410-242
410-242
    DIGILENT(迪芝伦)
    CHIPKITPGMPROGR/DEBUGGER
410-242 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com chipKIT™ PGM Programmer/Debugger Reference Manual Revised March 3, 2015 This manual applies to the chipKIT PGM rev. A Overview The chipKIT PGM is a simple, low cost, module that supports in-system programming and debugging of applications written for Microchip® PIC-based microcontroller boards such as the chipKIT and Cerebot™ boards. The chipKIT PGM is designed to work with the MPLAB® and MPLAB X development environments available from Microchip. This allows the chipKIT boards, for example, to be used as a more traditional microcontroller development platform using the professional tools available from Microchip. The chipKIT PGM can also be used from within the MPLAB or MPLAB-X development environments to enable insystem debugging of sketches developed using the Arduino® compatible MPIDE development environment. DOC#: 502-242 Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 4 chipKIT™ PGM Programmer/Debugger Reference Manual chipKIT PGM Hardware Overview The chipKIT PGM has the following features: 1. USB Connector This is a standard mini USB connector. Use the provided cable to connect the chipKIT PGM to an available USB port on the PC workstation. 2. Programming Connector Connect the chipKIT PGM to the target board using this connector. The white triangle marker indicates the Pin 1 end of the connector. 3. Status LED This LED indicates that the chipKIT PGM has connected to the target device and is ready for use. 4. Activity LED This LED is an activity indicator. It blinks when the programmer/debugger software is communicating with the target device. 5. Power LED This LED illuminates when the chipKIT PGM is receiving power via the USB port from the host PC. Using the chipKIT PGM The chipKIT PGM uses a programmer/debugger circuit licensed from Microchip. Use of the chipKIT PGM requires a supported version of either the MPLAB IDE or the MPLAB X IDE from Microchip. The licensed debugger is supported in version 8.63 or later of the MPLAB IDE and all versions of the MPLAB X IDE. The MPLAB or MPLAB X IDE can be downloaded from the Microchip web site at: www.microchip.com/mplab. These software suites include a free evaluation copy of the Microchip C32 compiler for use with the PIC32 microcontroller family. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 4 chipKIT™ PGM Programmer/Debugger Reference Manual The appropriate version of the IDE should be downloaded from the Microchip website and installed. This will install the necessary software and drivers to enable use of the chipKIT PGM. Once the desired version of MPLAB has been installed, connect the supplied USB cable to the mini-USB connector on the chipKIT PGM and to an available USB port on the PC. Connect the chipKIT PGM to the ICSP port on the target board and start the MPLAB IDE. The chipKIT PGM behaves similarly to the Microchip PICkit™ 3 Programmer/Debugger and can be used in a similar way. In the MPLAB IDE, select Licensed Debugger from either the Programmer.Select Programmer menu or the Debugger.Select Tool menu. The IDE will connect to the device and identify that it is a 'chipKIT Programmer by Digilent'. When the licensed debugger is selected, the MPLAB IDE will check the version number of the firmware running on the debugger and offer to update it if is out of date with the version of MPLAB being used. At this point, the chipKIT PGM is ready for use. Debugging MPIDE Sketches Using the chipKIT PGM For detailed information on how to use the chipKIT PGM and the MPLAB IDE to debug MPIDE sketches, please refer to the document “Debugging chipKIT with MPLAB IDE” available on the chipKIT wiki: www.chipKIT.org/wiki. This document is in the Application Notes section at the bottom of the Documenation page on the wiki. CHIPKIT and the CHIPKIT Logo are trademarks or registered trademarks of Microchip Technology Incorporated in the U.S. and other countries, and are used under license. Manufactured by Digilent under license from MICROCHIP. PICkit™ On-Board Programmer/Debugger, © 2011 Microchip Technology Inc. All rights reserved. MICROCHIP SOFTWARE OR FIRMWARE IS PROVIDED “AS IS,” WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR ANY PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL MICROCHIP BE LIABLE FOR ANY CLAIN, DAMAGES OR OTHER LIABILITY ARISING OUT OF OR IN CONNECTION WITH THE SOFTWARE OR FIRMWARE OR THE USE OF OTHER DEALINGS IN THE SOFTWARE OR FIRMWARE. THIS PRODUCT IS DISTRIBUTED UNDER LICENSE FROM MICROCHIP TECHNOLOGY INC. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 4 chipKIT™ PGM Programmer/Debugger Reference Manual Declaration of Conformity In accordance with EN ISO/IEC 17050-1:2010 Manufacturers Name: Manufacturers Address: Application of Council Directives: EMC Standards: EMC Digilent, Inc. 1300 NE Henley Court Pullman, WA 99163 U.S.A. 2004/108/EC EN55022:2010 EN55024:2010 Product Name: Product Model Number: Digilent Product Category: chipKIT PGM Digilent P/N 210-242 Programming Solutions We, the undersigned, hereby declare that the equipment specified above conforms to the above Directives and Standards. Location: _Pullman, WA______ Signature: Clint Cole__________ Date: _August 23, 2012 ___ Full Name (print): Clint Cole _________ Title: Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. President___________ Page 4 of 4
410-242 价格&库存
很抱歉,暂时无法提供与“410-242”相匹配的价格&库存,您可以联系我们找货
