.1 R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 5 7. Test method of Electrical property Pin6 - PIN INDEX Pin2 Pin3 Pin1 Pin4 Pin5 ITEM Rdc CM Impedance IL IRCR DESCRIPTION Pin 1-4, 2-3 Pin 1-2(Short) to Pin 3-4(Short) Pin 5 or 6 to Pin 1, 2, 3, 4 Pin1 -2 or Pin3-4 SOURCE 10mA DC Source 500mV 5V DC Source 5V DC Source EQUIPMENT Source Meter LCR Meter (3GHz) Source Meter Source Meter 7. 1 Rdc (Model: KEITHLEY 2400) - Off power and On power. - Press button ‘Ω’ of MEAS. - Measure Rdc value using test fixture. 7. 2 Common Mode Impedance (Model: Agilent 4287A) - Calibrate equipment - Measure CM Impedance (at 100MHz) using test fixture. Terminal Terminal Terminal Terminal R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 6 8. Reflow condition 8. 1 Recommended soldering profile (Lead-free condition) (℃ ) Dwell: max 260℃-10sec ℃ 185℃ ℃ 160℃ Δ T≤ 220℃ 130 ℃ 250℃ ΔT ≤130℃ 30~50 sec 30~50 sec Soldering Soldering Pre-heating 110 ±10 sec Gradual Cooling 25℃ 60 sec Time (sec) 8. 2 Recommended Lead-free solder paste - Supplier : Tamura Donghwa - Main composition : Sn-Ag-Cu - Ratio of composition : 96.5%-3.0%-0.5% 8. 3 Recommended hand solder - Max Temperature: Max 380 ℃(Max 5sec) R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 7 9. Packing specification 9. 1 Taping figure 9. 2 Carrier tape dimensions Unit : mm SYMBOL DIMENSION 11 A B 1.15 1.5 0.05 0.05 W 8.0 +0.30 -0.10 F E P1 P2 P0 D t 3.5 1.75 4.0 2.0 4.0 1.55 0.75 0.05 0.05 0.10 0.05 0.10 0.03 0.05 R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 8 9. 3 Reel dimensions (1) Reel Materials: Polystyrene (2) Label (3) Taping - Standard Packing Quantity per Reel (178) - Paper Tape: 4,000pcs Unit : mm CODE A B C D E W t R DIMENSION 1782 Min. 50 130.5 200.8 3.00.5 101.5 1.30.2 1.00.2 9. 4 Label code ICMEF112P350MFR J01218TA B 001 QTY 4,000 PCS ICMEF112P350MFR J01218TA 1210, 2P, 35ohm - P/N : Part Number - L/N : Lot Number - C/N : Customer Number - SPEC : Size, Line numbers & CM Impedance - DATE : Date code - Q’TY : Quantity 190101 4,000 R-0 ITEM P/N Page Common Mode ESD Filter ICMEF112P350MFR 9 9. 5 Reel packing Part Number / Company Name MADE IN KOREA (Country of region ) (1) (2) Product box material : Card board 5 Reels in each SPQ Box (3) PQ Box contains 10 SPQ Boxes (50 Reels) Packing box + Product weight Size L x W x H(mm) Product Common Mode Filter Common Mode ESD Filter Size weight(g) /1 unit S-box + 5reel M-box + 5S-box L-box + 10S-box 185 x 70 x 185 370 x 190 x 200 380 x 370 x 200 Total(g) Chip(g) Total(g) Chip(g) Total(g) Chip(g) 0806 0.00124 643 62 3215 310 6147 620 1210 0.00480 750 96 3758 480 7503 960 2012 0.00750 804 150 4028 750 8043 1500 0806 0.00128 646 65 3230 325 6177 650 1210 0.00490 752 98 3768 490 7523 980 1608 0.00237 701 47 3515 237 7017 474 2012 0.00760 806 152 4038 760 8063 1520
ICMEF112P350MFR 价格&库存
很抱歉,暂时无法提供与“ICMEF112P350MFR”相匹配的价格&库存,您可以联系我们找货
