AO3401
AO3401
    YONGYUTAI(永裕泰)
    SOT-23
    1个P沟道 耐压:20V 电流:3A
AO3401 数据手册
AO3401 P-Channel 20-V(D-S) MOSFET V(BR)DSS ID RDS(on)MAX   90 mΩ@-4.5V  -20 V SOT-23-3L -3 A 110 mΩ@-2.5V   1. GATE 2. SOURCE 3. DRAIN FEATURE z TrenchFET Power MOSFET APPLICATION Load Switch for Portable Devices z DC/DC Converter z MARKING : A19T Equivalent Circuit Maximum ratings (Ta=25℃ unless otherwise noted) Parameter Symbol Value Drain-Source Voltage VDS -20 Gate-Source Voltage VGS ±8 Continuous Drain Current ID -3 Pulsed Drain Current IDM -10 Continuous Source-Drain Diode Current IS -0.72 Maximum Power Dissipation PD 0.4 W ℃/W Thermal Resistance from Junction to Ambient(t ≤5s) R θJA 312.5 Junction Temperature TJ 150 Storage Temperature Tstg -55 ~+150 www.yongyutai.com Unit V A ℃ PAGE 1 AO3401 MOSFET ELECTRICAL CHARACTERISTICS Ta =25 ℃ unless otherwise specified Parameter Symbol Test Condition Min Typ Max Units Static Drain-source breakdown voltage V(BR)DSS VGS = 0V, ID =-250µA -20 Gate-source threshold voltage VGS(th) VDS =VGS, ID =-250µA -0.4 -1 V Gate-source leakage IGSS VDS =0V, VGS =±8V ±100 nA Zero gate voltage drain current IDSS VDS =-20V, VGS =0V -1 µA Drain-source on-state resistance a Forward transconductance RDS(on) a gfs VGS =-4.5V, ID =-2.8A 0.080 0.90 VGS =-2.5V, ID =-2.0A 0.90 0.110 VDS =-5V, ID =-2.8A 6.5 Ω S b Dynamic Input capacitance Ciss Output capacitance Coss Reverse transfer capacitance Crss Total gate charge Qg Gate-source charge Qgs Gate-drain charge Qgd Gate resistance Rg Turn-on delay time td(on) Rise time tr Turn-off delay time td(off) Fall time tf 405 VDS =-10V,VGS =0V,f =1MHz pF 75 55 VDS =-10V,VGS =-4.5V,ID =-3A VDS =-10V,VGS =-2.5V,ID =-3A 5.5 10 3.3 6 0.7 nC 1.3 f =1MHz VDD=-10V, RL=10Ω, ID =-1A, VGEN=-4.5V,Rg=1Ω 6.0 Ω 11 20 35 60 30 50 10 20 ns Drain-source body diode characteristics Continuous source-drain diode current Pulse diode forward current Body diode voltage a IS -1.3 TC=25℃ ISM VSD A -10 IS=-0.7A -0.8 -1.2 V Notes : a.Pulse Test : Pulse Width < 300µs, Duty Cycle ≤2%. b.Guaranteed by design, not subject to production testing. www.yongyutai.com PAGE 2
AO3401 价格&库存
很抱歉,暂时无法提供与“AO3401”相匹配的价格&库存,您可以联系我们找货
AO3401
  • 1+0.23210
  • 200+0.15070
  • 1500+0.13090
  • 3000+0.11550
库存:3054
AO3401
    • 20+0.22986
    • 300+0.18603
    • 1200+0.16177
    • 3000+0.14107
    库存:1784
    AO3401
    • 20+0.29614
    • 200+0.24084
    • 600+0.21006
    • 3000+0.17518
    • 9000+0.15920
    • 21000+0.15056
    库存:2936
    AO3401
    • 20+0.25076
    • 200+0.20295
    • 600+0.17648
    • 3000+0.15390
    • 9000+0.14016
    • 21000+0.13266
    库存:5890
