Flasher User Guide
Document: UM08022
Software Version: 7.82
Date: October 20, 2022
A product of SEGGER Microcontroller GmbH
www.segger.com
2
Disclaimer
The information written in this document is assumed to be accurate without guarantee. The
information in this manual is subject to change for functional or performance improvements
without notice. SEGGER Microcontroller GmbH (SEGGER) assumes no responsibility for any errors
or omissions in this document. SEGGER disclaims any warranties or conditions, express, implied
or statutory for the fitness of the product for a particular purpose. It is your sole responsibility
to evaluate the fitness of the product for any specific use.
Copyright notice
You may not extract portions of this manual or modify the PDF file in any way without the prior
written permission of SEGGER. The software described in this document is furnished under a
license and may only be used or copied in accordance with the terms of such a license.
© 2004-2022 SEGGER Microcontroller GmbH, Monheim am Rhein / Germany
Trademarks
Names mentioned in this manual may be trademarks of their respective companies.
Brand and product names are trademarks or registered trademarks of their respective holders.
Contact address
Ecolab-Allee 5
D-40789 Monheim am Rhein
Germany
Tel.
Fax.
E-mail:
Internet:
+49-2173-99312-0
+49-2173-99312-28
support@segger.com
www.segger.com
Flasher User Guide (UM08022)
3
Manual versions
This manual describes the Flasher device. For further information on topics or routines not yet
specified, please contact us.
Print date: October 20, 2022
Manual
Revision
version
Date
By
Description
7.82
JB
Updated how to enter the file access mode
7.68c
AB
Updated Universal Flashloader specifics
7.62b
JB
Typo in “DisplayName” corrected
7.59a
LG
* Replaced occurrences of “MSD mode” with “file access mode”
* Replaced occurrences of “J-Link mode” with “PC-based mode”
7.56c
JC
Chapter “Working with Flasher”
* Added Logfile section
* Improved some sections according to the feedback from the “Flasher
Reader Test”
6.98
AG
Added Flasher Compact
6.51
AB
moved Universal Flashloader device specifics to UM08037
6.50c
MF
added secure are ASCII commands
6.46
MF
corrected multi image sample
6.36
MF
added Portable PLUS specific section in multiple-file chapter for clarification
6.34
3
190221
MF
updated chapter Batch Programming in stand-alone mode
6.34
2
180205
AB
Removed all Flasher ATE related topics.
* Content has been moved to UM08035_FlasherATE.pdf
Chapter “Hardware”
* Added safety disclaimer for JTAG isolator
6.32
2
180205
AB
* Added STM8 support to universal flash loader.
6.30
1
180222
AG
* Section “Custom labels” added.
6.20
1
171130
AB
* Section “Flasher ATE” added.
Added chapter “TCP Services”
6.20
AB
* Section “Flasher Portable PLUS” added.
6.10a
EL
Chapter “Introduction”
* Section “Flasher Portable” updated.
6.00
NG
* Section “Batch Programming” added.
5.12e
NG
* Section “Setting up Flasher for stand-alone mode” moved.
* Section “Preparing for stand-alone operation manually” added.
5.02f
RH
Chapter “Remote control”
* Section “General usage” addded.
5.02e
EL
* Section “Specifications” updated for all models.
5.02f
RH
* Section “Programming multiple targets” addded.
4.50c
EL
* Section “Programming multiple targets in parallel” addded.
4.98
AG
* Section “Authorized flashing” added.
* Section “Limiting the number of programming cycles” added.
* Section “Operating Modes” updated.
4.86
AG
* Section “Newline encoding” added.
4.80
1
131220
AG
4
Manual
Revision
version
Date
By
Description
* Section “Multiple File Support” updated.
4.80
EL
* Section “Commands to Flasher” updated.
“#FCRC” command added.
4.78
AG
* Section “Features of Flasher Portable” added.
* Section “Flasher Portable” added.
4.72
EL
* Section “Patch file support” added.
4.64a
EL
* Section “LED status indicators” updated.
4.63a
EL
Chapter “Remote Control”
* Section “ASCII command interface”
Chapter “ASCII interface via Telnet” added.
4.62
EL
Flasher ARM, Flasher RX and Flasher PPC manual have been combined.
5.02
RE
New commands #FLIST and #MKDIR in ASCII command interface
5
About this document
Assumptions
This document assumes that you already have a solid knowledge of the following:
The software tools used for building your application (assembler, linker, C compiler).
The C programming language.
The target processor.
DOS command line.
If you feel that your knowledge of C is not sufficient, we recommend The C Programming Language by Kernighan and Richie (ISBN 0--13--1103628), which describes the standard in C programming and, in newer editions, also covers the ANSI C standard.
How to use this manual
This manual explains all the functions and macros that the product offers. It assumes you have
a working knowledge of the C language. Knowledge of assembly programming is not required.
Typographic conventions for syntax
This manual uses the following typographic conventions:
Style
Used for
Body
Body text.
Keyword
Text that you enter at the command prompt or that appears on
the display (that is system functions, file- or pathnames).
Parameter
Parameters in API functions.
Sample
Sample code in program examples.
Sample comment
Comments in program examples.
Reference
Reference to chapters, sections, tables and figures or other documents.
GUIElement
Buttons, dialog boxes, menu names, menu commands.
Emphasis
Very important sections.
6
7
Table of contents
1
Introduction ..................................................................................................................10
1.1
1.2
2
Flasher overview .......................................................................................... 11
1.1.1 Features of Flasher ARM/PPC/RX/PRO .................................................. 11
1.1.2 Features of Flasher Compact .............................................................. 11
1.1.3 Features of Flasher Portable/Flasher Portable PLUS ................................ 12
1.1.4 Working environment .........................................................................12
Specifications ...............................................................................................14
1.2.1 Specifications for Flasher ARM ............................................................ 14
1.2.2 Specifications for Flasher RX .............................................................. 16
1.2.3 Specifications for Flasher PPC ............................................................. 18
1.2.4 Specifications for Flasher PRO .............................................................20
1.2.5 Specifications for Flasher Compact ...................................................... 23
1.2.6 Specifications for Flasher Portable PLUS ............................................... 26
1.2.7 Specifications for Flasher Portable ....................................................... 29
Working with Flasher .................................................................................................. 32
2.1
2.2
2.3
2.4
2.5
2.6
2.7
2.8
2.9
Flasher Portable PLUS ...................................................................................33
2.1.1 Housing & Buttons ............................................................................ 33
2.1.2 Configuration .................................................................................... 34
Flasher Portable ........................................................................................... 35
2.2.1 Housing & Buttons ............................................................................ 35
File system ..................................................................................................37
Setting up the IP interface ............................................................................ 38
2.4.1 Connecting the first time ................................................................... 38
Operating modes ......................................................................................... 39
2.5.1 PC-based mode .................................................................................39
2.5.2 Stand-alone mode ............................................................................. 40
2.5.3 File access mode ...............................................................................42
Setting up Flasher for stand-alone mode .........................................................43
2.6.1 Preparing for stand-alone operation manually ....................................... 46
Universal Flash Loader mode ......................................................................... 48
2.7.1 Preparing manually ........................................................................... 48
2.7.2 Preparing using the PC utility ............................................................. 51
Multiple File Support .....................................................................................52
2.8.1 Flasher Portable specifics ................................................................... 52
2.8.2 Flasher Portable PLUS specifics ........................................................... 53
Custom labels ..............................................................................................55
2.9.1 Hardware and software requirements .................................................. 55
2.9.2 Assigning labels ................................................................................ 55
2.9.3 Considerations .................................................................................. 56
8
2.10
2.11
2.12
2.13
2.14
2.15
2.16
2.17
2.18
2.19
3
TCP Services .............................................................................................................. 76
3.1
3.2
4
Overview .....................................................................................................80
Handshake control ....................................................................................... 81
ASCII command interface ............................................................................. 82
4.3.1 Introduction ......................................................................................82
4.3.2 General command and reply message format ....................................... 82
4.3.3 General usage .................................................................................. 82
4.3.4 Settings for ASCII interface via RS232 .................................................82
4.3.5 Settings for ASCII interface via Telnet ................................................. 82
4.3.6 Commands and replies ...................................................................... 83
Performance ................................................................................................................93
5.1
6
FTP Server .................................................................................................. 77
3.1.1 Access data ...................................................................................... 77
Web server ..................................................................................................78
Remote control ............................................................................................................79
4.1
4.2
4.3
5
Programming multiple targets ...................................................................... 57
2.10.1 Programming multiple targets with J-Flash ......................................... 57
Batch Programming in stand-alone mode ...................................................... 58
2.11.1 Flasher Portable specifics ..................................................................59
2.11.2 Examples ........................................................................................60
Serial number programming ........................................................................ 61
2.12.1 Serial number settings ..................................................................... 61
2.12.2 Serial number file ............................................................................62
2.12.3 Serial number list file ...................................................................... 62
2.12.4 Programming process .......................................................................63
2.12.5 Downloading serial number files to Flasher ......................................... 64
2.12.6 Sample setup ..................................................................................64
Patch file support ....................................................................................... 66
2.13.1 Newline encoding ............................................................................ 67
Limiting the number of programming cycles .................................................. 68
2.14.1 Changed fail/error LED indicator behavior ...........................................68
2.14.2 Required Flasher hardware version for Cntdown.txt support .................. 68
Authorized flashing ..................................................................................... 69
2.15.1 Creating / Adding the secure area ..................................................... 69
2.15.2 Moving files to the secure area ......................................................... 69
2.15.3 Considerations to be taken when using the secure area ........................ 70
2.15.4 Required Flasher hardware version .................................................... 70
Target interfaces ........................................................................................ 71
Supported architectures .............................................................................. 72
2.17.1 External flashes .............................................................................. 72
2.17.2 Cores ............................................................................................. 72
Programming multiple targets in parallel ....................................................... 74
Logfiles and Quality Management ................................................................. 75
Performance of
5.1.1 Flasher
5.1.2 Flasher
5.1.3 Flasher
5.1.4 Flasher
5.1.5 Flasher
MCUs with internal flash memory ............................................. 94
ARM ..................................................................................... 94
PRO ..................................................................................... 94
Compact ............................................................................... 94
RX ....................................................................................... 94
PPC ...................................................................................... 94
Hardware .....................................................................................................................95
6.1
Flasher
6.1.1
6.1.2
6.1.3
ARM 20-pin JTAG/SWD Connector ....................................................... 96
Pinout JTAG ......................................................................................96
Pinout SWD ...................................................................................... 97
Target power supply .......................................................................... 98
9
6.2
6.3
6.4
6.5
6.6
7
Support and FAQs .................................................................................................... 107
7.1
7.2
8
Flasher RX 14-pin connector ..........................................................................99
6.2.1 Target power supply ........................................................................ 100
Flasher PPC 14-pin connector ...................................................................... 101
Target board design ....................................................................................102
6.4.1 Pull-up/pull-down resistors ............................................................... 102
6.4.2 RESET, nTRST ................................................................................. 102
Adapters ................................................................................................... 103
6.5.1 JTAG Isolator .................................................................................. 103
6.5.2 J-Link Needle Adapter ...................................................................... 104
How to determine the hardware version ........................................................ 106
Contacting support ..................................................................................... 108
Frequently Asked Questions .........................................................................109
Background information ............................................................................................ 110
8.1
Flash programming .....................................................................................111
8.1.1 How does flash programming via Flasher work? ...................................111
8.1.2 Data download to RAM .....................................................................111
8.1.3 Available options for flash programming ............................................. 111
8.1.4 How does the universal flash programming work? ................................111
9
Glossary .................................................................................................................... 112
10
Literature and references ........................................................................................116
Chapter 1
Introduction
This chapter gives a short overview about the different models of the Flasher family and
their features. Additional information can be found in our Wiki. You can find it under the
following URL:
https://wiki.segger.com/Main_Page
11
CHAPTER 1
1.1
Flasher overview
Flasher overview
Flasher is a programming tool for microcontrollers with on-chip or external flash memory.
