BZG03C Series
Zener Diodes
VZ :
10 -- 270 V
POWER DISSIPATION: 3.0 W
Features
SMA/DO-214AC
High reliability
Voltage range 10 V to 270 V
0. 181(4. 60)
0. 161( 4. 10)
Fits onto 5 mm SMD footpads
Wave and reflow solderable
0. 108( 2.75)
0. 096(2. 45)
0. 063(1.60)
0. 051(1.30)
Glass passivated junction
0. 209( 5. 30)
0. 193( 4.90)
Mechanical Data
0. 012(0.30)
0. 006(0.15)
Case:JEDEC DO-214AC(SMA)
0.096(2.45)
0.078(2.00)
Polarity: Color band denotes cathods end
0. 059(1. 50)
0. 035( 0. 90)
Weight: 0.002 ounces, 0.064 grams
Mounting position: any
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
Maximum Ratings and Thermal Characteristics
(TA=25℃ unless otherwise noted)
Symbol
Value
Unit
Power dissipation at Ttp=100℃
Ptot
3.0
W
Forward voltage @IF=500mA
VF
1.2
V
Maximum thermal resistance
junction to ambient
RθJA
150
K/W
Peak reverse power dissipation(non-repetitive)
tp=100µs square wave
PZSM
600
W
TJ
-65 to +150
TSTG
-65 to +150
Parameter
Junction temperature
Storage temperature range
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
BZG03C Series
Zener Diodes
ELECTRICAL CHARACTERISTICS (TA=25℃)
Type
Device
marking
code
Zener voltage
range
VZ
Dynamic resistance
rzj@IZT
IZT
V
V
V
Ω
Ω
Min.
Typ.
Max.
Typ.
Max.
mA
Temperature
coefficient
of zener voltage
TKVZ@IZT
Reverse leakage
current
I R@VR
%/K
%/K
µ A
Typ.
Max.
Max.
V
BZG03C10
G10
9.4
10
10.6
2.0
4.0
50
0.05
0.09
10
7.5
BZG03C11
G11
10.4
11
11.6
4.0
7.0
50
0.05
0.10
4.0
8.2
BZG03C12
G12
11.4
12
12.7
4.0
7.0
50
0.05
0.10
3.0
9.1
BZG03C13
G13
12.4
13
14.1
5.0
10
50
0.05
0.10
2.0
10
BZG03C15
G15
13.8
15
15.6
5.0
10
50
0.05
0.10
1.0
11
BZG03C16
G16
15.3
16
17.1
6.0
15
25
0.06
0.11
1.0
12
BZG03C18
G18
16.8
18
19.1
6.0
15
25
0.06
0.11
1.0
13
BZG03C20
G20
18.8
6.0
15
25
0.06
0.11
1.0
15
BZG03C22
G22
20.8
22
23.3
6.0
15
25
0.06
0.11
1.0
16
BZG03C24
G24
22.8
24
25.6
7.0
15
25
0.06
0.11
1.0
18
BZG03C27
G27
25.1
27
28.9
7.0
15
25
0.06
0.11
1.0
BZG03C30
G30
28
30
32
8.0
15
25
0.06
0.11
1.0
22
BZG03C33
G33
31
33
35
8.0
15
25
0.06
0.11
1.0
24
BZG03C36
G36
34
36
38
21
40
10
0.06
0.11
1.0
27
BZG03C39
G39
37
39
41
21
40
10
0.06
0.11
1.0
30
BZG03C43
G43
40
43
46
24
45
10
0.07
0.12
1.0
33
BZG03C47
G47
44
47
50
24
45
10
0.07
0.12
1.0
36
BZG03C51
G51
48
51
54
25
60
10
0.07
0.12
1.0
39
BZG03C56
G56
52
56
60
25
60
10
0.07
0.12
1.0
43
BZG03C62
G62
58
62
66
25
80
10
0.08
0.13
1.0
47
BZG03C68
G68
64
68
72
25
80
10
0.08
0.13
1.0
51
BZG03C75
G75
70
75
79
30
100
10
0.08
0.13
1.0
56
BZG03C82
G82
77
82
87
30
100
10
0.08
0.13
1.0
62
BZG03C91
G91
85
91
96
60
200
5
0.09
0.13
1.0
68
BZG03C100
G100
94
100
106
60
200
5
0.09
0.13
1.0
75
BZG03C110
G110
104
110
116
80
250
5
0.09
0.13
1.0
82
BZG03C120
G120
114
120
127
80
250
5
0.09
0.13
1.0
91
BZG03C130
G130
124
130
141
110
300
5
0.09
0.13
1.0
100
BZG03C150
G150
138
150
156
130
300
5
0.09
0.13
1.0
110
BZG03C160
G160
153
160
171
150
350
5
0.09
0.13
1.0
120
BZG03C180
G180
168
180
191
180
400
5
0.09
0.13
1.0
130
BZG03C200
G200
188
200
212
200
500
5
0.09
0.13
1.0
150
BZG03C220
G220
208
220
233
350
750
2
0.09
0.13
1.0
160
BZG03C240
G240
228
240
256
400
850
2
0.09
0.13
1.0
180
BZG03C270
G270
251
270
289
450
1000
2
0.09
0.13
1.0
200
ht t p : //
www.lgesemi .c o m
BZG03C Series
Zener Diodes
Ratings AND Charactieristic Curves
FIG.2 -- NON REPETITIVE SURGE POWER
DISSIPATION VS.PULSE LENGTH
10000
2.5
2.0
1.5
1.0
0.5
POWER DISSIPATION
NON-REPETITIVE SURGE
3.0
AMPERES
INSTANTANEOUS FORWARD CURRENT
FIG.1 --TYPICAL FORWARD CHARACTERISTIC
1000
10
0.01
1.0
2.0
1.5
0.1
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
1
10
100
PULSE LENGTH(ms)
THERMAL RESISTANCE FOR PULSE COND.(K/W)
FIG.3 -- THERMAL RESPONSE
1000
100
tp/T=0.5
tp/T=0.2
10
tp/T=0.1
tp/T=0.05
tp/T=0.02
1
10–5
tp/T=0.01
10–4
10–3
10–2
10–1
100
101
102
PULSE LENGTH(S)
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMA
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“BZG03C62”相匹配的价格&库存,您可以联系我们找货
