Technical Data ELX1035
Effective April 2021
SDCH1V80
Semi-shielded power inductors
Applications
Product features
High current carrying capacity
High power density, low core losses
Magnetically semi-shielded
8.3 mm x 8.3 mm surface mount package in 4.2
mm height
NiZn ferrite magnetic material
Moisture sensitivity level (MSL): 1
DC-DC converters
Switching controllers
Industrial IoT equipment
Game consoles
Portable electronics
Laptops, notebooks, and netbooks
Desktops and workstations
Battery backup
LED lighting
HD televisions and displays
Environmental compliance and general
specifications
Storage temperature range (component):
-40 °C to +125 °C
Operating temperature range: -40 °C to +125 °C
(ambient plus self-temperature rise)
Solder reflow temperature:
J-STD-020 (latest revision) compliant
HALOGEN
Pb HF
FREE
SDCH1V80
Product specifications
Part number5
OCL1
(µH)
FLL2
(µH) minimum
Irms3
(A)
Isat4
(A)
DCR (mΩ)
@ +20 °C
nominal
DCR (mΩ)
@ +20 °C
maximum
SDCH1V8040-1R0N-R
1.0±30%
0.46
8.0
12.0
6.5
9
SDCH1V8040-1R5N-R
1.5±30%
0.68
7.3
9.6
7.5
11
SDCH1V8040-2R2M-R
2.2±20%
1.14
6.9
9.3
10
13
SDCH1V8040-3R3M-R
3.3±20%
1.72
5.0
8.6
15
19
SDCH1V8040-4R7M-R
4.7±20%
2.44
4.7
6.3
18
21
SDCH1V8040-6R8M-R
6.8±20%
3.54
3.8
5.1
26
30
SDCH1V8040-100M-R
10±20%
5.2
3.0
4.6
40
46
SDCH1V8040-150M-R
15±20%
7.8
2.8
3.2
50
58
SDCH1V8040-220M-R
22±20%
11.44
2.5
2.8
70
81
SDCH1V8040-330M-R
33±20%
17.16
1.9
2.2
110
127
SDCH1V8040-470M-R
47±20%
24.44
1.8
2.0
140
161
SDCH1V8040-680M-R
68±20%
35.36
1.3
1.6
215
247
SDCH1V8040-101M-R
100±20%
52.0
1.1
1.22
300
345
SDCH1V8040-221M-R
220±20%
114.4
0.75
0.9
680
782
SDCH1V8040-331M-R
330±20%
171.6
0.6
0.7
1000
1150
SDCH1V8040-471M-R
470±20%
244.4
0.5
0.65
1500
1725
SDCH1V8040-681M-R
680±20%
353.6
0.42
0.53
2200
2530
SDCH1V8040-821M-R
820±20%
426.4
0.4
0.45
2500
2875
SDCH1V8040-102M-R
1000±20%
520.0
0.37
0.42
2900
3335
1. Open circuit inductance (OCL) test parameters: 100 kHz, 0.25 Vrms, 0.0 Adc, +25 °C
2. Full load inductance (FLL) test parameters: 100 kHz, 0.25 Vrms, Isat, +25 °C
3. Irms: DC current for an approximate temperature rise of 40 °C without core loss. Derating is necessary for AC currents.
PCB layout, trace thickness and width, air-flow, and proximity of other heat generating components will affect the
temperature rise. It is recommended that the temperature of the part not exceed +125 °C under worst case operating
conditions verified in the end application.
2
www.eaton.com/electronics
4. Isat : Peak current for approximately 35% maximum rolloff @ +25 °C
5. Part number definition: SDCH1Vxxxx-yyyz-R
SDCH1V = Product code
xxxx= size code
yyy= Inductance value in μH, R=decimal point
z= Inductance tolerance
-R suffix = RoHS compliant
SDCH1V80
Dimensions-mm
SDCH1V8040
Dimension
Value
A
8.0 ± 0.3
B
8.0 ± 0.3
C
4.2 MAX
D
6.3 ± 0.2
E
2.45 ± 0.3
F
3.1 ± 0.3
a
2.8 TYP
b
8.3 TYP
c
6.6 TYP
Part marking: xxx= inductance value in µH, R= decimal point. If no R is present then last character equals number of zeros.
Tolerances are ±0.3 millimeters unless stated otherwise
All soldering surfaces to be coplanar within 0.1 millimeters
Pad layout tolerances are ±0.1 millimeters unless stated otherwise
Traces or vias underneath the inductor is not recommended
3
SDCH1V80
Packaging information- mm
SDCH1V8040
Supplied in tape and reel packaging, 1000 parts per 13” diameter reel (EIA-481 compliant)
Drawing not to scale
4
Dimension
Value
W
16.00 + 0.20/-0.30
F
7.50 ± 0.10
E1
1.75 ± 0.10
E2
N/A
P0
4.00 ± 0.10
P1
12.00 ± 0.10
P2
2.00 ± 0.10
ØD0
1.55 ± 0.05
ØD1
1.55 ± 0.05
A0
8.55 ± 0.10
B0
8.55 ± 0.10
K0
4.40 ± 0.10
T
0.40 ± 0.05
SDCH1V80
Inductance and temperature rise vs current
5
6
SDCH1V80
SDCH1V80
7
SDCH1V80
Solder reflow profile
TP
TC -5°C
tP
Max. Ramp Up Rate = 3°C/s
Max. Ramp Down Rate = 6°C/s
Temperature
TL
Preheat
A
T smax
t
Table 1 - Standard SnPb solder (Tc)
Package
thickness
Volume
mm3
很抱歉,暂时无法提供与“SDCH1V8040-101M-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.98080
- 10+2.34360
- 30+2.07360
- 国内价格 香港价格
- 1+3.530971+0.45913
- 10+2.9282510+0.38076
- 100+2.40650100+0.31291
- 国内价格 香港价格
- 1000+0.986601000+0.12829
- 2000+0.930192000+0.12095
- 3000+0.898713000+0.11686
- 5000+0.860625000+0.11191
- 7000+0.836437000+0.10876
- 10000+0.8115410000+0.10553