Flasher is designed for programming flash targets with the J-Flash software or stand-alone.
In addition to that Flasher can also be used as a regular J-Link. For more information about
J-Link in general, please refer to the J-Link / J-Trace User Guide which can be downloaded
at http://www.segger.com.
Flasher connects to a PC using the USB/Ethernet/RS232 interface (what host interfaces
are available depends on the Flasher model), running Microsoft Windows 2000, Windows
XP, Windows 2003, Windows Vista, Windows 7, Windows 8 or Windows 10. In stand-alone
mode, Flasher can be driven by the start/stop button, or via the RS232 interface (handshake
control or ASCII interface). Flasher always has a 20-pin connector, which target interfaces
are supported depends on the Flasher model:
1.1.1
Flasher
Flasher
Flasher
Flasher
Flasher
ARM: JTAG and SWD are supported.
RX: JTAG is supported. Flasher comes with additional 14-pin RX adapter
PPC: JTAG is supported. Flasher comes with additional 14-pin PPC adapter.
PRO: JTAG and SWD are supported.
Compact: JTAG and SWD are supported.
Three boot modes: PC-based mode, stand-alone mode, file access mode
Stand-alone JTAG/SWD programmer (Once set up, Flasher can be controlled without
the use of PC program)
No power supply required, powered through USB
Supports internal and external flash devices
128 MB memory for storage of target program
Can be used as J-Link (emulator) with a download speed of up to 720 Kbytes/second
Data files can updated via USB/Ethernet (using the J-Flash software), via FTP, via RS232
or via the file access mode of Flasher
Supported cores
Supported
target
interfaces
Flasher
ARM
ARM7/ARM9/Cortex-M
JTAG, SWD
between 170 and 300
Kbytes/second
Flasher RX
Renesas RX610, RX621,
RX62N, RX62T
JTAG
between 30-300 Kbytes/second
JTAG
up to 138 Kbytes/second
JTAG, SWD
between 30-300 Kbytes/ second
Flasher
model
Flasher PPC Power PC e200z0
Flasher
PRO
1.1.2
ARM7/ARM9/Cortex-M Renesas RX610, RX621, RX62N,
RX62T Power PC e200z0
Flash programming speed
(depending on target hardware)
Data files can updated via USB/Ethernet (using the J-Flash software) or via the file
12
CHAPTER 1
Flasher overview
Supported cores
Supported
target
interfaces
Flasher
ARM
ARM7/ARM9/Cortex-M
JTAG, SWD
between 170 and 300
Kbytes/second
Flasher RX
RX62N, RX62T
JTAG
JTAG
JTAG, SWD
Flasher
model
Flasher
Compact
1.1.3
Stand-alone in-circuit-programmer (Once set up, Flasher can be controlled without the
use of a PC program)
Powered by an internal rechargeable battery (standard batteries for Flasher Portable),
no Laptop or external power supply required.
Multiple firmware images can be stored on Flasher
Easy selection of image to be programmed, via button
Supported CPUs: ARM Cortex, Legacy ARM7/9, Renesas RX, Freescale PowerPC
Free software updates*, 1 year of support
Data files can be updated via the file access mode functionality or via J-Flash
Programming speed between 30-300 Kbytes/second (actual speed depends on target
hardware)
Note
Ethernet and RS232 as host interface are not available for Flasher Portable
Note
*As a legitimate owner of a SEGGER Flasher, you can always download the latest
software free of charge. Though not planned and not likely, we reserve the right to
change this policy. Note that older models may not be supported by newer versions
of the software. Typically, we support older models with new software at least 3 years
after end of life
Supported cores
Supported
target interfaces
ARM7/ARM9/Cortex-M
JTAG, SWD
RX62N, RX62T
JTAG
between 170 and 300 Kbytes/second
Power PC e200z0
JTAG
1.1.4
Working environment
General
The Flasher can operate from a PC with an appropriate software like J-Flash or in standalone mode.
13
CHAPTER 1
Flasher overview
Host System
IBM PC/AT or compatible CPU: 486 (or better) with at least 128MB of RAM, running Microsoft Windows 2000, Windows XP, Windows 2003, Windows Vista, Windows 7, Windows
8 or Windows 10. It needs to have a USB, Ethernet or RS232 interface available for communication with Flasher.
Power supply
Flasher Portable: 3x standard AAA batteries or 5V DC, min. 100 mA via USB connector.
Flasher Portable PLUS: internal rechargeable 680mAh Li-Ion battery, min. 100 mA via USB
connector.
Other Flashers: 5V DC, min. 100 mA via USB connector.
Installing Flasher PC-software (J-Flash)
The latest version of the J-Flash software, which is part of the J-Link software and documentation package, can always be downloaded from our website:
segger.com/jlink-software.html For more information about using J-Flash please refer to
UM08003_JFlashARM.pdf (J-Flash user guide) which is also available for download on our
website.
14
CHAPTER 1
1.2
Specifications
Specifications
1.2.1
General
Supported OS
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Microsoft
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Windows
Operating Temperature
+5 °C … +60 °C
Storage Temperature
-20 °C … +60 °C
Relative Humidity (non-condensing)
6.25
Hz)
• Programming (slow blinking on/off time: 300ms
=> ~1.67 Hz)
• Verifying (slow blinking, on/off time: 100ms =>
5 Hz)
GREEN: constant
RED: off or constant
GREEN constant, RED off: Operation successful.
GREEN constant, RED constant: Operation failed
Goes back to state #0 automatically, but in case of
operation failed, RED remains on until state #1 is
entered the next time.
2
3
42
CHAPTER 2
2.5.3
Operating modes
File access mode
When pressing the Start/Stop button (for Flasher Portable PLUS PRG button) of the Flasher
while connecting it to the PC, Flasher will boot in the “file access mode”. If you are using
a self-powered Flasher such as the Flasher Portable Plus, the Flasher must be turned off
before connecting it. This mode can be used to downdate a Flasher firmware version if
a firmware update did not work properly and it can be used to configure Flasher for the
“stand-alone mode”, without using J-Flash. If Flasher has been configured for “stand-alone
mode” as described in the section above, there will be four files on the drive, FLASHER.CFG,
FLASHER.DAT, FLASHER.LOG, SERIAL.TXT.
FLASHER.CFG contains the configuration settings for programming the target device and
FLASHER.DAT contains the data to be programmed. FLASHER.LOG contains all logging information about the commands, performed in stand-alone mode. The SERIAL.TXT contains
the serial number, which will be programmed next. J-Flash supports to configure Flasher
for automated serial number programming.
Currently, J-Flash does not support to configure Flasher for automated serial number programming.
If you want to configure multiple Flasher for the same target you do not have to use J-Flash
all the time. It is also possible to copy the FLASHER.CFG and the FLASHER.DAT files from a
configured Flasher to another one. To copy these files boot Flasher in “file access mode”.
43
2.6
CHAPTER 2
In order to set up Flasher for the stand-alone mode it needs to be configured once using the
J-Flash software. For more information about J-Flash, please refer to the J-Flash User Guide.
After starting J-Flash, open the appropriate J-Flash project for the target Flasher shall be
configured for, by selecting File -> Open Project. If J-Flash does not come with an appropriate sample project for the desired hardware, a new project needs to be created by
selecting File -> File -> New Project.
After the appropriate project has been opened / created, the data file which shall be programmed needs to be loaded, by selecting File -> Open. After this J-Flash should look
like in the screenshot below.
44
CHAPTER 2
Before downloading the configuration (project) and program data (data file) to Flasher, the
connection type (USB/IP) needs to be selected in the project. These settings are also saved
on a per-project basis, so this also only needs to be setup once per J-Flash project. The
connection dialog is opened by clicking Options -> Project settings -> General.
The connection dialog allows the user to select how to connect to Flasher. When connecting
to a Flasher via TCP/IP it is not mandatory to enter an IP address. If the field is left blank
and File -> Download to programmer is selected, an emulator selection dialog pops up
which shows all Flasher which have been found on the network. The user then can simply
select the Flash he wants to download the configuration to.
45
CHAPTER 2
In order to download the configuration and program data to the Flasher, simply select File
-> Download config & data file to Flasher.
46
CHAPTER 2
The J-Flash log window indicates that the download to the emulator was successful.
From now on, Flasher can be used in stand-alone mode (without host PC interaction) for
stand-alone programming.
2.6.1
As an alternative, J-Flash can also be used to save config and data file to a hard drive.
This files can later be copied to a Flasher without using J-Flash, which is useful to prepare
additional Flasher for stand-alone programming, if for example a company plans to widen
its production, new Flasher units can be bought and used in production by simply copying
the files to the new units.
Creating config and data files
J-Flash config (*.CFG) and data (*.DAT) files can be created by using the “Save Flasher
config file…” and “Save Flasher data file…” options in the “File” menu.
For some devices, additional files (*.PEX) are needed. J-Flash will create a subdirectory (in
the same directory as the config file) with the same name as the config file and place the
files needed in this directory.
About *.PEX files
When using the “Save Flasher config file…” menu point or when using the “multiple configurations stored on Flasher” feature (See Multiple File Support on page 52.) feature, the
following needs to be taken care of:
For some devices, special connect, reset etc. sequences are necessary which are stored in
so-called *.PEX files on the Flasher.
When using the “Download config & data file to Flasher”, J-Flash takes care of correct use
and download of these files to Flasher.
47
CHAPTER 2
When creating the config files manually and later download them to the Flasher manually,
it is user’s responsibility to put them at the right place.
The *.PEX files need to be placed in a subdirectory with the same name as the corresponding
*.cfg file. J-Flash creates a directory with the correct name automatically when a config
file is created.
Example:
MyConf0 is a project for a device that requires a *.PEX file for connect.
MyConf1 is a project for a device that requires no *.PEX file at all.
48
CHAPTER 2
2.7
As an alternative to the stand-alone mode, configured via J-Flash, there is the Universal
Flash Loader mode. While the normal stand-alone mode relies on using the debug interface
of the device, the Universal Flash Loader mode uses device or vendor specific programming
interfaces and protocols and therefore it is independent of the CPU core.
The Universal Flash Loader is available for the following Flasher models:
Flasher PRO
Flasher Compact
For some of the supported devices, SEGGER offers specific adapters.
2.7.1
Preparing manually
The Universal Flash Loader uses an initialization file (*.UNI), a device specific flash programming algorithm (*.PEX) and a data file (*.DAT).
2.7.1.1
Configuration
The initialization file basically is split into three parts. The first part, the section [DEVICE],
controls the generic behavior of the Universal Flash Loader. It specifies which protocol
driver and data file to use. It allows enabling and configuring target power and it defines
which actions to perform. The second part consists of one or more [BANKx] sections, which
contain information about the memories. The third part, the section [CONFIG], includes
configuration settings for the protocol driver.
An .ini file might look as follows:
[OPTIONS]
TargetPower = "0"
ChipErase
= "0"
[TASKS]
CheckBlank
Erase
Program
Verify
Secure
[DEVICE]
Algo
Data
Offset
= "RL78.PEX"
= "ALL_6k.mot"
= "0x00000000"
"1"
"1"
"1"
"1"
"1"
[BANK0]
; Code Flash
Base = "0x00000000"
Size = "0x00004000"
Sect = "0x00000400"
[BANK1]
; Data Flash
Base = "0x000F1000"
Size = "0x00000800"
Sect = "0x00000400"
[CONFIG]
BaudRate = "1000000"
ClearConfigOnConnect = "0x00"
Security = "0xFF"
ShieldStart = "0x0000"
ShieldEnd = "0x000F"
49
CHAPTER 2
[OPTIONS]
TargetPower
If set to a value >0, power is applied to the target. The value defines the delay (in ms)
after enabling the target power supply and before starting to communicate with the target.
