CFM-8020CF-235-346-20
    CUIDEVICES
CFM-8020CF-235-346-20 数据手册
Additional Resources: Product Page | 3D Model date 08/12/2022 page 1 of 8 SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN FEATURES • omniCOOL™ bearing system • 80 x 80 mm frame • multiple speed options • PWM/tachometer wires available MODEL input voltage input current1 input power1 rated speed1 airflow2 static pressure3 noise4 (CFM) (inch H2O) typ (dBA) rated (Vdc) range (Vdc) max (A) max (W) typ (RPM±10%) CFM-8015CF-120-213 12 10.8~13.2 0.09 1.08 2,0005 23.23 0.04 21.3 CFM-8015CF-130-301 12 10.8~13.2 0.26 3.12 3,0005 34.85 0.10 30.1 CFM-8015CF-140-363 12 10.8~13.2 0.51 6.12 3,800 43.49 0.16 35.2 CFM-8015CF-220-213 24 21.6~26.4 0.06 1.44 2,0005 23.23 0.04 21.3 CFM-8015CF-230-301 24 21.6~26.4 0.21 5.04 3,000 34.85 0.10 30.1 CFM-8015CF-240-363 24 21.6~26.4 0.21 5.04 3,800 43.49 0.16 35.2 CFM-8020CF-125-273 12 10.8~13.2 0.08 0.96 2,5005 24.52 0.07 27.4 CFM-8020CF-135-346 12 10.8~13.2 0.15 1.80 3,500 34.33 0.14 34.7 CFM-8020CF-145-401 12 10.8~13.2 0.30 3.60 4,500 44.14 0.24 40.2 CFM-8020CF-225-273 24 21.6~26.4 0.05 1.20 2,5005 24.52 0.07 27.4 CFM-8020CF-235-346 24 21.6~26.4 0.09 2.16 3,500 34.33 0.14 34.0 CFM-8020CF-245-401 24 21.6~26.4 0.18 4.32 4,500 44.14 0.24 40.2 Notes: 1. At rated voltage, after 3 minutes. 2. At rated voltage, room temperature, 65% humidity, 0 inch H20 static pressure. 3. At rated voltage, 0 CFM airflow. 4. Measured in an anechoic chamber as per ISO3745/GB4214-84 at rated voltage, with background noise 20±2 dBA at 1 m from the fan intake. 5. Typical rated speed is measured as RPM±350 at rated voltage. 6. All specifications are measured at 25°C, 65% relative humidity unless otherwise specified. PART NUMBER KEY CFM-8015CF-120-213- XX - CXX Base Number Fan Signals “blank” = no signals 20 = tachometer signal 22 = tachometer signal / PWM control signal cuidevices.com Reserved for Custom Configurations Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 2 of 8 INPUT parameter conditions/description min typ max units operating input voltage7 12 Vdc input models 24 Vdc input models 10.8 21.6 12 24 13.2 26.4 Vdc Vdc starting voltage 12 Vdc input models 24 Vdc input models (CFM-8020CF-225-273 & CFM8020CF-235-346: 12 Vdc) Note: 7 14 Vdc Vdc 7. See Model section on page 1 for specific input voltage ranges. PERFORMANCE8 parameter conditions/description max units rated speed at rated voltage, 25°C, after 3 minutes 2,000 4,500 RPM air flow at 0 inch H2O, see performance curves 23.23 44.14 CFM static pressure at 0 CFM, see performance curves 0.04 0.24 inch H2O noise at 1 m, rated speed 21.3 40.2 dBA Note: min typ 8. See Model section on page 1 for specific values. PROTECTIONS / FEATURES9 parameter conditions/description auto restart on all models polarity protection on all models tachometer signal available on “20” and “22” models PWM control signal available on “22” models Notes: min typ max units min typ max units 9. See Application Notes for details. SAFETY & COMPLIANCE parameter conditions/description insulation resistance at 500 Vdc between frame and positive terminal dielectric strength at 500 Vac, 60 Hz, 1 minute between housing and positive terminal safety approvals UL/cUL 507, TUV (EN/IEC 62368-1:2020+A11) EMI/EMC EN 55032:2015, EN 55035:2017 life expectancy at 40°C, 65% RH, 90% confidence level RoHS yes 10 MΩ 5 40,000 mA hours ENVIRONMENTAL parameter conditions/description min typ max units operating temperature -10 70 °C storage temperature -40 75 °C operating humidity non-condensing 35 85 % storage humidity non-condensing 35 85 % cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 3 of 8 PERFORMANCE CURVES CFM-8015CF-130-301 Static Pressure (mm H O) 2 Static Pressure (mm H O) 2 CFM-8015CF-120-213 Air Flow (CFM) Air Flow (CFM) Air Flow (CFM) Static Pressure (mm H O) 2 CFM-8015CF-220-213 Static