MIKROE-2511
MIKROE-2511
    MIKRO
    MIKROPROGFORMSP432
MIKROE-2511 数据手册
mikroProg for MSP432 PID: MIKROE-2511   mikroProg™ for MSP432 is a fast and reliable USB programmer and hardware debugger. This mikroProg supports the SimpleLink™ MSP432™ microcontroller family from Texas Instruments. Compiler Compatibility mikroProg™ for MSP432™ is supported with mikroC™, mikroBasic™ and mikroPascal™ compilers for ARM®. SingleClick™ Debugging mikroProg™ has native support for hardware step-by-step Debugging. The debugger is a separate DLL module in MikroElektronika ARM® compilers which supports Step-over [F8], Step-into[F7], Step-out[Ctrl+F8], Run[F6], Run To Cursor[F4] debugging operations. Also, the debugger supports standard breakpoints, which enable you to exploit the full potential of fast debugging. You won’t rip out the cable How many times have you pulled the cable out of some device accidentally and it just stopped working? We made sure to provide a secure connection of programmer cable and created a holder to tie it firmly into place. Package contains mikroProg™ for MSP432 is packed in a protective box along with the relevant documentation. The package contains:     Damage resistant protective box  mikroProg™ for MSP432  USB cable  User manual  Product Type Applications Architecture Power Supply ARM Hardware Debugging ARM (32-bit) 5V (via USB) https://shop.mikroe.com/debuggers/mikroprog/msp432 3/21/2017
MIKROE-2511 价格&库存
很抱歉,暂时无法提供与“MIKROE-2511”相匹配的价格&库存,您可以联系我们找货
MIKROE-2511
  • 1+1312.571261+170.13423