ChipErase
If set to 1, the chip erase function is called for erasing the chip.
Note
Do not enable this setting if the flash programming algorithm does not support chip
erase.
[TASKS]
CheckBlank
Defines if a blank check should be performed before erasing a sector.
Erase
Defines if the sector should be erased before programming.
Program
Defines if the sector should be programmed.
Verify
Defines if the sector should be verified after programming.
Secure
Defines if the device should be secured or protected against read-out after verifying.
[DEVICE]
Algo
File name of the flash programming algorithm. This file is provided by SEGGER and will
typically support a series of devices.
Data
File name of the data file to program. The flasher supports the Flasher DTA, the Intel HEX,
the Motorola S-Record and the binary file format. Flasher DAT files are generated by J-Flash
and offer high performance together with high flexibility. The other file formats produce a
small overhead, because they have to be parsed before the data can be programmed.
Offset
Offset to apply when programming a binary data file. Unless specified differently, binary
files start at offset 0x00000000.
[BANKx]
x blocks with configuration data for the flash banks. All three parameters (Base, Size and
Sect) are mandatory.
Base
Base address of the flash bank.
50
CHAPTER 2
Size
Total size of the flash bank.
Sect
Sector size of the flash bank.
[CONFIG]
This section includes specific configuration data for the flash programming algorithm.
There are no general parameters.
Note
The data file must be organized in ascending address order. Gaps can be included. But
descending addresses will result in programming errors. You can sort the data files by
loading them into the J-Flash tool and saving it as a new file.
51
CHAPTER 2
2.7.2
In order to set up Flasher for the Universal Flash Loader mode, a PC utility called SEGGER
Universal Flash Loader Configurator is available for download.
The Universal Flash Loader Configurator comes with a large list of devices and flash programming algorithms. If you are going to use a device from one of the supported families
which currently is not available in the utility, feel free to contact the support.
52
CHAPTER 2
2.8
It is also possible to have multiple data files and config files on Flasher, to make Flasher
more easy to use in production environment. To choose the correct configuration file and
data file pair, a FLASHER.INI file is used. This init file contains a [FILES] section which
describes which configuration file and which data file should be used for programming. A
sample content of a FLASHER.INI file is shown below:
[FILES]
DataFile = "Flasher1.dat"
ConfigFile = "Flasher1.cfg"
Using this method all configuration files and data files which are used in the production
only have to be downloaded once. From there on a configuration file / data file pair can
be switched by simply replacing the FLASHER.INI by a new one, which contains the new
descriptions for the configuration file and data file. The FLASHER.INI can be replaced in
two ways:
1. Boot Flasher in file access mode in order to replace the FLASHER.INI
2. If Flasher is already integrated into the production line, runs in stand-alone mode and
can not be booted in other mode: Use the file I/O commands provided by the ASCII
interface of Flasher, to replace the FLASHER.INI. For more information about the file I/
O commands, please refer to File I/O commands on page 87.
Note
Flasher supports 8.3 filenames only (8 characters filename, 3 characters file extension). Using longer filenames may result in incorrect operation.
2.8.1
Flasher Portable allows to choose between four configuration and data file pairs during
runtime by using the select/arrow button on the front of Flasher Portable.
Which config / data file pair is used for which image selection position is determined by the
contents of the FLASHER.INI. For this, the FLASHER.INI contents in the [FILES] section
have been extended. The sample below shows how to enable the user to select between
four different images on the Flasher portable via the select / arrow button:
[FILES]
DataFile = "First.dat"
ConfigFile = "First.cfg"
DataFile1 = "Second.dat"
ConfigFile1 = "Second.cfg"
DataFile2 = "Third.dat"
ConfigFile2 = "Third.cfg"
DataFile3 = "Fourth.dat"
ConfigFile3 = "Fourth.cfg"
Using this method, all configuration files and data files which are used in the production
only have to be stored on Flasher Portable via file access mode. From there on, switching
between the files can be done by simply using the selection button of Flasher Portable.
53
CHAPTER 2
2.8.1.1
Example
1 Target, 2 Datafiles (e.g. boot loader und application) --> same configuration file (*.CFG)
but different data files (*.DAT) should be used.
Open pre-configured J-Flash project
File -> Save Flasher config file … (DEFAULT.CFG)
Open data file 1 (boot loader)
File -> Save Flasher data file … (BOOT.DAT)
Open data file 2 (application)
File -> Save Flasher data file … (APP.DAT)
Create the a FLASHER.INI file (content see below)
Connect the Flasher in file access mode to the PC
Copy DEFAULT.CFG, BOOT.DAT, APP.DAT and FLASHER.INI on the Flasher
FLASHER.INI content:
[FILES]
DataFile
ConfigFile
DataFile1
ConfigFile1
2.8.2
"BOOT.DAT"
"DEFAULT.CFG"
"APP.DAT"
"DEFAULT.CFG"
Flasher Portable PLUS allows to choose between 16 configuration and data file pairs during
runtime by using the select button on the front of Flasher Portable PLUS.
the contents of the FLASHER.INI. For this, the FLASHER.INI may contain several [BATCH]
sections. The sample below shows how to enable the user to select between five different
images on the Flasher Portable PLUS via the select / arrow button:
[BATCH]
DataFile =
ConfigFile
[BATCH1]
DataFile =
ConfigFile
[BATCH2]
DataFile =
ConfigFile
[BATCH7]
DataFile =
ConfigFile
[BATCH15]
DataFile =
ConfigFile
"First.dat"
= "First.cfg"
"Second.dat"
= "Second.cfg"
"Third.dat"
= "Third.cfg"
"Proj_8.dat"
= "Proj_8.cfg"
"Proj_16.dat"
= "Proj_16.cfg"
Using this method, all configuration files and data files which are used in the production only
have to be stored on Flasher Portable PLUS via file access mode. From there on, switching
between the files can be done by simply using the selection button of Flasher Portable PLUS.
Please also consider the chapter Batch Programming in stand-alone mode on page 58.
Note
There the Flasher Portable PLUS checks if the files exist on its flash storage. If the
a file is missing the entry will be skip and the selection jumps directly to the next
entry in the list.
54
CHAPTER 2
Note
You may have gaps in the list. The missing entries will be skipped when selecting the
next configuration.
Note
The [Files] section is supported by the Flasher Portable PLUS, too. But the number
of configuration is limited to four.
2.8.2.1
Example
[BATCH]
DataFile
= "BOOT.DAT"
ConfigFile = "DEFAULT.CFG"
DisplayName = "Bootloader"
[BATCH1]
DataFile
= "APP.DAT"
DisplayName = "Application"
[BATCH2]
DataFile
= "BOOT.DAT"
DataFile1
= "APP.DAT"
ConfigFile1 = "DEFAULT.CFG"
DisplayName = "BL and App"
55
CHAPTER 2
2.9
Custom labels
Custom labels
Flasher supports to assign custom labels to configurations. This allows to specify easy to
remember names for configurations that are stored on the Flasher.
2.9.1
This feature is supported by the following models:
This feature is supported since V6.30e of the software package and firmware
2.9.2
Assigning labels
The configuration and data file pairs are specified in the FLASHER.INI file:
[FILES]
DataFile
ConfigFile
DataFile1
ConfigFile1
"IMAGE0.dat"
"IMAGE0.cfg"
"IMAGE1.dat"
"IMAGE1.cfg"
By default, Flasher will show the names of the configuration and data file:
By adding DisplayName, DisplayName1, … keys to the FLASHER.INI, a custom label can
be shown instead:
[FILES]
DisplayName
DataFile
ConfigFile
DisplayName1
DataFile1
ConfigFile1
"FW smartwatch"
"IMAGE0.dat"
"IMAGE0.cfg"
"FW smart meter"
"IMAGE1.dat"
"IMAGE1.cfg"
The images will now be shown as follows:
56
CHAPTER 2
2.9.3
Custom labels
Considerations
The maximum length of a custom label is 32 characters. If this length is exceeded, the
label is ignored and Flasher switches back to default mode for the affected configuration.
57
CHAPTER 2
2.10
It is possible to program multiple targets which are located in a JTAG chain. The targets
will be programmed each with a configuration and a data file. The configuration for the
desired target must be selected before it can be programmed, this can be done with the
#SELECT command. For more information how to use the #SELECT command please refer
to Chapter “3.3.5 Commands to Flasher”.
Example
Three devices should be programmed.
JTAG Chain: TDI --> Device2 --> Device1 --> Device0 --> TDO
Three configurations would be stored on the flasher:
Config 0: Configured to program Device0 (DEVICE0.CFG, DEVICE0.DAT)
Config 1: Configured to program Device1 (DEVICE1.CFG, DEVICE1.DAT)
Config 2: Configured to program Device2 (DEVICE2.CFG, DEVICE2.DAT)
Selection and programming of the target will be done via the ASCII interface:
#SELECT DEVICE0
#AUTO
#SELECT DEVICE1
#AUTO
#SELECT DEVICE2
#AUTO
2.10.1
Programming multiple targets can also be done via J-Flash using the command line interface. For this each target must be handled with its own project file.
Example
JFlash.exe -openproj"Device0.jflash" -open"Device0.hex" -auto -exit
JFlash.exe -openproj"Device1.jflash" -open"Device1.hex" -auto -exit
JFlash.exe -openproj"Device2.jflash" -open"Device2.hex" -auto -exit
58
CHAPTER 2
2.11
Batch programming allows to execute different stand-alone mode jobs in batch to be executed in immediate succession, without any user interaction in between. This can be used
for example to program multiple targets in a JTAG-Chain or multiple data files to a target.
A batch may contains an unlimited number of configurations which consist of a data file
(*.DAT) and config file (*.CFG). For further information regarding config and data files,
please refer to Preparing for stand-alone operation manually on page 46.
In order to specify the batch jobs, a FLASHER.INI file is used. This init file contains a
[BATCH] section which describes which configuration pairs (*.DAT and *.CFG file) should
be used for each batch job. A sample content of a FLASHER.INI file is shown below:
[BATCH]
DataFile = "Flasher0.dat"
ConfigFile = "Flasher0.cfg"
DataFile1 = "Flasher1.dat"
ConfigFile1 = "Flasher1.cfg"
The Flasher Portable PLUS screen will show that the number of jobs contained in the batch
and the configuration file name of the first job.
The progress will be shown during the flashing action. The Flasher lists the current job of
the batch, the current sector address and the percentage of the currently executed action.
The result of the programming will be shown on the screen after finishing all jobs.
59
CHAPTER 2
Creating / Replacing of the FLASHER.INI file can done in two ways:
interface of Flasher, to replace the FLASHER.INI . For more information about the file
I/O commands, please refer to File I/O commands on page 87. In case of an error
occurred during execution, the Flasher terminates the entire batch processing.
Note
Please note that the batch programming feature can not be used with the multiple file
support feature. Therefore, neither the #SELECT ASCII command nor the [FILES] tag
in the FLASHER.INI file can be used.
Note
2.11.1
Flasher Portable allows to choose between four different batches during runtime by using
the select/arrow button on the front of Flasher Portable. Which batch configuration is used
for which image selection position is specified in the FLASHER.INI. For this, the FLASHER.INI
contents in the [BATCH] section have been extended. The sample below shows how to
enable the user to select between four different batches on the Flasher Portable via the
[BATCH]
DataFile2 = "Flasher2.dat"
ConfigFile2 = "Flasher2.cfg"
[BATCH1]
DataFile = "TEST.dat"
ConfigFile = "Test.cfg"
[BATCH2]
DataFile = "VALIDATE.dat"
Using this method allows to have different batches for different setups used in the production to be stored once on the Flasher Portable via file access mode. From there on, switching
between the batches can be done by simply using the selection button of Flasher Portable.
