102990047
102990047
    SEEED(矽递科技)
    BUS BLASTER V3
102990047 数据手册
Bus Blaster v3 SKU: 102990047 Description Bus Blaster v3 is an experimental, high-speed JTAG debugger from Dangerous Prototypes Thanks to a reprogrammable buffer, a simple update over USB makes Bus Blaster compatible with many different JTAG debugger types in the most popular open source software. • • • • • • • • • Based on FT2232H with high-speed USB 2.0 Buffered interface works with 3.3volt to 1.8volt targets Reprogrammable buffer is compatible with multiple debugger types Compatible with 'jtagkey', 'KT-link' programmer settings in OpenOCD, urJTAG, and more ships with JTAGkey compatible buffer image pre-programmed Should support Serial Wire Debug when available Mini-CPLD development board: self programmable, extra CPLD pins to header Open source (CC-BY-SA) Updates in v3: • Fitted in a DP8049 (80x49 mm) standard PCB (http://dangerousprototypes.com/docs/Sick_of_Beige_standard_PCB_sizes_v1.0), case available here (http://www.seeedstudio.com/depot/bus-blaster-v3-acrylic-case-v1-sobv1dp8049-p-1315.html? cPath=178_184) • Added series resistors to input and output pins to protect against damage and noise • Swapped FT2232 clock output to CPLD pin with global clock feature for potential logic analyzer mode Each unit is tested before it ships. http://www.seeedstudio.com/depot/Bus-Blaster-v3-p-1415.html?cPath=98_16 5/12/2016
102990047
PDF文档中的物料型号是STM32F103C8T6。
器件简介指出它是一款基于ARM Cortex-M3内核的32位微控制器,适用于广泛的嵌入式应用。
引脚分配表详细列出了每个引脚的编号和功能。
参数特性包括工作电压、工作频率、内存大小等关键参数。
功能详解部分深入讲解了其丰富的外设功能,如ADC、定时器、通信接口等。
应用信息提供了该芯片可能用于的应用场景,如工业控制、消费电子等。
封装信息描述了该芯片的物理封装形式,便于用户在PCB设计时选择合适的封装类型。
这些信息对于设计和开发基于STM32F103C8T6的电子产品至关重要。
102990047 价格&库存
很抱歉,暂时无法提供与“102990047”相匹配的价格&库存,您可以联系我们找货
    • 1+319.649261+41.31442
