Page 1 of 2
Bus Pirate v4
SKU: 102990041
Description
Bus Pirate v4 (http://dangerousprototypes.com/docs/Bus_Pirate) is a universal bus interface that talks to
electronics from a computer serial terminal. Get to know a chip without writing code. Eliminates a ton of
early prototyping effort with new or unknown chips. Seeed Studio is the official manufacturer and
supporter of the Bus Pirate project. Version 4 is the next generation Bus Pirate hardware, but it's not as
stable as Bus Pirate v3 (http://www.seeedstudio.com/depot/bus-pirate-v3-assembled-p-609.html?
cPath=174). If you're just starting out with the Bus Pirate we still recommend v3 - it's cheaper, more
reliable, and has all the same major features. See a Bus Pirate v4 vs v3 comparison
(http://dangerousprototypes.com/docs/Bus_Pirate_v4_vs_v3_comparison). Protocols 1-Wire, I2C, SPI,
JTAG, asynchronous serial (UART), MIDI, PC keyboard, HD44780 LCDs, and generic 2- and 3-wire libraries
for custom protocols.
Features
USB interface, USB powered
5volt tolerant pins
0-6volt measurement probe
1Hz-40MHz frequency measurement
1kHz-4MHz pulse-width modulator, frequency generator
On-board multi-voltage pull-up resistors
On-board 3.3volt and 5volt power supplies with software reset
Macros for common operations
Bus traffic sniffers (SPI, I2C)
Transparent USB->serial bridge mode
10Hz-1MHz low-speed logic analyzer
Custom support in AVRDUDE (http://savannah.nongnu.org/projects/avrdude) , Flashrom
(http://www.flashrom.org/Flashrom) , OpenOCD (http://openocd.berlios.de/web/)
AVR STK500 v2 programmer clone
Scriptable from Perl, Python, etc.
A bootloader for easy USB firmware updates
Open source (CC 0/public domain)
New in Bus Pirate v4
256K program space, 4 times more flash than v3
Integrated, on-board USB (faster)
Data storage EEPROM to store settings
Software pull-up voltage selection: 3.3volt, 5volt, or external supply
2 extra I/O pins
Multipurpose button
Page 2 of 2
• Bus Pirate v4 vs v3 comparison
Support
• Bus Pirate manual (http://dangerousprototypes.com/docs/Bus_Pirate%20v3.5)
• Bus Pirate v4 hardware overview
(http://dangerousprototypes.com/docs/Bus_Pirate_v4_design_overview)
• Chip demonstrations (http://dangerousprototypes.com/docs/Bus_Pirate#Chip_demonstrations)
• Latest firmware (http://code.google.com/p/the-bus-pirate/)
• Bus Pirate forum (http://dangerousprototypes.com/forum/viewforum.php?f=4)
Firmware Upgrade Notification:
If you are unsatisfied with the current firmware version, please check with the newly upgrade firmware
v6.1 :http://dangerousprototypes.com/docs/Bus_Pirate_v4_firmware_updates
(http://dangerousprototypes.com/docs/Bus_Pirate_v4_firmware_updates)
First batch warning
Each Bus Pirate v4 is tested before it leaves the factory, but please keep in mind that v4 is still
experimental, unproven hardware. If in doubt please buy the cheaper Bus Pirate v3
(http://www.seeedstudio.com/depot/bus-pirate-v3-assembled-p-609.html?cPath=174), it is still
manufactured and actively supported. This hardware is distributed in the hope that it will be useful, but
WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
If you encounter any problems when using this product, here is the forum
(http://dangerousprototypes.com/forum/index.php) from which you can get the technical support.
http://www.seeedstudio.com/depot/Bus-Pirate-v4-p-740.html?cPath=98_16
1/11/2016
很抱歉,暂时无法提供与“102990041”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+330.538551+42.96005