60
CHAPTER 2
2.11.2
Examples
Example 1: Programming two Data files to the same target
Open your J-Flash project.
Use File -> Save Flasher config file… to save the .CFG file (in this example:
STM32F4.CFG).
Select the first binary and use File -> Save Flasher Data file… to save the first .DAT file
(in this example: DATA0.DAT).
Select the second binary and use File -> Save Flasher Data file… to save the second
data file .DAT file (in this example: DATA1.DAT).
Copy the Files to the Flasher e.g. by using file access mode.
Create a FLASHER.INI file in the root directory of the Flasher.
Exemplary content of FLASHER.INI:
[BATCH]
DataFile = "DATA0.dat"
ConfigFile = "emPower.cfg"
DataFile1 = "DATA1.dat"
ConfigFile1 = "emPower.cfg"
Example 2: Programming one Data file to the first target in a JTAG-Chain and then programming two data files to another device in the JTAG chain.
Example scenario: 2 Devices in a JTAG chain, a STM32F1 and a STM32F4.
Follow the same as described before and additionally:
Create one project file per target (and create a .CFG file of each one).
Make sure each project file is configured correctly, especially the JTAG-Chain position
(See UM8003 “J-Flash” for more detailed info).
[BATCH]
DataFile = "F1DATA.dat"
ConfigFile = "STM32F1.cfg"
DataFile1 = "F4DATA0.dat"
ConfigFile1 = "STM32F4.cfg"
DataFile2 = "F4DATA1.dat"
ConfigFile2 = "STM32F4.cfg"
Example 3: Using multiple Batch sections with Flasher Portable.
Selection 1 will program the STM32F1 target.
Selection 2 will program the STM32F4 target using “F4DATA0.dat”.
Selection 3 will program the STM32F4 target using “F4DATA1.dat”.
Selection 4 will execute 1, 2 and 3 in sequence.
[BATCH]
[BATCH1]
DataFile = "F4DATA0.dat"
ConfigFile = "STM32F4.cfg"
[BATCH2]
DataFile = "F4DATA1.dat"
[BATCH3]
61
CHAPTER 2
2.12
Flasher supports programming of serial numbers. In order to use the serial number programming feature, the J-Flash project to be used as well as some files on the Flasher (depending on the configuration) need to be configured first.
In general, Flasher supports two ways of programming a serial number into the target:
1. Programming continuous serial numbers. Serial number is 1-4 bytes in size. Start serial
number, increment, serial number size and address is configured in the J-Flash project.
2. Programming custom serial numbers from a serial number list file. Start line into serial
number list file to get next serial number bytes, line increment, serial number size and
address is configured in J-Flash project. Serial number list file needs to be specified
and created by user.
In the following some generic information how to setup Flasher & the J-Flash project for
serial number programming are given.
Note
Full serial number programming support has been introduced with V4.51d of the JFlash software and the Flasher firmware that comes with it.
Note
Currently, programming of serial numbers is only supported for stand-alone mode.
Future versions of J-Flash may also support serial number programming in PC-based
mode.
2.12.1
In order to enable the programming of serial numbers in stand-alone mode, the J-Flash
project has to be configured to enable programming a serial number at a specific address.
This is done by enabling the Program serial number option as shown in the screenshot
and table below:
62
CHAPTER 2
Setting
Meaning
Address
The address the serial number should be
programmed at.
Len
The length of the serial number (in bytes)
which should be programmed.
If no serial number list file is given, J-Flash
allows to use a 1-4 byte serial number. In
case of 8 is selected as length, the serial number and its complementary is programmed at the given address.
In case a serial number list file is given,
Flasher will take the serial number bytes
from the list file. If a serial number in the
list file does not define all bytes of Len ,
the remaining bytes are filled with 0s. No
complements etc. are added to the serial
number.
Next SN
In case no serial number list file is given, Next SN is next serial number which
should be programmed. The serial number
is always stored in little endian format in
the flash memory.
Next SN describes the line of the serial
number list file where to read the next
serial number bytes from. Flasher starts
counting with line 0, so in order to start
serial number programming with the first
line of the SNList.txt, Next SN needs to
be set to 0.
Increment
Specifies how much Next SN is incremented.
2.12.2
Serial number file
When selecting File -> Download serial number file to Flasher, J-Flash will create a
Serial number file named as _Serial.txt. This file is downloaded
as SERIAL.TXT on Flasher. The file is generated based on the serial number settings in
the J-Flash project and will contain the value defined by the Next SN option. The serial
number file can also be manually edited by the user, since the serial number is written
ASCII encoded in the SERIAL.TXT file.
2.12.3
In order to program custom serial numbers which can not be covered by the standard serial
number scheme provided by J-Flash (e.g. when programming non-continuous serial numbers or having gaps between the serial numbers), a so called serial number list file needs to
be created by the user. When selecting File-> Download serial number file to Flasher,
J-Flash will look for a serial number list file named as _SNList.txt
in the directory where the J-Flash project is located. This file is downloaded as SNList.txt
on Flasher. The serial number list file needs to be created manually by the user and has
the following syntax:
One serial number per line
Each byte of the serial number is described by two hexadecimal digits.
Example
A 8-byte serial number should be programmed at address 0x08000000.
63
CHAPTER 2
It should be programmed as follows in the memory:
0x08000000: 0x01 0x02 0x03 0x04 0x55 0x66 0x77 0x88
The serial number list file should look as follows:
0102030455667788
The number of bytes to read per line is configured via the Len option in J-Flash. For more
information, please refer to Serial number settings on page 61.
Which line Flasher will read at the next programming cycle, is configured via the Next SN
option in J-Flash. For more information, please refer to Serial number settings on page 61.
In this case Next SN needs to be set to 0, since programming should be started with the
serial number bytes defined in the first line of the file.
Note
If the number of bytes specified in a line of the serial number list file is less than
the serial number length defined in the project, the remaining bytes filled with 0s by
Flasher.
Note
If the number of bytes specified in a line of the serial number list file is greater than
the serial number length defined in the J-Flash project, the remaining bytes will be
ignored by Flasher.
2.12.4
Programming process
Flasher will increment the serial number in SERIAL.TXT by the value defined in Increment
, after each successful programming cycle.
For each programming cycle, the FLASHER.LOG on the Flasher is updated and contains the
value from SERIAL.TXT that has been used for the programming cycle.
Note
The serial number in SERIAL.TXT will also be incremented in case if serial number
programming is disabled, to make sure that for the Flasher logfile there is a reference
which programming cycle passed and which not. As long as serial number programFlasher User Guide (UM08022)
64
CHAPTER 2
ming has not been enabled in the J-Flash project, Flasher does not merge any serial
number data into the image data to be programmed.
2.12.5
Downloading the serial number files needs to be done explicitly by selecting File-> Download serial number file to Flasher. Please note that the File -> Download config &
data file to Flasher option does only download the configuration and data file to Flasher
since usually the current serial number used for programming shall not be reset/overwritten when just updating the image Flasher shall program.
2.12.6
Sample setup
In the following a small sample is given how to setup Flasher for serial number programming. In the following sample, 4-byte serial numbers starting at 1234567 (0x12D687) shall
be programmed at address 0x08001000.
Defining serial number address, length and start value
In the J-Flash project the following needs to be defined:
Address is 0x08001000
Next SN is 1234567
Increment is 1
Len is 4 (bytes)
65
CHAPTER 2
Downloading configuration, data and serial number to Flasher.
After setting up the rest of the configuration (Target interface etc.) and selecting an appropriate data file, the configuration, data and serial number file is downloaded into Flasher
via the File -> Download config & data file to Flasher and File-> Download serial
number file to Flasher option.
After downloading the serial number to Flasher, J-Flash also created the _Serial.txt.
Now Flasher is prepared to program the 8-byte serial number.
66
CHAPTER 2
2.13
Patch file support
Patch file support
In stand-alone mode Flasher supports patch files which allows to patch the content of the
data to be programmed. Patches for undefined memory locations will be ignored, so there
need to be placeholders in the data file. Before starting programming process in stand-alone
mode, Flasher will look for a file named Patches.txt being present on the Flasher. This file
includes the patches. If this file is present, the number in Serial.txt describes the line
number of the Patches.txt that will be used for the current cycle (line counting starts at 0).
Each line in the Patches.txt can hold up to 4 patches, where each patch can be up to
32 bytes in length.
Syntax
Each line begins with followed by each patch ,:
in sequence and separated by commas. So the syntax for = = 4 would be
as follows:
:,,:\r\n
Find below a table which describes each parameter.
Parameter
Description
Describes the number of patches in this patch line. Max. value is 4.
Describes the address to be patched. Value is expected in
hex.
Number of bytes for the current patch. Max. value is 20h (32
in decimal). Value is expected in hex.
Describes the data to be patched. is always expected as 2 hexadecimal characters per byte.
Note
All values are expected in hexadecimal format (hex).
section is always preceded by “:”, not “,”.
Example
Below is an example patch.
1,18,4:01020304\r\n
Patching the following data:
with the example patch will result in the following data:
67
CHAPTER 2
Patch file support
Please note that as mentioned earlier patching undefined memory locations will be ignored.
Applying the example patch to the following data:
Causes no data to be patched, as can be seen in the following image:
Therefore it is necessary to first write placeholder data to the memory locations which are
supposed to be patched.
An example for such a placeholder can be seen here:
Please note that the actual data inside the placeholder does not matter to the Flasher,
because it is overwritten during patching.
Applying the example patch will now work as expected:
Single patch via RS232
Alternatively, you can start a programming cycle with patch data that is only valid for this
one cycle (no need for a Patches.txt file):
Send the #AUTO PATCH ,,:
command via Flasher ASCII interface. The parameters have the same function as described
in the table above.
2.13.1
Newline encoding
In general, for all patch files, init files etc. Flasher supports both newline encodings:
Windows: \r\n
Unix/Mac: \n
All parser functionality etc. are written to be independent from the host operating system.
68
CHAPTER 2
2.14
Flasher provides a mechanism to limit the number of programming cycles that can be
performed in stand-alone mode with the configuration that is stored on the Flasher. To
make use of this feature, a file called Cntdown.txt needs to be placed on the Flasher. This
file simply contains a decimal number (32-bit unsigned integer) that describes how many
programming cycles can be performed with the current setup.
This feature especially makes sense when used in combination with authorized flashing.
For more information about authorized flashing, please refer to Authorized flashing on
page 69.
Note
The number in the Cntdown.txt is only updated on a successful programming cycle.
Programming cycles that failed, do not affect the Cntdown.txt.
2.14.1
In case a Cntdown.txt is found at boot time, the fail/error LED of Flasher behaves different
from normal. If the number of programming cycles left is 10 or below, the following will
happen:
The red error/fail LED will lit for 1 second
After this, it will blink/toggle x times @ 5 Hz, indicating the number of programming
cycles left. (blinking 5 times for 5 cycles left, …)
support
Older Flasher models do not support the limiting of programming cycles. The Flashers with
the following serial number ranges do not support limiting of programming cycles:
1621xxxxx
1630xxxxx
4210xxxxx
4110xxxxx
(Flasher
(Flasher
(Flasher
(Flasher
ARM V2)
ARM V3)
PPC V1)
RX V1)
All other models / hardware versions support limiting of programming cycles.
69
CHAPTER 2
2.15
Authorized flashing
Authorized flashing
Current hardware versions of Flasher support creation of a so called secure area which
allows to pre-configure the Flasher with a given setup and then give it to external production
facilities etc. without the possibility to read out the Flasher contents via file access mode,
FILE I/O functionality (J-Link Commander) or RS232 commands. This section describes how
to setup a secure area on a Flasher and how to move the configuration/data file(s) into it.
