866C
866C
    B&K
    PROGRAMMER UNIV W/USB INTERFACE
866C 数据手册
Data Sheet Device Programmers Models 844USB & 866C Model 866C Model 844USB Universal device programmers are powerful, versatile, and simple to use. Our programmers are the ideal solution for programming new chips as well as copying chips for backup or repair purposes. We offer on-going program software updates that extend device libraries and provide continuous improvements for both models 844USB and 866C programmers. Whether you are working with PLCC, SOIC, TSOP, DIP, TQFP, SSOP, PSOP or QFP packaging, we provide an extensive line of socket adapters that will work in conjunction with our programmers. Specifications 844USB Devices Supported EPROM, EEPROM/Flash, Serial EPROM, Microcontroller, PLD and BPROM (BPROMs 866C) Device libraries ■ Extensive device libraries ■ Fast and high performance ■ Powerful program software ■ Supports Windows® XP/Vista/7 866C Over 29,000 Interface Common Features & Benefits Over 70,000 USB 2.0 / USB 1.1 Compatible DIL40 pin ZIF Socket, ISP for in-circuit programming Programming Socket DIL48 pin ZIF Socket, ISP for in-circuit programming "Erase, Random Data Fill, Fill Block, Copy Block, Move Block, Swap Block, Buffer Print, Find Text, Replace Text, GoTo Address, Checksum Calculator, 8 bit & 16 bit View Modes" Buffer Features I.C. Tester No Power Requirements Yes 100-240 VAC, 47-63 Hz Weight 1.1 lbs (500 g) 1.98 lbs (0.9 kg) Dimensions (W x H x D) 3.8” x 1.4” x 6.3” (95 x 35 x 160 mm) 5.5” x 2.2” x 7.7” (140 x 56 x 195 mm) One-Year Warranty Windows is a registered trademark of Microsoft Corporation in the United States and other countries. ® Technical data subject to change © B&K Precision Corp. 2013 v060313 www.bkprecision.com Programmer software
很抱歉,暂时无法提供与“866C”相匹配的价格&库存,您可以联系我们找货
