FE2HX225M631LGL
FE2HX225M631LGL
    PSA(信昌电陶)
    2.2UF ±20% 630V
FE2HX225M631LGL 数据手册
信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.566-1, Kaoshi Rd., Yangmei, Taoyuan 32668, Taiwan (R.O.C.) Tel : 886-3-4753355 Fax : 886-3-4854959 Messrs. : Date : 一般共用 2020/02/11 APPROVAL SHEET Product Name : Stacked Capacitors Part No. : FE Series Description : Size 1210~2225, C0G/X7R, 50~630Vdc PREPARED BY APPROVED BY 信昌電子陶瓷股份有限公司 PROSPERITY DIELECTRICS CO., LTD. 桃園市楊梅區高獅路 566-1 號 Tel : 03-4753355 ext : Contactor : http://www.pdc.com.tw Fax : 03-4854959 Mobile : DCM-003-8.1 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. No.566-1, Kaoshi Rd., Yangmei, Taoyuan 32668, Taiwan (R.O.C.) Tel : 886-3-4753355 Fax : 886-3-4854959 SPECIFICATION FOR Product Name : Stacked Capacitors Part No. : FE Series Description : Size 1210~2225, C0G/X7R, 50~630Vdc SPEC. No. : FE-000-001-09 DATE : 2020/02/11 DRAWN BY CHECEKED BY APPROVED BY Jane Hsiao Yvens Chou Joseph Ling DCM-003-8.2 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 1. INTRODUCTION FE Series green type capacitors are manufactured by using green materials without lead and cadmium. These capacitors to achieve a unique structure of high reliability. The use of metal lead frame, can absorb the heat and mechanical stress. ESR (equivalent series resistance), ESL (equivalent series inductance) is small, the most suitable for high frequency operation of the rectifier power supply. 2. FEATURES 3. APPLICATIONS a. High reliability and stability. b. Higher mechanical endurance. c. Anti thermal stress and mechanical stress. d. Improved vibration performance. e. More capacitance without changing footprint. f. RoHS & HALOGEN Compliant. a. DC to DC converter. b. High voltage coupling/DC blocking. c. Back-lighting inverters. d. Snubbers in high frequency power converters. e. Power supplies. f. Surge protection. g. Filtering, smoothing, and decoupling application. 4. HOW TO ORDER FE 2H X 106 K PDC Size Dielectric Capacitance Tolerance Family Table 1 Table 2 Table 3 Table 4 Table 5 500 L G K Rated Control Packaging Thickness Voltage Code Table 6 Table 7 Table 8 Table 9 Table 1 PDC Family Code Description Table 6 Code Description Code Description FE Stacked Capacitors Series 500 50Vdc 251 250Vdc 101 100Vdc 501 500Vdc Table 2 Stack chip quantity and chip size 201 200Vdc 631 630Vdc M Special Code Table 10 Rated Voltage Code Description The first digit : # of chips in stack Table 7 Second digit code : chip size (below) Packaging Type Code Description Code Description Code Description Code Description Code Description A 1210 (3225) G 1825 (4563) I 2225 (5763) B Bulk T Tray package C 1812 (4532) H 2220 (5750) L Tape and 13” Reel, Embossed Tape Table 3 Dielectric Material Characteristics Table 8 Thickness Description Code Description Code Description Code Description Code Description Code Description N C0G X X7R A 3.00±0.35 mm J 7.80±0.35 mm S 12.60±0.35 mm T 13.20±0.35 mm Table 4 Capacitance Rule Code B 3.60±0.35 mm K C 4.20±0.35 mm L 9.00±0.35 mm 8.40±0.35 mm D 4.80±0.35 mm M 9.60±0.35 mm V 2.10±0.25 mm E 5.40±0.35 mm N 10.20±0.35 mm W 2.50±0.25 mm Code Description Code Description F 6.00±0.35 mm P 10.80±0.35 mm R47 0.47pF 102 102=10x102=1000pF G 6.60±0.35 mm Q 11.40±0.35 mm 0R5 0.5pF 104 104=10x104=100nF H 7.20±0.35 mm R 12.00±0.35 mm 100 0 100=10x10 =10pF Table 5 106 U 1.70±0.25 mm 6 106=10x10 =10µF Tolerance Table 9 Control Code Code Description Code Description Code Description Code Description Code Description A ±0.05 pF I -10% ~ 0% Q ±0.03 pF L L type lea K K type lead B ±0.10 pF J ±5 % Z -20% ~ +80% J J type lead B B type lead C ±0.25 pF K ±10 % X +10% ~ +20% S Straight type lead F Straight type lead D ±0.50 pF L 0% ~ +10% F ±1 % M ±20 % G H ±2 % ±3 % N P -5% ~ +10% ±0.02 pF Table 10 Blank Special Code --- M Automotive Specification No. : FE-000-001-09 ~1~ DCM-003-8.3 Rev 2 信昌電子陶瓷股份有限公司 Prosperity Dielectrics Co., Ltd. 5. EXTERNAL DIMENSIONS Size Inch (mm) L (mm) W (mm) 1210 (3225) 3.50±0.40 2.50±0.40 1.70±0.15 1812 (4532) 4.80±0.40 3.20±0.40 1.70±0.15 1825 (4563) 4.80±0.40 6.30±0.50 2220 (5750) 6.00±0.50 5.00±0.50 1.70±0.15 2225 (5763) 6.00±0.50 6.30±0.50 1.70±0.15 Code / T (mm) Reference Table 8 E (mm) 1.70±0.15 Fig. 5.1 The outline of Stacked Capacitors 6. GENERAL ELECTRICAL DATA Dielectric Size Rated voltage (WVDC) C0G X7R 1210, 1812, 1825, 2220, 2225 1210, 1812, 1825, 2220, 2225 50V, 100V, 200V, 250V, 500V, 630V 50V, 100V, 200V, 250V, 500V, 630V 220nF Max. 47µF Max. Reference to Table 5 Reference to Table 5 Capacitance range Capacitance tolerance Tan δ Cap. Range Q Spec. Cap. Range D.F. Spec. Cap.1000pF, 1.0±0.2Vrms, 1KHz±10%. Cap. Range Q/D.F. Cap.≥30pF Q≥1000 Class I (C0G) Cap.10µF, 0.5±0.2Vrms, 120Hz±20%. * With no electrical load. 4. 5. 6. Temperature T.C. Operating Temp. Coefficient C0G -55~125°C at 25°C X7R -55~125°C at 25°C Rated Vol. (V) Apply Voltage Test Time Insulation ≤100 1 times of UR Max. 120 sec. Resistance 100500 500Vdc 60 sec. Rated Voltage Condition ≤100 2.5 times of UR 100