2.15.1
By default, Flashers are shipped with a public area only (full Flasher flash size accessible
via file access mode etc.). The secure area has to be activated / created once, to make
use of it. This will reserve half of the Flasher storage size (on current models this will be
~64 MB) for the secure area. The secure area can be removed at any time, providing the
full flasher storage to the public area again. The secure area can be created / removed
via J-Link Commander, which is part of the software package that comes with Flasher.
The following secure area related commands are available in J-Link Commander:
securearea create
securearea remove
Note
When creating or removing the secure area, all configuration and data files being
stored on the Flasher, are lost. Please make sure that they are not needed anymore,
before adding / removing the security area.
2.15.2
Before moving configuration + data to the secure area, proper functionality of the setup
should be tested in stand-alone mode. Once the setup is working as expected, do the
following, to move the configuration + data into the secure area:
Start Flasher in file access mode (For more info, please refer to: file access mode on
page 42)
Create a folder “_SECURE”
Move all files that shall be moved to the secure area, into this folder
70
CHAPTER 2
2.15.3
area
Authorized flashing
Reboot Flasher (Do not enter file access mode again, yet! Otherwise, contents will not
be moved). Now, depending on the configuration and data file size, it may take a bit,
before the Flasher Power LED lit. Once it lit, all contents have been moved to the secure
area and the _SECURE folder in the public area has been deleted.
Now Flasher can be used in stand-alone mode, as normal, but the files cannot be read
back by the user / operator.
When using the secure area, some things need to be considered:
2.15.4
All features like multiple file support, patch file support etc. can also be used when
operating from the secure area.
The secure area cannot be read back by any utility. Solely the FLASHER.LOG is always
placed and updated in the public area, even when Flasher operates from the secure
area.
If there is any file/folder in the public area, except the FLASHER.LOG and there is also any
configuration / data present in the secure area, stand-alone flashing will fail because it
is not unambiguous which configuration / data shall be used. In such cases, Flashers with
Ethernet / RS232 interface will output an appropriate error message on programming.
All Flasher models will output an appropriate error message in the FLASHER.LOG.
Moving files from the public into the secure area can be done multiple times, as explained
in Moving files to the secure area on page 69. Each time files are moved from the
public area to the secure area, all contents of the secure area are erased first, to
make sure that no previous configuration is present there.
Older Flasher models do not support authorized flashing. The Flashers with the following
serial number ranges do not support authorized flashing:
1621xxxxx
1630xxxxx
4210xxxxx
4110xxxxx
(Flasher
(Flasher
(Flasher
(Flasher
ARM V2)
ARM V3)
PPC V1)
RX V1)
All other models / hardware versions support authorized flashing.
71
CHAPTER 2
2.16
Target interfaces
Target interfaces
The table below shows the supported target interfaces of the different Flasher models.
Hardware
Supported interfaces
Flasher PRO
JTAG, SWD
Flasher Compact
JTAG, SWD
Flasher ARM
JTAG, SWD
Flasher RX
JTAG
Flasher PPC
JTAG
For more information about the target interfaces itself, please refer to:
UM08001, chapter “Working with J-Link and J-Trace”, section “JTAG interface”
UM08001, chapter “Working with J-Link and J-Trace”, section “SWD interface”
72
CHAPTER 2
2.17
Flasher supports programming of the internal flash of a large number of different microcontrollers. The number of supported devices is steadily growing. You can always find the
latest list of supported devices on our website:
http://www.segger.com/supported-devices.html
Sometimes, especially early in MCU development, only a few samples/boards are available
and may not be made available to third parties (e.g. SEGGER) to add support for a new
device. Also the existence of the device may have confidential status, so it might not be
mentioned as being supported in public releases yet. Therefore it might be desirable to be
able to add support for new devices on your own, without depending on SEGGER and a new
release of the J-Link Software an Documentation Pack being available.
The J-Link DLL allows customers to add support for new devices on their own. It is also
possible to edit / extend existing device support by for example adding new flash banks (e.g.
to add support for internal EEPROM programming or SPIFI programming). The following
article in our Wiki https://wiki.segger.com/Open_Flashloader explains how new devices can
be added to the DLL and how existing ones can be edited / extended.
If a device is not supported, you can always contact us. We will be happy to provide you
with an offer.
2.17.1
External flashes
In general our Flashers support programming of external flashes listed below:
parallel NOR flash
serial NOR flash
NAND flash
I2C/(Q)SPI EEPROM/Flash
FRAM
If the parallel NOR flash device which is used is not CFI-compliant you have to select
the flash device in J-Flash explicitly, for a list of all parallel NOR flash devices which can
be explicitly selected in J-Flash, please refer to UM08003, J-Flash User Guide, chapter
Supported Flash Devices.
Since the connection of the flash to the CPU can be different for each of the other flash
types mentioned above, a suitable Open Flashloader can be used in such a case. The J-Flash
software comes with sample projects for Open Flashloader. For a complete list of all Open
Flashloader projects for use with J-Flash software, see also: http://www.segger.com/supported-devices.html
Note
Complete Information about Open Flashloaders can be found in our Wiki:
2.17.2
Cores
2.17.2.1
Flasher ARM
Flasher ARM supports and has been tested with the following cores, but should work with
any ARM7/9, Cortex-M0/M1/M3/M4 core. If you experience problems with a particular core,
do not hesitate to contact Segger.
ARM7TDMI (Rev 1)
ARM7TDMI (Rev 3)
ARM7TDMI-S (Rev 4)
ARM920T
ARM922T
© 2004-2022 SEGGER Microcontroller GmbH
73
CHAPTER 2
ARM926EJ-S
ARM946E-S
ARM966E-S
Cortex-M0
Cortex-M1
Cortex-M3
Cortex-M4
2.17.2.2
Flasher RX
Flasher RX supports and has been tested with the following cores. If you experience problems with a particular core, do not hesitate to contact Segger.
RX610
RX621
RX62N
RX62T
2.17.2.3
Flasher PPC
Flasher PPC supports and has been tested with the following cores. If you experience problems with a particular core, do not hesitate to contact Segger.
e200z0
2.17.2.4
Flasher PRO/Compact/Portable PLUS
All of the above cores using J-Flash. Many more and constantly growing by means of Universal Flash Loader https://www.segger.com/supported-devices/flasher/.
74
CHAPTER 2
2.18
To program multiple targets in parallel there are the following possibilities:
Using a Flasher gang, or
Using multiple Flashers, each connecting to one CPU.
Devices for gang progamming are:
Flasher ATE; suitable for programming up to 10 targets in parallel. Refer Flasher ATE
user manual (UM08035_FlasherATE.pdf).
Flasher Hub in conjunction with up to 24 Flasher (Compact). Refer Flasher Hub user
manual (UM08039_FlasherHUB.pdf).
When using multiple flashers, this can be done with the J-Flash production programming software. For further information, please refer to Chapter “Command Line Interface” Sub-chapter “Programming multiple targets in parallel” of the J-Flash User Guide
(UM08003_JFlash.pdf) which is part of the Flasher Software and Documentation package.
https://www.segger.com/downloads/flasher/#FlasherSoftwareAndDocumentationPack
75
CHAPTER 2
2.19
All Flasher models keep a log file named Flasher.log which logs each programming attempt. This file contains the serial number of the device, the result of the programming
attempt, and the programming duration for quality tracking purposes. An example of a
Flasher.log file might look like the following:
SN:
SN:
SN:
SN:
SN:
SN:
1
1
2
3
4
5
Failed
Failed
O.K. (931
O.K. (931
O.K. (933
O.K. (932
ms)
ms)
ms)
ms)
If applicable, the logfile contains more detailed error messages. For example:
ERROR: Programming failed @ address 0x00000000 (1)
ERROR: Cannot connect to CPU. Target interface speed too high?
The Flasher Portable PLUS creates an additional log file named UNIERROR.LOG for Universal
Flash Loader projects. This file contains error messages that would otherwise have been
displayed by the other flashers on the terminal. For example:
Verify error config word area @
config word
config word read back
Verify error flash area @
data from file
data read back
Note
These log files can be accessed by booting the flasher into file access mode or directly
via FTP if the flasher has an appropriate network interface.
Chapter 3
TCP Services
This chapter describes the integrated TCP services.
77
CHAPTER 3
3.1
FTP Server
FTP Server
The FTP server provides easy access to the files on the internal file system. The server
supports a maximum of 2 simultaneous connections and works with all common FTP clients.
3.1.1
Access data
Anonymous access to the FTP server is limited to read-only access to the file system.
For write access, special login credentials have to be used:
Login: admin
Password: 1234
Note
The access data for read/write access can not be modified and it is intended to be
used only as a convenience feature to avoid unintended modification of the Flasher’s
file system. It is not meant as a security feature.
78
3.2
CHAPTER 3
Web server
Web server
All Flashers which come with an Ethernet interface also come with a built-in web server,
which provides a web interface for information and network configuration. For the network,
the IP address settings can be changed and a nick name can be assigned to the device.
Additionally, the web interface provides information about the status of the integrated operating system, the IP stack and the target hardware.
Chapter 4
Remote control
This chapter describes how to control Flasher via the 9-pin serial interface connector or via
the integrated Telnet interface.
80
CHAPTER 4
4.1
Overview
Overview
There are 3 ways to control Flasher operation:
Manual: Programming operation starts when pressing the button. The LEDs serve as
visible indicators.
Via Handshake lines: 3 lines on the serial interface are used:
1 line is an input and can be used to start operation,
2 lines are outputs and serve as busy and status signals.
Terminal communication via RS232.
Terminal communication via Telnet.
Note
All ways to control Flasher operation are working only if Flasher is in standalone mode.
In PC-based mode or file access mode they have no effect.
81
CHAPTER 4
4.2
Handshake control
Handshake control
Some Flasher models can be remote controlled by automated testers without the need
of a connection to a PC. Therefore Flasher is equipped with additional hardware control
functions, which are connected to the SUBD9 male connector, normally used as RS232
interface to PC.
The handshake control is available for the following Flashers:
Flasher ARM
Flasher PRO
Flasher Compact (via Flasher Hub only)
The following diagrams show the internal remote control circuitry of Flasher:
Pin No.
Function
Description
1
START
A positive pulse of any voltage between 5 and 30V
with duration of min. 30 ms starts “Auto” function
(Clear / Program / Verify) on falling edge of pulse.
The behavior of the “Auto” function depends on the
project settings, chosen in J-Flash at the Production tab.
4
BUSY
As soon as the “Auto” function is started, BUSY
becomes active, which means that transistor is
switched OFF.
5
GND
Common Signal ground.
7
OK
This output reflects result of last action. It is valid
after BUSY turned back to passive state. The output
transistor is switched ON to reflect OK state.
82
CHAPTER 4
4.3
4.3.1
Introduction
Once set up using J-Flash, the Flasher can be driven by any application or just a simple
terminal using ASCII commands.
Every known command is acknowledged by the Flasher and then executed. After command
execution, Flasher sends an ASCII reply message.
Note
There are situations where the execution of a known command is rejected with
#NACK:ERRxxx if Flasher is currently busy and the received command is not allowed
to be sent while Flasher is busy
4.3.2
4.3.3
Any ASCII command has to start with the start delimiter #.
Any ASCII command has to end with simple carriage return (’\r’, ASCII code 13).
Commands can be sent upper or lower case
General usage
Reply messages must be considered in each case. In general, a new command must not
be sent before a reply for the last one has been received.
When a flash programming function (#AUTO, #CANCEL, #ERASE, #PROGRAM, #VERIFY) has
finished, the debug logic of the MCU is disabled (power down) and the target interface of
the module is switched off (tristated).