Pressure (mm H O) 2 CFM-8015CF-140-363 Air Flow (CFM) CFM-8015CF-240-363 Static Pressure (mm H O) 2 Static Pressure (mm H O) 2 CFM-8015CF-230-301 Air Flow (CFM) Air Flow (CFM) cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 4 of 8 PERFORMANCE CURVES (CONTINUED) CFM-8020CF-135-346 Static Pressure (mm H O) 2 Static Pressure (mm H O) 2 CFM-8020CF-125-273 Air Flow (CFM) Air Flow (CFM) CFM-8020CF-225-273 Static Pressure (mm H O) 2 Static Pressure (mm H O) 2 CFM-8020CF-145-401 Air Flow (CFM) CFM-8020CF-245-401 Static Pressure (mm H O) 2 Static Pressure (mm H O) 2 CFM-8020CF-235-346 Air Flow (CFM) Air Flow (CFM) Air Flow (CFM) cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 5 of 8 MECHANICAL parameter conditions/description motor 4 pole DC brushless min bearing system omniCOOL™ bearing system direction of rotation counter-clockwise viewed from front of fan blade dimensions CFM-8015CF models: 80 x 80 x 15.4 CFM-8020CF models: 80 x 80 x 20.0 material PBT (UL94V-0) weight CFM-8015CF models: weight varies by model CFM-8020CF models: weight varies by model typ max units mm mm 50.5 55.1 55.1 61.0 g g MECHANICAL DRAWING units: mm 2 wire versions (+Vin & -Vin): UL 1007, 26 AWG 3 wire versions (+Vin, -Vin, & tach): UL 1007, 26 AWG 4 wire versions (+Vin, -Vin, tach, & PWM): UL 1007, 26 AWG MOUNTING SCREW (Pan Head) CFM-8015CF WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin Yellow10 Tach Signal Blue10 PWM Notes: 10. Wires only present on versions with output signals. cuidevices.com Screw Type Size Standard Torque Machine Screw M4 JIS B1111-1974 7.5 kgf-cm Self-tapping Screw M5 JIS B1122 Type 2 7.5 kgf-cm Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 6 of 8 MECHANICAL DRAWING (CONTINUED) units: mm MOUNTING SCREW (Pan Head) 2 wire versions (+Vin & -Vin): UL 1007, 24 AWG 3 wire versions (+Vin, -Vin, & tach): UL 1007, 24 AWG 4 wire versions (+Vin, -Vin, tach, & PWM): UL 1007, 28 AWG Screw Type CFM-8020CF WIRE CONNECTIONS Wire Color Function Red +Vin Black -Vin Yellow10 Tach Signal Blue10 PWM Notes: 10. Wires only present on versions with output signals. cuidevices.com Size Standard Torque Machine Screw M4 JIS B1111-1974 4.5 kgf-cm Self-tapping Screw M4.8 JIS B1122 Type 2 5.5 kgf-cm Additional Resources: Product Page CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN | 3D Model date 08/12/2022 | page 7 of 8 APPLICATION NOTES Auto Restart Protection When the fan motor is locked by an external force, the device will temporarily turn off electrical power to the motor and restart automatically when the locked rotor condition is released. Polarity Protection Able to withstand 10 minutes of reverse polarity connection between the positive and negative wires without causing damage. Tachometer Signal (Yellow Wire) The tachometer signal is for detecting the rotational speed of the fan motor. The output will be a square wave when fan is operating and VFG or VCE depending on the locked rotor position when fan motor is locked (See Figures 1~2 below). Figure 1: Tachometer Output Circuit Output Type: Open Collector Vs: (VFG) 5 V fan: 3.3~5 V All others: 3.3~15 V Ic≤5 mA R≥Vs/Ic VCE(sat)≤0.5 V Figure 2: Tachometer Output Waveform 4 Pole Motor N=RPM T=60/N (sec) FG=1/T*2 (Hz) N=FG*30 PWM Signal (Blue Wire) This wire is for speed control of the fan motor using a PWM input signal from the customer circuit (See Figure 3 below). Figure 3: PWM Input Signal cuidevices.com Additional Resources: Product Page | 3D Model CUI DEVICES | SERIES: CFM-80CF | DESCRIPTION: DC AXIAL FAN date 08/12/2022 | page 8 of 8 REVISION HISTORY rev. description date 1.0 initial release 10/15/2021 1.01 added PWM signal versions 05/19/2022 logo, datasheet style update 08/12/2022 1.02 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
CFM-8020CF-235-346-20 价格&库存
很抱歉,暂时无法提供与“CFM-8020CF-235-346-20”相匹配的价格&库存,您可以联系我们找货