4.3.4
Flasher is driven via a RS232 serial port with the following interface settings:
9600 baud
8 data bits
no parity
1 stop bit
The baud rate can be changed by using the #BAUDRATE command.
4.3.5
A client application can connect to Flasher via Telnet on port 23. Find below a screenshot
of Flasher which is remote controlled via Telnet:
83
CHAPTER 4
4.3.6
The table below gives an overview about the commands which are supported by the current
version of Flasher firmware. Click on the names for a detailed description:
Commands to the Flasher
#BAUDRATE
#AUTO
#AUTO PATCH
#AUTO NOINFO
#CANCEL
#ERASE
#PROGRAM
#RESULT
#SELECT
#START
#STATUS
#VERIFY
File I/O commands
#FCLOSE
#FCRC
#FDELETE
#FOPEN
#FREAD ,
#FSIZE
#FWRITE ,:
#FLIST
#MKDIR
SecureArea commands
#HASSECUREAREA
#SECUREAREA
Replies from the Flasher
#ACK
84
CHAPTER 4
ASCII command interface
#NACK
#OK
#OK::
#OK:
#STATUS:
#DONE
#ERRxxx
85
CHAPTER 4
4.3.6.1
#AUTO
The #AUTO command behaves exactly as the start button or external remote control input.
Usually, the following command sequence will be performed when receiving the #AUTO
command:
The Flasher erases the target CPU (if not blank)
The Flasher programs the target CPU
The Flasher verifies the target CPU
Depending on the settings chosen in the Production tab in J-Flash, this sequence can differ
from the one shown above.
Finally, Flasher responds with
#OK if no error occurred
#ERRxxx if any error occurred during operation. xxx represents the error code, normally
replied to Flasher PC program. The #ERRxxx message may be followed by an additional
error text.
During execution of the #AUTO command, Flasher automatically sends “status” messages
via RS232 to reflect the state of execution. Typically during execution of #AUTO command,
Flasher will reply the following sequence of messages:
#ACK
#STATUS:INITIALIZING
#STATUS:CONNECTING
#STATUS:UNLOCKING
#STATUS:ERASING
#STATUS:PROGRAMMING
#STATUS:VERIFYING
#OK (Total 13.993s, Erase 0.483s, Prog 9.183s, Verify 2.514s)
#AUTO PATCH
The #AUTO PATCH command allows patching of the content of the data to be programmed.
error text.
For further information about the usage of the #AUTO PATCH command please refer to Patch
file support on page 66.
#AUTO NOINFO
This command may be used instead of #AUTO, if no status messages from Flasher should
be sent during execution. The NOINFO extension is also available for all other commands.
The command ends with #OK or #ERRxxx
#BAUDRATE
This command can be sent in order to change the baud rate of the Flasher’s RS232 interface
used for communication. is expected in decimal format.
If this command succeeds, Flasher responds with:
#ACK
#OK
Otherwise it will respond with one of the following error messages:
#ERR255: Invalid parameters
86
CHAPTER 4
or
#ERR255: Baudrate is not supported
Note
After sending the #BAUDRATE command you will first have to wait until the Flasher
responds with the #OK message. It is recommended wait 5ms before sending the next
command with the new baudrate in order to give the Flasher the time to change the
baudrate.
#CANCEL
This command can be sent to abort a running program. It may take a while until the current
program is actually canceled.
Flasher will respond with:
#ERR007:CANCELED.
#ERASE
This command can be sent to erase all selected target flash sectors.
#ACK
#STATUS:CONNECTING
#STATUS:UNLOCKING
#STATUS:ERASING
#OK (Total 0.893s, Erase 0.483s)
#PROGRAM
This command can be used instead of #AUTO to program a target without erasing the target
before programming and without performing a final verification.
#RESULT
This command can be sent any time, even during other command execution. Flasher responds with the last result of the previously executed command.
#SELECT
The #SELECT command is used to select a specific config and data file pair which should be
used by Flasher to program the target. specifies the name of file pair without
extensions (.CFG and .DAT) on the Flasher which should be selected. If you are using the
universal flash programming mode, specifies the full name of the .UNI file
including the extension. Flasher saves the selected config and data file in the FLASHER.INI
file. So this selection is remembered even between power-cycling Flasher.
This may be verfy helpful in cases where several config and data files are stored on Flasher.
The user can easily switch between these config and data files without connecting Flasher
to a host.
#ACK
#OK
Find below a sample sequence which shows how to use the #SELECT command:
#SELECT ATSAM7_1 // ATSAM7_1.CFG and ATSAM7_1.DAT is selected
#ACK
#OK
#AUTO // Start auto programming
#ACK
87
CHAPTER 4
#STATUS:CONNECTING
#STATUS:UNLOCKING
#STATUS:ERASING
#STATUS:PROGRAMMING
#STATUS:VERIFYING
#OK (Total 8.416s, Erase 0.005s, Prog 6.845s, Verify 0.959s)
#SELECT ATSAM7_2 // ATSAM7_2.CFG and ATSAM7_2.DAT is selected
#ACK
#OK
#ACK
#STATUS:CONNECTING
#STATUS:UNLOCKING
#STATUS:ERASING
#STATUS:PROGRAMMING
#STATUS:VERIFYING
#OK (Total 8.632s, Erase 0.005s, Prog 7.051s, Verify 0.969s)
#START
This command can be sent to start the application using the method configured in the JFlash project.
Flasher will reply with the following sequence of messages:
#ACK
#STATUS:CONNECTING
#OK (Total 1.148s)
#STATUS
This command can be sent any time, even during other command execution. Flasher responds with its current state. All defined state messages are described under Replies from
Flasher on page 91.
#VERIFY
This command can used to verify the target flash content against the data stored in Flasher.
4.3.6.2
File I/O commands
The ASCII interface of the Flasher also supports file I/O operations.
The following file I/O commands are supported:
#FCLOSE
The #FCLOSE command closes the file on Flasher which was opened via #FOPEN. After this
command has been issued further file I/O operations except #FDELETE are not allowed until
the #FOPEN command is send again.
A typical sequence when using the #FCLOSE command does look like as follows:
#FCLOSE
#ACK
#OK
Note
When using the #FCLOSE command a file has to be open (previously opened by
#FOPEN). Otherwise Flasher will respond with the following if no file has been opened:
88
CHAPTER 4
#ACK
#ERR255:No file opened
#FCRC
The #FCRC command calculates a 32-bit CRC of the given file. This CRC can be used to verify
file integrity. This command should not be used while a file has been opened via #FOPEN.
The CRC will be also reported by J-Flash when downloading or saving files via J-Flash.
A typical sequence when using the #FCRC command does look like as follows:
#FCRC flasher.dat
#ACK
#OK:0x75BC855A
#FDELETE
The #FDELETE command is used to delete a file on Flasher where specifies the
name of the file.
A typical sequence when using the #FDELETE command does look like as follows:
#FDELETE flasher.dat
#ACK
#OK
Note
If deletion of the file fails for example if the file does not exist, Flasher will respond
with the following sequence:
#ACK
#ERR255:Failed to delete file
#FOPEN
The #FOPEN command is used to open a file on Flasher for further file I/O operations.
specifies the file on the Flasher which should be opened. If can
not be found on Flasher a new one will be created.
A typical sequence using the #FOPEN command does look like as follows:
#FOPEN flasher.dat
#ACK
#OK
Note
Currently only one file can be open at the same time. If #FOPEN is send and another
file is already open, Flasher will respond with:
#ACK
#ERR255:A file has already been opened
#FREAD ,
The #FREAD command is used to read data from a file on Flasher. specifies the
offset in the file, at which data reading is started. specifies the number of bytes
which should be read.
A typical sequence when using the #FREAD command does look like as follows:
#FREAD 0,4
#ACK
#OK:04:466c6173
89
CHAPTER 4
If the #FREAD command succeeds, Flasher will finally respond with a #OK:: reply message. For more information about the Flasher reply messages, please refer
to Replies from Flasher on page 91.
Note
In order to use the #FREAD command. A file has to be opened before, via the #FOPEN
command. Otherwise Flasher will respond with the following sequence:
#ACK
#FSIZE
The #FSIZE command is used to get the size of the currently opened file on Flasher.
A typical sequence when using the #FSIZE command does look like as follows:
#FSIZE
#ACK
#OK:10 // file on flasher which is currently open, has a size of 16 bytes
If the #FSIZE command succeeds, Flasher will respond with a #OK: reply message.
For more information about the Flasher reply messages, please refer to Replies from Flasher
on page 91.
Note
#ACK
#FWRITE ,:
The #FWRITE command is used to write to a file on Flasher. specifies the offset in
the file, at which data writing is started. specifies the number of bytes which
are send with this command and which are written into the file on Flasher.
is limited to 512 bytes at once. This means, if you want to write e.g. 1024 bytes, you
have to send the #FWRITE command twice, using an appropriate offset when sending it
the second time.
and are expected in hexadecimal format.
#FWRITE 0,200:
#FWRITE 200,200:
The data is expected in hexadecimal format (two hexadecimal characters per byte). The
following example illustrates the use of #FWRITE:
Data to be send: Hello !
ASCII values: 0x48, 0x65, 0x6C, 0x6C, 0x6F, 0x20, 0x21
#FWRITE 0,7:48656C6C6F2021
Note
In order to use the #FWRITE command a file has to be opened via the #FOPEN command,
first. Otherwise Flasher will respond with the following sequence:
#ACK
90
CHAPTER 4
#FLIST
The #LIST command is used to list all files stored on the Flasher.
A typical sequence using the #FLIST command does look like as follows:
#FLIST
#ACK
FLASHER.INI Size: 60
SERIAL.TXT Size: 3
FLASHER.LOG Size: 207
FOLDER (DIR)
FOLDER\TEST1.CFG Size: 2048
FOLDER\TEST1.DAT Size: 12288
#OK
#MKDIR
The #MKDIR command is used to create a directory on Flasher. specifies the
name of the new directory. may also specify a path to create a subdirectory.
A typical sequence using the #MKDIR command does look like as follows:
#MKDIR folder
#ACK
#OK
Note
If the directory can not be created because of a bad argument, Flasher
will respond with:
#ACK
#ERR255:Failed to create directory
4.3.6.3
Secure Area Commands
#HASSECUREAREA
The #HASSECUREAREA command checks if the Flasher is configured with a secure area.
#RESULT:YES indicates the secure area is present, #RESULT:NO indicates no secure area
is present.
#SECUREAREA
The #SECUREAREA command allows to create or remove the secure area on the
Flasher.
the action CREATE creates the secure area.
the action REMOVE will remove the secure area.
A typical sequence using the #SECUREAREA command does look like as follows:
#SECUREAREA CREATE
#ACK
#DONE
Note
91
CHAPTER 4
4.3.6.4
The reply messages from Flasher follow the same data format as commands. Any reply
message starts with ASCII start delimiter #, ends with simple carriage return (ASCII code
13) and is sent in uppercase. In contrast to commands, replies can be followed by a descriptive message, which gives more detailed information about the reply. This description
is sent in mixed case. The #OK reply, for example, is such a reply. It is followed by a string
containing information about the performance time needed for the operations:
The following reply messages from Flasher are defined:
#ACK
Flasher replies with #ACK message on reception of any defined command before the command itself is executed.
#NACK
Flasher replies with #NACK, if an undefined command was received.
#OK
Flasher replies with #OK, if a command other than #STATUS or #RESULT was executed and
ended with no error.
#OK::
Flasher replies with #OK:: if a #FREAD command was executed.
is the number of bytes which could be read. This value may differ from the number of
requested bytes, for example if more bytes than available, were requested.
and are send in hexadecimal format (for : two hexadecimal characters per
byte).
#OK:
Flasher replies if #OK: if a #FSIZE command has been executed. is the size
(in bytes) of the currently opened file. is send in hexadecimal format.
#STATUS:
The Flasher replies with its current state.
The following status messages are currently defined:
Message
Description
#STATUS:READY
Flasher is ready to receive a new command.
#STATUS:CONNECTING
Flasher initializes connection to target
CPU.
Flasher performs self check and internal
init.
#STATUS:UNLOCKING
Unlocking flash sectors.
#STATUS:ERASING
Flasher is erasing the flash of the target
device.
#STATUS:PROGRAMMING
Flasher is programming the flash of the
target device.
#STATUS:VERIFYING
Flasher verifies the programmed flash contents.
92
CHAPTER 4
#ERRxxx
If any command other than #STATUS or #RESULT was terminated with an error, Flasher
cancels the command and replies with an error message instead of #OK message.
Some error codes may be followed by colon and an additional error text.
For example:
#ERR007:CANCELED.
The error code numbers are described in the following table:
Message
Description
#ERR007
Flasher received #CANCEL command and
has canceled the current operation.
#ERR008
Flasher is already busy with execution of
previous command.
#ERR009
Failed to allocate memory.
#ERR010
Failed to open file.
#ERR011
Failed to read file.
#ERR012
Failed to write file.
#ERR013
Failed to delete file.
#ERR255
Undefined error occurred. This reply is followed by an error string.
Chapter 5
Performance
The following chapter lists programming performance of common flash devices andmicrocontrollers.
94
CHAPTER 5
5.1
Performance of MCUs with internal flash memory
5.1.1
Flasher ARM
The following table lists program and erase performance values of Flasher ARM for different
controllers.
Microcontroller
Size [kByte]
Erase
time [sec]
Program
time [sec]
Verify
time [sec]
Total
time [sec]
Analog Devices
62
2.943
2.286
0.563
5.792
Atmel
AT91SAM7S64
64
3.488
0.438
3.926
Atmel
AT91SAM7S256
256
7.709
1.053
8.762
NXP LPC1768
512
3.740
8.559
5.092
17.391
NXP LPC2106
120
0.448
1.204
0.634
2.286
NXP LPC2129
248
0.449
2.916
1.347
4.712
NXP LPC2138
500
0.448
5.488
2.649
8.585
NXP LPC2148
500
0.448
5.632
2.721
8.801
NXP LPC2294
2048
0.808
15.976
9.669
26.453
NXP LPC2478
504
0.448
5.419
2.559
8.426
ST STM32F103ZE
512
0.028
18.763
3.939
22.730
ST STR711
272
0.429
5.476
4.742
10.647
ST STR912
544
1.167
12.907
5.236
19.310
TI TMS470R1B1M
1024
2.289
8.147
5.362
15.798
5.1.2
Flasher PRO
See Flasher ARM.
5.1.3
Flasher Compact
See Flasher ARM.
5.1.4
Flasher RX
The following table lists program and erase performance values of Flasher RX.
Microcontroller
R5F56108
5.1.5
Size [kByte]
2.048
Erase
time [sec]
9.523
Program
time [sec]
11.915
Verify
time [sec]
3.890
Total
time [sec]
25.585
Flasher PPC
The following table lists program and erase performance values of Flasher PPC.
Microcontroller
ST SPC560B50
Size [kByte]
576
Erase
time [sec]
4.747
Program
time [sec]
4.159
Verify
time [sec]
1.929
Total
time [sec]
10.917
Chapter 6
Hardware
This chapter gives an overview about Flasher specific hardware details, such as the pinouts
and available adapters.
96
CHAPTER 6
6.1
Flasher ARM 20-pin JTAG/SWD Connector
Flasher has a JTAG connector compatible with ARM’s Multi-ICE. The JTAG connector is a
20 way Insulation Displacement Connector (IDC) keyed box header (2.54mm male) that
mates with IDC sockets mounted on a ribbon cable.
6.1.1
Pinout JTAG
The following table lists the Flasher JTAG pinout.
PIN
SIGNAL
TYPE
Description
1
VTref
Input
This is the target reference voltage. It is used to check if the
target has power, to create the logic-level reference for the
input comparators and to control the output logic levels to
the target. It is normally fed from Vdd of the target board
and must not have a series resistor.
2
Vsupply
NC
This pin is not connected to Flasher ARM. It is reserved for
compatibility with other equipment. Connect to Vdd or leave
open in target system.
3
nTRST
Output
JTAG Reset. Output from Flasher ARM to the Reset signal of
the target JTAG port. Typically connected to nTRST of the
target CPU. This pin is normally pulled HIGH on the target to
avoid unintentional resets when there is no connection.
5
TDI
Output
JTAG data input of target CPU. It is recommended that this
pin is pulled to a defined state on the target board. Typically
connected to TDI of target CPU.
7
TMS
Output
JTAG mode set input of target CPU. This pin should be pulled
up on the target. Typically connected to TMS of target CPU.
9
TCK
Output
JTAG clock signal to target CPU. It is recommended that this
pin is pulled to a defined state of the target board. Typically
connected to TCK of target CPU.
11 RTCK
Input
Return test clock signal from the target. Some targets must
synchronize the JTAG inputs to internal clocks. To assist in
meeting this requirement, you can use a returned, and retimed, TCK to dynamically control the TCK rate. Flasher ARM
supports adaptive clocking, which waits for TCK changes to
be echoed correctly before making further changes. Connect
to RTCK if available, otherwise to GND.
13 TDO
Input
JTAG data output from target CPU. Typically connected to
TDO of target CPU.
15 RESET
I/O
Target CPU reset signal. Typically connected to the RESET
pin of the target CPU, which is typically called “nRST”,
“nRESET” or “RESET”.
97
CHAPTER 6
PIN
SIGNAL
17 DBGRQ
19
5V-Target
supply
TYPE
Description
NC
This pin is not connected in Flasher ARM. It is reserved for
compatibility with other equipment to be used as a debug
request signal to the target system. Typically connected to
DBGRQ if available, otherwise left open.
Output
This pin is used to supply power to some eval boards. Typically left open on target hardware.
Pins 4, 6, 8, 10, 12, 14, 16, 18, 20 are GND pins connected to GND in Flasher ARM. They
should also be connected to GND in the target system.
6.1.2
Pinout SWD
The 20-pin connector of Flasher is also compatible to ARM’s Serial Wire Debug (SWD)
interface.
The following table lists the J-Link / J-Trace SWD pinout.
PIN
SIGNAL
TYPE
Description
1
VTref
Input
2
Vsupply
NC
This pin is not connected in J-Link. It is reserved for compatibility with other equipment. Connect to Vdd or leave open in
target system.
3
Not Used
NC
This pin is not used by J-Link. If the device may also be accessed via JTAG, this pin may be connected to nTRST, otherwise leave open.
5
Not used
NC
This pin is not used by J-Link. If the device may also be accessed via JTAG, this pin may be connected to TDI, otherwise leave open.
7
SWDIO
I/O
Single bi-directional data pin.
Output
Clock signal to target CPU.
It is recommended that this pin is pulled to a defined state
of the target board. Typically connected to TCK of target
CPU.
11 Not used
NC
This pin is not used by J-Link. This pin is not used by J-Link
when operating in SWD mode. If the device may also be accessed via JTAG, this pin may be connected to RTCK, otherwise leave open.
13 SWO
Output
Serial Wire Output trace port. (Optional, not required for
SWD communication.)
9
SWCLK
98
CHAPTER 6
PIN
SIGNAL
TYPE
Description
15 RESET
I/O
17 Not used
NC
Output
This pin is used to supply power to some eval boards. Not all
J-Links supply power on this pin, only the KS (Kickstart) versions. Typically left open on target hardware.
19
5V-Target
supply
Pins 4, 6, 8, 10, 12, 14, 16, 18, 20 are GND pins connected to GND in J-Link. They should
6.1.3
Target power supply
Pin 19 of the connector can be used to supply power to the target hardware. Supply voltage is 5V, max. current is 400mA. The output current is monitored and protected against
overload and short-circuit.
Power can be controlled via the J-Link commander. The following commands are available
to control power:
Command
Explanation
power on
Switch target power on
power off
Switch target power off
power on perm
Set target power supply default to “on”
power off perm
Set target power supply default to “off”
99
CHAPTER 6
6.2
Flasher RX 14-pin connector
Flasher RX itself has a 20-pin JTAG connector mounted but comes with a 14-pin adapter for
Renesas RX devices. This adapter also enables Flasher RX to optionally power the connected
target hardware. On the adapter there is a jumper which allows selection between 3.3V
and 5V supply target voltage supply. The target is supplied via the VTref connection when
the supply option is jumpered.
The following table lists the Flasher RX 14-pin JTAG pinout.
Pin
1
3
Signal
TCK
TRSTn
Type
Description
Output
connected to TCK on target CPU.
Output
4
EMLE
Output
Pin for the on-chip emulator enable signal. When the on-chip
emulator is used, this pin should be driven high. When not
used, it should be driven low. Pulled HIGH to VTref via 1k
pull-up resistor on 14-pin adapter.
5
TDO
Input
TDO on target CPU.
6
NC
This pin is not connected to Flasher RX.
7
NC
8
VTref
Input
9
TMS
Output
up on the target. Typically connected to TMS on target CPU.
10 —
NC
11 TDI
Output
connected to TDI on target CPU.
13 nRES
I/O
All pins marked NC are not connected to Flasher RX. Any signal can be applied here;
Flasher RX will simply ignore such a signal.
Pins 2, 12, 14 are GND pins connected to GND in Flasher RX. They should also be
100
CHAPTER 6
6.2.1
Target power supply
Pin 8 of the 14-pin connector can be used to supply power to the target hardware. Supply
voltage is 3.3V / 5V, max. current is 400mA. The output current is monitored and protected
against overload and short-circuit. Power can be controlled via the J-Link commander. The
following commands are available to control power:
Command
Explanation
power on
power off
power on perm
power off perm
101
CHAPTER 6
6.3
Flasher PPC 14-pin connector
Flasher PPC itself has a 20-pin JTAG connector mounted but comes with a 14-pin adapter
for PowerPC devices.
The following table lists the Flasher PPC 14-pin JTAG pinout.
Pin
Signal
Type
Description
1
TDI
Output
3
TDO
Input
TDO on target CPU.
5
TCK
Output
7
NC
This pin is not connected to Flasher PPC.
8
NC
9
nRES
I/O
Output
11 VDDE7
Input
13 nRDY
Input
Nexus ready output. Indicates to the development tools that
the data is ready to be read from or written to the Nexus
read/write access registers.
Output
JTAG TAP Controller Enable / JTAG Compliancy (JCOMP).
JCOMP is used to enable the TAP controller for communication to the JTAG state machine for boundary scan and for debug access. This pin is set to HIGH by Flasher PPC (in order
to enable the JTAG TAP controller on the target device).
10 TMS
14 JCOMP
All pins marked NC are not connected to Flasher PPC. Any signal can be applied here;
Flasher PPC will simply ignore such a signal.
Pins 2, 12, 6, 12 are GND pins connected to GND in Flasher PPC. They should also be
102
CHAPTER 6
6.4
Target board design
Target board design
We strongly advise following the recommendations given by the chip manufacturer. These
recommendations are normally in line with the recommendations. Please refer to the the
appropriate tables depending on the core:
Pinout JTAG on page 96
Pinout SWD on page 97
Flasher RX 14-pin connector on page 99
Flasher PPC 14-pin connector on page 101
In case of doubt you should follow the recommendations given by the semiconductor manufacturer.
6.4.1
Pull-up/pull-down resistors
Unless otherwise specified by developer’s manual, pull-ups/pull-downs are recommended
to be between 2.2 kOhms and 47 kOhms.
6.4.2
RESET, nTRST
The debug logic is reset independently from the CPU core with nTRST. For the core to
operate correctly it is essential that both signals are asserted after power-up.
The advantage of having separate connection to the two reset signals is that it allows the
developer performing software debug to setup breakpoints, which are retained by the debug
logic even when the core is reset. (For example, at the reset vector address, to allow the
code to be single-stepped as soon as it comes out of reset). This can be particularly useful
when first trying to bring up a board with a new ASIC.
103
CHAPTER 6
6.5
Adapters
Adapters
6.5.1
JTAG Isolator
The JTAG Isolator can be connected between Flasher and JTAG adapter, to provide electrical
isolation. This is essential when the development tools are not connected to the same
ground as the application. For more information about the JTAG Isolator, please refer to JLink JTAG Isolator User Manual (UM08010) which can be downloaded from our website.
6.5.1.1
Pinout
The following table shows the target-side pinout of the J-Link JTAG Isolator.
Pin
Signal
Type
Description
1
VCC
Output
The target side of the isolator draws power over this pin.
2
VCC
Output
3
nTRST
Output
JTAG Reset. Output from Flasher to the Reset signal of the
target JTAG port. Typically connected to nTRST of the target
CPU. This pin is normally pulled HIGH on the target to avoid
5
TDI
Output
7
TMS
Output
9
TCK
Output
11 RTCK
Input
13 TDO
Input
TDO of target CPU.
15 RESET
I/O
17 N/C
N/C
This pin is not connected on the target side of the isolator.
19 N/C
N/C
104
CHAPTER 6
Adapters
Pins 4, 6, 8, 10, 12, 14, 16, 18, 20 are connected to GND.
6.5.1.2
Safety
This isolator provides basic isolation only. Do not use with hazardous voltages without further protection measures to avoid risk of electrical shock and fire.
SEGGER isolators provide a basic isolation to withstand high voltages as mentioned in
the resp. technical data section. To preserve integrity of human beings when dealing with
potential hazardous voltages it is mandatory to have a second protection measure in place
in case the first insulation barrier fails. This is called double or reinforced isolation. How this
double isolation can be achieved depends on the use case or application setup. Also check
your the local safety related directives valid for your country to make sure all requirements
are met.
6.5.2
J-Link Needle Adapter
To connect to the J-Link OB via programming interface the J-Link Needle Adapter is recommended.
Why to choose the J-Link Needle Adapter:
1.
2.
3.
4.
5.
No additional connector required on your PCB
Very small footprint
High reliability spring pins for secure connections
Designed with 3 locating pins, so the adapter can not be connected the wrong way
No external power supply required! The J-Link Needle Adapter comes with the option
to power the target hardware via J-Link.
These features make the J-Link Needle Adapter the perfect solution for production purposes.
The pinout of the J-Link Needle Adapter is based on the pinout of the needle adapter by TagConnect. Please note, that both pinouts are not identical since the J-Link Needle Adapter
comes with a 5V-supply pin.
As you can see on the image below, the three locating pins ensure, that the adapter cannot
be connected to the PCB the wrong way.
Moreover, the two “legs” on each side of the connector guarantee a stable and secure
contact between pins and the PCB.
105
CHAPTER 6
Adapters
The J-Link Needle Adapter can be connected to J-Link via the 20-pin 0.1’’ JTAG to a 10pin needle connector.
106
6.6
CHAPTER 6
How to determine the hardware version
To determine the hardware version of your Flasher, the first step should be to look at the
label at the bottom side of the unit. Flasher has the hardware version printed on the back
label.
If this is not the case with your Flasher, you can use JLink.exe to determine your hardware
version (if Flasher is in PC-based mode). As part of the initial message, the hardware version
is displayed. For more information about how to ensure that Flasher is in PC-based mode,
please refer to PC-based mode on page 39.
Chapter 7
Support and FAQs
This chapter contains troubleshooting tips together with solutions for common problems
which might occur when using Flasher. There are several steps you can take before contacting support. Performing these steps can solve many problems and often eliminates the
need for assistance. This chapter also contains a collection of frequently asked questions
(FAQs) with answers.
108
CHAPTER 7
7.1
Contacting support
Contacting support
Before contacting support, make sure you tried to solve your problem by trying your Flasher
with another PC and if possible with another target system to see if it works there. If the
device functions correctly, the USB setup on the original machine or your target hardware
is the source of the problem, not Flasher.
If you need to contact support, send the following information to
support@segger.com
A detailed description of the problem
Flasher serial number
Information about your target hardware (processor, board, etc.).
FLASHER.CFG, FLASHER.DAT, FLASHER.LOG, SERIAL.TXT file from Flasher. To get these
files, Flasher has to be in file access mode. For more information about how to boot
Flasher in file access mode, please refer to file access mode on page 42.
Flasher is sold directly by SEGGER.
109
7.2
CHAPTER 7
Frequently Asked Questions
Maximum JTAG speed
Q: What is the maximum JTAG speed supported by Flasher?
A: Flasher’s maximum supported JTAG speed is 12MHz.
Maximum download speed
Q: What is the maximum download speed?
A: The maximum download speed is currently about 720 Kbytes/second when downloading
into RAM. The actual speed depends on various factors, such as JTAG, clock speed, host
CPU core etc.
Chapter 8
Background information
This chapter provides background information about flash programming in general. It also
provides information about how to replace the firmware of Flasher manually.
111
CHAPTER 8
8.1
Flash programming
Flash programming
Flasher comes with a DLL, which allows - amongst other functionalities - reading and writing
RAM, CPU registers, starting and stopping the CPU, and setting breakpoints.
8.1.1
How does flash programming via Flasher work?
This requires extra code. This extra code typically downloads a program into the RAM of
the target system, which is able to erase and program the flash. This program is called
RAM code and “knows” how to program the flash; it contains an implementation of the
flash programming algorithm for the particular flash. Different flash chips have different
programming algorithms;the programming algorithm also depends on other things, such
as endianess of the target system and organization of the flash memory (for example 1 *
8 bits, 1 * 16 bits, 2 * 16 bits or 32 bits). The RAM code requires data to be programmed
into the flash memory. The data is supplied by downloading it to RAM.
8.1.2
Data download to RAM
The data (or part of it) is downloaded to another part of the RAM of the target system. The
Instruction pointer (PC) of the CPU is then set to the start address of the Ram code, the
CPU is started, executing the RAM code. The RAM code, which contains the programming
algorithm for the flash chip, copies the data into the flash chip. The CPU is stopped after this.
This process may have to be repeated until the entire data is programmed into the flash.
8.1.3
Available options for flash programming
In general, there are two possibilities in order to use Flasher for flash programming:
8.1.3.1
Using Flasher stand-alone to program the target flash memory (stand-alone mode)
Using Flasher in combination with J-Flash to program the target flash memory (Flasher
in “PC-based mode”)
Using Flasher in stand-alone mode
In order to use the Flasher in stand-alone mode, it has to be configured first. For more
information about how to setup Flasher for using in “stand-alone mode”, please refer to
Setting up Flasher for stand-alone mode on page 43.
8.1.3.2
J-Flash - Complete flash programming solution
J-Flash is a stand-alone Windows application, which can read / write data files and program
the flash in almost any ARM system. For more information about J-Flash please refer to the
J-Flash User Guide, which can be downloaded from our website http://www.segger.com.
8.1.4
How does the universal flash programming work?
In universal flash programming mode, the flasher typically communicates with a boot loader
running on the device using a vendor specific protocol, rather than using the debug interface.
Universal flash programming is available only for stand-alone mode.
Chapter 9
Glossary
This chapter describes important terms used throughout this manual.
113
CHAPTER 9
Big-endian
Memory organization where the least significant byte of a word is at a higher address than
the most significant byte. See Little-endian.
Cache cleaning
The process of writing dirty data in a cache to main memory.
Coprocessor
An additional processor that is used for certain operations, for example, for floating-point
math calculations, signal processing, or memory management.
Dirty data
When referring to a processor data cache, data that has been written to the cache but
has not been written to main memory is referred to as dirty data. Only write-back caches
can have dirty data because a write-through cache writes data to the cache and to main
memory simultaneously. See also cache cleaning.
Halfword
A 16-bit unit of information.
Host
A computer which provides data and other services to another computer. Especially, a
computer providing debugging services to a target being debugged.
ICache
Instruction cache.
ID
Identifier.
IEEE 1149.1
The IEEE Standard which defines TAP. Commonly (but incorrectly) referred to as JTAG.
An executable file that has been loaded onto a processor for execution.
Instruction Register
When referring to a TAP controller, a register that controls the operation of the TAP.
IR
See Instruction Register.
Joint Test Action Group (JTAG)
The name of the standards group which created the IEEE 1149.1 specification.
Little-endian
Memory organization where the least significant byte of a word is at a lower address than
the most significant byte. See also Big-endian.
Memory coherency
A memory is coherent if the value read by a data read or instruction fetch is the value that
was most recently written to that location. Obtaining memory coherency is difficult when
114
CHAPTER 9
there are multiple possible physical locations that are involved, such as a system that has
main memory, a write buffer, and a cache.
Memory management unit (MMU)
Hardware that controls caches and access permissions to blocks of memory, and translates
virtual to physical addresses.
Memory Protection Unit (MPU)
Hardware that controls access permissions to blocks of memory. Unlike an MMU, a MPU
does not translate virtual addresses to physical addresses.
RESET
Abbreviation of System Reset. The electronic signal which causes the target system other
than the TAP controller to be reset. This signal is also known as “nSRST” “nSYSRST”, “nRST”,
or “nRESET” in some other manuals. See also nTRST.
nTRST
Abbreviation of TAP Reset. The electronic signal that causes the target system TAP controller
to be reset. This signal is known as nICERST in some other manuals. See also nSRST.
Open collector
A signal that may be actively driven LOW by one or more drivers, and is otherwise passively
pulled HIGH. Also known as a “wired AND” signal.
Processor Core
The part of a microprocessor that reads instructions from memory and executes them,
including the instruction fetch unit, arithmetic and logic unit, and the register bank. It
excludes optional coprocessors, caches, and the memory management unit.
Remapping
Changing the address of physical memory or devices after the application has started executing. This is typically done to make RAM replace ROM once the initialization has been
done.
RTOS
Real Time Operating System.
TAP Controller
Logic on a device which allows access to some or all of that device for test purposes. The
circuit functionality is defined in IEEE1149.1.
Target
The actual processor (real silicon or simulated) on which the application program is running.
TCK
The electronic clock signal which times data on the TAP data lines TMS, TDI, and TDO.
TDI
The electronic signal input to a TAP controller from the data source (upstream). Usually,
this is seen connecting the J-Link Interface Unit to the first TAP controller.
TDO
The electronic signal output from a TAP controller to the data sink (downstream). Usually,
this is seen connecting the last TAP controller to the J-Link Interface Unit.
115
CHAPTER 9
Test Access Port (TAP)
The port used to access a device’s TAP Controller. Comprises TCK, TMS, TDI, TDO, and
nTRST (optional).
Transistor-transistor logic (TTL)
A type of logic design in which two bipolar transistors drive the logic output to one or
zero. LSI and VLSI logic often used TTL with HIGH logic level approaching +5V and LOW
approaching 0V.
Word
A 32-bit unit of information. Contents are taken as being an unsigned integer unless otherwise stated.
Chapter 10
Literature and references
This chapter lists documents, which we think may be useful to gain a deeper under- standing
of technical details.
117
CHAPTER 10
Reference
Title
Comments
[J-Link]
J-Link / J-Trace User Guide
This document describes J-Link
and J-Trace. It is publicly available from SEGGER (www.segger.com).
[J-Flash]
J-Flash User Guide
This document describes J-Flash.
